+TheBF #1176 Posted January 16 Looking at my Github site I find a few half-baked files. Oops. So I fixed up this one that might be useful. \ * \ * Boot tracking \ * \ * Code copied more or less verbatim from: \ * 1.7. The Art Of Assembly Part 7. Why A Duck? \ * By Bruce Harrison 1991 \ * \ BOOTTR MOV @>83D0,R12 * GET THE CRU BASE IN R12 \ MOV @>83D2,R9 * GET THE ROM ADDRESS FOR \DEVICE \ SBO 0 * ENABLE THE ROM \ AI R9,4 * ADDING FOUR PUTS US AT THE LENGTH BYTE \ MOVB *R9+,R4 * PLACE THAT IN R4 AND INCREMENT R9 \ SRL R4,8 * RIGHT JUSTIFY LENGTH IN R4 \ LI R10,FILEDV * POINT TO TEXT BUFFER \ MOVIT MOVB *R9+,*R10+ * MOV ONE BYTE FROM ROM TO TEXT BUFFER \ DEC R4 * FINISHED? \ JNE MOVIT * NO, DO ANOTHER BYTE \ SBZ 0 * DISABLE THE ROM (R4 IS ZERO AT THIS POINT) \ B *R11 * BRANCH TO NEXT SECTION OF CODE \ FILEDV TEXT "DSK1." * File device \ NEEDS MARKER FROM DSK1.MARKER \ NEEDS .S FROM DSK1.TOOLS \ MARKER REMOVE DECIMAL 24 USER 'R12 \ address of R12 in any CAmel99 workspace \ >8324 in other TI-99 Forths HEX CODE 0SBO ( -- ) 1D00 , NEXT, ENDCODE CODE 0SBZ ( -- ) 1E00 , NEXT, ENDCODE 83D0 CONSTANT DISKCARD 83D2 CONSTANT ROMADDR HEX : BOOTDISK ( -- addr len) DISKCARD @ 'R12 ! 0SBO ROMADDR @ 4 + COUNT PAD PLACE 0SBZ PAD COUNT ; 2 Quote Share this post Link to post Share on other sites
+Lee Stewart #1177 Posted January 16 4 hours ago, TheBF said: : BOOTDISK ( -- addr len) DISKCARD @ 'R12 ! 0SBO ROMADDR @ 4 + COUNT PAD PLACE 0SBZ PAD COUNT ; This will only be valid in a, likely unpredictable, narrow window of time, n’est-ce pas? ...lee Quote Share this post Link to post Share on other sites
+TheBF #1178 Posted January 16 Just now, Lee Stewart said: This will only be valid in a, likely unpredictable, narrow window of time, n’est-ce pas? ...lee I think so. I don't even remember where I found the ALC reference. Perhaps the intent is that you run it early and retain the string in your program for future file reads to use. ? Come to think of it I could use it in my Shell program to set the load disk as a default and display it in a prompt like DOS/CPM maybe. I will try a couple of other file reads from other disks and see what happens. 1 Quote Share this post Link to post Share on other sites
+TheBF #1179 Posted January 16 4 minutes ago, TheBF said: I will try a couple of other file reads from other disks and see what happens. Yes indeed I loaded a text file of source code from DSK3. and BOOTDISK TYPE showed DSK3. So I think I will rename it to LASTDISK. What to you think of that name? 1 Quote Share this post Link to post Share on other sites
+Lee Stewart #1180 Posted January 17 1 hour ago, TheBF said: Yes indeed I loaded a text file of source code from DSK3. and BOOTDISK TYPE showed DSK3. So I think I will rename it to LASTDISK. What to you think of that name? Groovy! ...lee Quote Share this post Link to post Share on other sites
+TheBF #1181 Posted January 17 The cleanup never ends I was never happy with the TRANSIENT, PERMANENT, ERADICATE system I created, mostly because I didn't finish it. I like it now. This is clean and easy. ERADICATE removes the TRANSIENT dictionary. Spoiler CR .( Transient.fth Jan 17 2022 B Fox) \ Compile code into another RAM location and remove it later) \ SEE: DSK1.LOWTOOLS DSK1.SUPERTOOLS for demo code HEX VARIABLE SAVEDP VARIABLE OLDNFA \ NFA of last word in the old dictionary : TRANSIENT ( NEWDP -- ) \ Usage HEX 2000 TRANSIENT LATEST @ OLDNFA ! HERE SAVEDP ! \ save the dictionary pointer. DP ! ; \ Point DP to transient memory : PERMANENT ( -- ) ( Restores high ram compiling ) HERE H ! \ give back what we didn't use to the HEAP SAVEDP @ DP ! \ restore DP back to original address \ built a dummy word as the link to the permanent dictionary S" $$$$" HEADER, COMPILE DOCON HERE , COMPILE EXIT ; : ERADICATE ( -- ) ( removes TRANSIENT dictionary code) OLDNFA @ LATEST ! \ relink the dictionary 2000 H ! ; \ init-the heap. DSK1.SUPERTOOLS CR .( Compile Tools in SuperCart RAM) NEEDS TRANSIENT FROM DSK1.TRANSIENT HEX 6000 TRANSIENT \ transient dictionary in supercart CR .( Compiling to address:) HERE U. INCLUDE DSK1.ELAPSE INCLUDE DSK1.TOOLS INCLUDE DSK1.ASM9900 PERMANENT CR .( Now compiling to: ) HERE HEX U. .FREE DECIMAL 2 Quote Share this post Link to post Share on other sites
GDMike #1182 Posted January 17 BTW, do you have a simple Forth assembly code I can look at to figure out how things are done without labels, branches like what I use in a loop whenever you find a moment.. just something I'd like to review. I did put together marks TF assembler manual that he provides, but again, I forgot to bring it to work with me for the second day. Quote Share this post Link to post Share on other sites
+TheBF #1183 Posted January 17 (edited) 20 minutes ago, GDMike said: BTW, do you have a simple Forth assembly code I can look at to figure out how things are done without labels, branches like what I use in a loop whenever you find a moment.. just something I'd like to review. I did put together marks TF assembler manual that he provides, but again, I forgot to bring it to work with me for the second day. Well... I have overhauled the old TI-Forth assembler for these things using some new-fangled thinkin' that came from a crazy Forth guy in Australia. It's much simpler code and takes less space in our little 99s. To be clear, the parts that are "really" changed are IF, ELSE, THEN, UNTIL, WHILE, etc. They have no error checking they just work. You may have a question or two. It took me a while to grok these things. Here is a link: https://github.com/bfox9900/CAMEL99-V2/blob/master/LIB.ITC/ASM9900.FTH Edited January 17 by TheBF typo 1 Quote Share this post Link to post Share on other sites
+TheBF #1184 Posted January 17 (edited) 52 minutes ago, GDMike said: BTW, do you have a simple Forth assembly code I can look at to figure out how things are done without labels, branches like what I use in a loop whenever you find a moment.. just something I'd like to review. I did put together marks TF assembler manual that he provides, but again, I forgot to bring it to work with me for the second day. Oops. You may have questions about Forth loops not Assembler loops. The good news is they are similar. Forth has two "jump" instructions. ?BRANCH ( sometimes called 0BRANCH) jumps if top of stack=0. The cell right after ?branch contains a negative or a positive number. TurboForth uses a 16bit address to jump to. FbForth and Camel Forth use +/- value to add to the instruction pointer to know where to jump to. BRANCH Jump unconditionally to the address (or the offset) that follows branch. So the trick is how you do all those fancy IF THEN BEGIN UNTIL when you only have 2 jump instructions? Here is the magic code from Australia. They are dead simple without error checking so it's simpler to understand. : AHEAD ( -- addr) HERE 0 , ; : <BACK ( addr --) HERE - , ; : THEN ( addr -- ) HERE OVER - SWAP ! ; IMMEDIATE : BEGIN HERE ; IMMEDIATE : IF POSTPONE ?BRANCH AHEAD ; IMMEDIATE : ELSE POSTPONE BRANCH AHEAD SWAP POSTPONE THEN ; IMMEDIATE : UNTIL POSTPONE ?BRANCH <BACK ; IMMEDIATE : AGAIN POSTPONE BRANCH <BACK ; IMMEDIATE : WHILE POSTPONE IF SWAP ; IMMEDIATE : REPEAT POSTPONE AGAIN POSTPONE THEN ; IMMEDIATE Think of POSTPONE as a word that "compiles" something into a Forth definition. Simplest loop structure to understand: BEGIN AGAIN : TEST BEGIN ( puts HERE on the data stack because it's an immediate word) 2 2 + ( we put some code in the definition which moves the dictionary pointer forward. (Remember that HERE just does fetch on the dictionary pointer variable) DUP DROP AGAIN ( compile the Forth BRANCH word into the definition, ( <BACK computes the difference between the HERE at BEGIN and HERE right now and compiles that number with comma) ( TF compiles the actual HERE from BEGIN) ; Give it a stare and ask more questions. Edited January 17 by TheBF 2 Quote Share this post Link to post Share on other sites
GDMike #1185 Posted January 18 (edited) Now I gotta try this out. Actually, I am asking about both, this is a nice start. Meaning forth assembler. But I have that manual, I'll look at that. But this is very good to start with. I Know simple loops using DO .. LOOP and using that, but this is a nice example I never seen. Thank you. I'll jump out now... Edited January 18 by GDMike Quote Share this post Link to post Share on other sites
Willsy #1186 Posted January 18 (edited) Immediate words are the key to doing powerful things in the Forth language. As you can see, CAMEL99 uses POSTPONE to compile a word (immediate or not) into a definition. TF (and possibly fbForth?) uses COMPILE and [COMPILE] (though POSTPONE is defined on the TurboForth TOOLS disk if you want to use POSTPONE in TF). For an introduction to immediate words, have a read of this (this took a bit of tracking down!): The information presented above applies to all Forth systems, not just TF or CAMEL or fbForth. Immediate words are a pretty much universal Forth concept. I'm having a blast reading these old articles - it's like someone else wrote them! I'm impressed at how much stuff I knew, and depressed at how much stuff I've forgotten! Edited January 18 by Willsy 3 Quote Share this post Link to post Share on other sites
+Lee Stewart #1187 Posted January 18 7 hours ago, Willsy said: TF (and possibly fbForth?) uses COMPILE and [COMPILE] Yup. ...lee 1 Quote Share this post Link to post Share on other sites
GDMike #1188 Posted January 18 (edited) Funny thing, as I was typing letter by letter in a screen, because of other reasons, into my TF as I needed the SAMs functionality and only had a screenshot of the definitions, and I saw this, [COMPILE] and I noticed a word prior to the word [COMPILE] and i assumed it was creating a word on the fly so to speak, and I haven't had time to try this on my own yet, and I haven't quite understood the difference between [COMPILE] and COMPILE... but anyway..let me get back into the book first before tying up the Post. A lot can be had by reading... thx all Edited January 18 by GDMike Quote Share this post Link to post Share on other sites
+TheBF #1189 Posted January 18 (edited) On 1/18/2022 at 3:27 PM, GDMike said: Funny thing, as I was typing letter by letter in a screen, because of other reasons, into my TF as I needed the SAMs functionality and only had a screenshot of the definitions, and I saw this, [COMPILE] and I noticed a word prior to the word [COMPILE] and i assumed it was creating a word on the fly so to speak, and I haven't had time to try this on my own yet, and I haven't quite understood the difference between [COMPILE] and COMPILE... but anyway..let me get back into the book first before tying up the Post. A lot can be had by reading... thx all This can get into the weeds pretty fast in Forth and truth be told I most of the time have to try things a few times before they work as I want them to. So COMPILE and [COMPILE] are used to make a special kind of words that let you extend or change how the compiler works. It's important to understand this point because when programming in most languages you don't change the compiler. So this is a pretty special case. I would say black-belt level Forth. So lets look at the examples for IF up above. In Forth83 or Fig Forth this would be like below (their are other error protection words used in a lot of systems but this is the payload section) : IF COMPILE ?BRANCH AHEAD ; IMMEDIATE The system has a word called ?BRANCH that compares the TOS to zero and jumps ahead if it is true. When we make this code in our program it will type "TRUE!" if the TOS of stack is anything other than zero. Here is how that happens. : TEST IF ." TRUE!" THEN ; Internally it looks like this which is really weird when you don't understand it. ( Details will vary a bit on various Forth systems but here is what Camel Forth compiles) : TEST ?BRANCH 12 S" TRUE!" TYPE ; Notice that when we typed IF the compiler put in ?BRANCH . That is what COMPILE did. It "compiled" the token for ?BRANCH into the word we created. Why go to that trouble? Because ?BRANCH needs to know how far to jump "ahead". We don't actually know that when are programming so if figures that out for us. Guess which word figures out how far to jump AHEAD? IF is an immediate word so even though we were in compile mode by the ':' AHEAD ran when IF was invoked. This what AHEAD did: put the HERE address on the data stack to remember where it is it compiled 0 into the HERE address (using comma) **The zero is a place holder for how far "ahead" we have to jump. We won't know that until we hit "THEN". ----------------- Next we compiled a string "TRUE!" and TYPE to print the string. When the compiler hits THEN some magic happens. : THEN ( addr -- ) HERE OVER - SWAP ! ; IMMEDIATE There is already HERE on the data stack that is right after ?BRANCH. THEN puts HERE on the data stack so we know where it is in memory. If only we could somehow subtract those two addresses we would know how far ?BRANCH has to jump AHEAD! Thank G_d we have a computer handy. The calculation is HERE1 HERE2 OVER - ( -- HERE1 offset) Remember that zero we stuck in memory, it is at address HERE1. So SWAP ! puts the offset in memory that ?BRANCH needed all along. You can use [COMPILE] for the same thing as COMPILE but for "compiling" IMMEDIATE words. "Thus endeth the lesson" Edited January 26 by TheBF removed whitespace 1 1 Quote Share this post Link to post Share on other sites
GDMike #1190 Posted January 18 Right on. Sorry to tie you up..it's fun though, but I don't see your arms wailing around...so much is missing by typing it out. I gotcha exactly, but I'm comparing it a bit to the assembler doing math for me at assembly Time when I don't know a particular value would be until run time for a situation, like a clock time or screen timer value..I suppose, maybe a poor comparison, but it's all I got.. I'm really jumping the gun and I should be in the book a bit more..I think, maybe, that some of this isn't really found that easy...it might be in the book but have no example...etc . It'll be awhile before I use those words.. but I'll promise to get what I can get in my TF manual. 1 Quote Share this post Link to post Share on other sites
+Lee Stewart #1191 Posted January 19 The explanations of COMPILE and [COMPILE] by @Willsy and @TheBF are spot on, but, to me, the very use of “compile” in the names of both of these two words has been the reason I took so long to grok what they actually did and how to use them. I agree with both fellas that POSTPONE is much to be preferred because the programmer does not lose any sleep over which of the other two words to use, but I think it is more consistent to think that what is always postponed is execution rather than compilation. The reason I say this is that, while the interpreter is compiling a new word started with : , [COMPILE] is the only way to compile an immediate word (execution only), whereas COMPILE does, in fact, defer or postpone compilation one level (but only for normal words). [Note: You can use [COMPILE] to compile a normal word, but the interpreter would compile it anyway, so it is only reasonable to use it for immediate words. On the other hand, COMPILE will not work on immediate words at all. It must be used on normal words or bad things will happen.] So, in line with “deferring execution”, [COMPILE] defers execution of an immediate word, COMPILE defers execution of a normal word, and POSTPONE defers execution of either. Here is how to use [COMPILE] and COMPILE : Spoiler : IMMEDIATE_WORD_1 ( do stuff, even while compiling ) ; IMMEDIATE \ make IMMEDIATE_WORD_1 immediate : IMMEDIATE_WORD_2 ( do stuff, even while compiling ) ; IMMEDIATE \ make IMMEDIATE_WORD_2 immediate : NORMAL_WORD ( do stuff normally ) ; : OTHER_STUFF ( do stuff normally ) ; : WORD1 IMMEDIATE_WORD_1 \ IMMEDIATE_WORD_1 executes now [COMPILE] IMMEDIATE_WORD_2 \ IMMEDIATE_WORD_2 compiles now COMPILE NORMAL_WORD \ COMPILE & NORMAL_WORD both compile now OTHER_STUFF \ OTHER_STUFF compiles now ; IMMEDIATE \ make WORD1 immediate :WORD2 WORD1 \ executes now and does the following: \ IMMEDIATE_WORD_2 executes now \ COMPILE executes and compiles NORMAL_WORD \ OTHER_STUFF executes now \ remainder of definition... ; WORD2 \ WORD2 executes now and does the following: \ NORMAL_WORD executes now \ remainder of definition executes now ...lee 2 Quote Share this post Link to post Share on other sites
Willsy #1192 Posted January 19 That's a good example, Lee. Here's another (re-hashed from the article I quoted above) with observable results: In TF or fbForth, type this (it will work in CAMEL99, too - just use POSTPONE instead of [COMPILE]: : BOB ( -- ) CR ." BOO! BOB WAS HERE!" CR ; IMMEDIATE Okay, you typed it in. Nothing much happened. Now execute it: type BOB and press enter. Again, no big surprises. Now, try this: : TOM ( -- ) BOB CR ." HELLO! I AM TOM!" CR ; Did you see what happened? While *TOM* was being compiled, BOB got in on the act and ran, rather rudely announcing his presence. Why? Because he is an immediate word, and so, when encountered by the compiler, it is executed IMMEDIATEly. So what happens if we run TOM (type TOM and press enter)? HELLO! I AM TOM! Where's BOB? Should BOB not also say BOO!? No. Because BOB was executed at compile-time (during the compilation of TOM). Sometimes, we might to override this behaviour. Sometimes we want an immediate word to be actually compiled by the compiler rather than executed. We can do this with [COMPILE]. So, we could re-write TOM like this: : TOM ( -- ) [COMPILE] BOB CR ." HELLO! I AM TOM!" CR ; Now, when TOM is compiled, nothing really happens. It just compiles it. And when TOM is executed, BOB announces his presence along with TOM, exactly the same as if we'd said: : TOM ( -- ) BOB CR ." HELLO! I AM TOM!" CR ; 2 1 Quote Share this post Link to post Share on other sites
Willsy #1193 Posted January 19 (with apologies to Brian for hijacking the CAMEL99 thread with a discussion in IMMEDIATE words!) 2 Quote Share this post Link to post Share on other sites
+TheBF #1194 Posted January 19 4 hours ago, Willsy said: (with apologies to Brian for hijacking the CAMEL99 thread with a discussion in IMMEDIATE words!) No apology needed. It's all important for GDMike to help him code his project so thanks for contributing Mark. 1 Quote Share this post Link to post Share on other sites
GDMike #1195 Posted January 19 This was exceptional for my noodle to grasp. Great.. I know something new. What a great word. Quote Share this post Link to post Share on other sites
+TheBF #1196 Posted January 20 Don't like RPN you say... I found this code on a site by Marcel Hendrix, author of iForth, a very fast native code compiler for intel boxes. ec 212a KISS (iae.nl) The code by Albert Nijhof is devilishly clever. The way you can just declare operators is brilliant. I think I could improve it by making another vocabulary so there are no name conflicts with Forth operators. I changed a couple of names because these suited my mentality but I did get the original version to compile with only a three-line harness. I also added (( and )) to make things look nicer when they are needed. I think I tried a few years back but did not have a compliant wordlist library. Three cheers for ANS Forth. It hurts my head to type infix math into a Forth command line. Spoiler \ KISS COMMANDS (Albert Nijhof) -- 1 april 2003 \ Mods for Camel Forth and some name changes Brian Fox Jan 20 2022 \ Camel99 harness INCLUDE DSK1.TOOLS INCLUDE DSK1.WORDLISTS ' 2- ALIAS CELL- ONLY FORTH DEFINITIONS DECIMAL VOCABULARY INFIX ALSO INFIX DEFINITIONS \ P-stack with relative stackpointer in cell # 0 12 CELLS CONSTANT PQ CREATE P 0 , PQ ALLOT : FRESH 0 P ! ; \ Reset p-stack : ?P ( p# -- ) \ Check overflow and underflow PQ 0 WITHIN IF FRESH TRUE ABORT" Syntax Error " THEN ; : P> ( -- x ) P @ DUP CELL- DUP ?P P ! P + @ ; : >P ( x -- ) P @ DUP ?P CELL+ DUP P ! P + ! ; ALSO FORTH DEFINITIONS : ) ( -- ) P> [email protected] ( xt imm? ) 0< STATE @ AND IF COMPILE, EXIT THEN EXECUTE ; IMMEDIATE : INFIX: ( ccc -- ) >IN @ >R ' DROP \ Does this word exist? [email protected] >IN ! BL WORD FIND ( -- xt imm?) R> >IN ! CREATE HERE 2 CELLS ALLOT 2! IMMEDIATE DOES> >P BL WORD COUNT EVALUATE POSTPONE ) ; : DUMMY ; IMMEDIATE INFIX: DUMMY \ we now loose or ( -- ) comments but oh well : ( \ -- ['] DUMMY >BODY >P ; IMMEDIATE : (( POSTPONE ( POSTPONE ( ; IMMEDIATE : )) POSTPONE ) POSTPONE ) ; IMMEDIATE PREVIOUS FORTH \ ----- End of code ----- \ ----- Examples ----- \ define infix operators INFIX: + INFIX: - INFIX: * INFIX: / INFIX: . INFIX: EMIT INFIX: > INFIX: < INFIX: = INFIX: <> INFIX: IF INFIX: THEN INFIX: AND : TEST \ ( x -- ) CR . DUP ." is " IF ( DUP = 0 ) THEN ( ." zero " ) IF ( DUP < 0 ) THEN ( ." negative " ) IF ( 0 < OVER ) THEN ( ." positive " ) ." and " IF ( = ( 1 AND TUCK ) ) THEN ( ." odd." ELSE ." even." ) ; \ make a infix version of TEST INFIX: TEST INFIX: OR INFIX: XOR INFIX: WITHIN : >UP \ ( ch1 -- ch2 ) XOR ( DUP WITHIN ( [CHAR] a [CHAR] z + 1 ) AND BL ) ; INFIX: >UP 2 Quote Share this post Link to post Share on other sites
Willsy #1197 Posted January 21 Nice job! Do you remember, decades ago (mid 80s?) Charles Moore himself wrote a version of BASIC in Forth. It was published in Forth Dimensions IIRC. It was relatively simple, as the idea was to prove a concept, but IIRC there was some clever stuff going on in there! Must see if I can find out - still need to dig my old laptop out of the garage! 3 Quote Share this post Link to post Share on other sites
+TheBF #1198 Posted January 21 2 hours ago, Willsy said: Nice job! Do you remember, decades ago (mid 80s?) Charles Moore himself wrote a version of BASIC in Forth. It was published in Forth Dimensions IIRC. It was relatively simple, as the idea was to prove a concept, but IIRC there was some clever stuff going on in there! Must see if I can find out - still need to dig my old laptop out of the garage! LOL. I didn't have to do much. Mr. Nijhof is a pretty hot Forth programmers. Yes I do remember that one. I tried porting it once but failed. It does beg the question. What would a BASIC in Forth be like? I often wonder would it run faster than on written in GPL ? The BASIC compiler that the community uses is actually compiling to direct threaded code so that's a pretty good indicator of what could be done. 4 Quote Share this post Link to post Share on other sites
+TheBF #1199 Posted January 25 Now that I seem to have a stable build I have read that an ITC Forth system spends about 50% of its time running the inner interpreter called NEXT. I often wondered how much difference this would make: NEXT as it exists in the existing TI-99 Forth systems... l: _next *IP+ W MOV, *W+ R5 MOV, *R5 B, Versus this: l: _next *IP+ W MOV, *W R5 MOV, *R5 B, The difference is only one auto-increment, 4 clocks, but it is a reduction from 56 total to 52 total or a speedup of 3.7% Now that I have a nice build file it was easier to find out. I made a new version of my primitives file with this new NEXT code and I had to add one line to four routines: W INCT, to DOVAR DOCON DOUSER and DOCOL. And the results are... its a bit faster. On code like OPTEST below where each word is short and NEXT makes up a big piece of the running time I measured 12.6 sec. vs 12.2 sec or 3.3% speedup. On a big test like the SEVENS benchmark it was 64.7 secs vs 64.1 secs so very little, but still faster. HEX : OPTEST ( mixed ) 3000 0 DO AAAA ( lit) DUP SWAP OVER ROT DROP DUP AND DUP OR DUP XOR 1+ 1- 2+ 2- 2* 2/ NEGATE ABS + 2 * DROP LOOP ; 4 Quote Share this post Link to post Share on other sites
+Lee Stewart #1200 Posted January 26 5 hours ago, TheBF said: Now that I seem to have a stable build I have read that an ITC Forth system spends about 50% of its time running the inner interpreter called NEXT. I often wondered how much difference this would make: NEXT as it exists in the existing TI-99 Forth systems... l: _next *IP+ W MOV, *W+ R5 MOV, *R5 B, Versus this: l: _next *IP+ W MOV, *W R5 MOV, *R5 B, The difference is only one auto-increment, 4 clocks, but it is a reduction from 56 total to 52 total or a speedup of 3.7%. Now that I have a nice build file it was easier to find out. I made a new version of my primitives file with this new NEXT code and I had to add one line to four routines: W INCT, to DOVAR DOCON DOUSER and DOCOL. And the results are... its a bit faster. On code like OPTEST below where each word is short and NEXT makes up a big piece of the running time I measured 12.6 sec. vs 12.2 sec or 3.3% speedup. Not sure how this would play in TI Forth and fbForth. The payloads for DOVAR DOCON DOUSER all call DODOES , which falls through to DOCOL and $NEXT . All colon definitions end in ; , which executes $SEMIS , which executes a copy of $NEXT , which actually might make it possible to separate direct calls to $NEXT with your improvement (would also affect DOEXEC ). All of this code is in scratchpad RAM on the 16-bit bus for speed: DODOES DECT SP MOV W,*SP MOV LINK,W DOCOL DECT R MOV IP,*R MOV W,IP $NEXT MOV *IP+,W DOEXEC MOV *W+,R1 B *R1 $SEMIS MOV *R+,IP MOV *IP+,W <<<----copy of $NEXT MOV *W+,R1 <<<----copy of DOEXEC B *R1 <<<---+ ...lee Quote Share this post Link to post Share on other sites
