Scooter83 #1 Posted December 19, 2017 Well in my random pick ups were these 2 diagnostic carts. the 810 looks pretty much standard for that an 810 diagnostic cart would be ( still need to fire it up and compare it to the other one i have) but theres also this 810/815 cart. First one ive come across. Figured id share both with you and kinda wondering what 815 operations it tests for and how this cart would be useful on the 810 and 815 since they were not all that compatible. 2 Quote Share this post Link to post Share on other sites
MrFish #2 Posted December 19, 2017 it's probably this: Quote Share this post Link to post Share on other sites
Scooter83 #3 Posted December 19, 2017 Thats what Im guessing itll be since it says REV E. But what does it mean on the 810 label (FLDEX) is that a employee code for an employee or what? Quote Share this post Link to post Share on other sites
MrFish #4 Posted December 19, 2017 (edited) Thats what Im guessing itll be since it says REV E. It also has "B/I" on it, for Burn-In. But what does it mean on the 810 label (FLDEX) is that a employee code for an employee or what? It stands for "Field Exerciser" (see below). Edited December 19, 2017 by MrFish Quote Share this post Link to post Share on other sites
Tempest #5 Posted December 19, 2017 it's probably this: 810-815 Burn-In.png So are the 810 and 815 compatible enough that they can use the same diagnostic cart? I thought they were pretty different internally. Quote Share this post Link to post Share on other sites
Scooter83 #6 Posted December 19, 2017 Well if it comes up as a field exerciser on boot up that would be different than the other 810 i have so that would be a keeper as well. Well im glad to add these and even though i did find a dump for the 810/815, if the screen boots up any different ill put it with the others to be dumped. cause i assume that all E rev carts should be from the same source. Quote Share this post Link to post Share on other sites
MrFish #7 Posted December 19, 2017 So are the 810 and 815 compatible enough that they can use the same diagnostic cart? I thought they were pretty different internally. Apparently 8K is enough to handle it. It is just the burn-in test, though. Well if it comes up as a field exerciser on boot up that would be different than the other 810 i have so that would be a keeper as well. Well im glad to add these and even though i did find a dump for the 810/815, if the screen boots up any different ill put it with the others to be dumped. cause i assume that all E rev carts should be from the same source. What do your other 810 Diag carts come up with on boot then? I thought they all showed the same screen. Quote Share this post Link to post Share on other sites
Scooter83 #8 Posted December 19, 2017 Ill double check Im not sure mine booted up with the REV 0. Could be thinking of the 130XE REV.3.4 . Ill double check Quote Share this post Link to post Share on other sites
