SiLic0ne t0aD
New Coleco RGB board?
How do I adjust R23 because my RGB board doesn’t get a sync.
Also, is it possible to use the SNES styled multi out connector for the RGB mod?
Edited by Retro_Game_Lover96
That thing where someone seeks technical support from the competitor to the product they actually bought, and gets it anyway ;)
  • Haha 1
The snes multi out requires a square hole to be cut in the console shell and is a lot more work.  Also you would have to either cannibalize another console for the connector, or 3D print one and get a pcb manufactured.  Just make sure the connector is made with hard gold on the edge connector.  Also the standard snes cable has extra capacitors and resistors in the cable that you would have to compensate for on the mod pcb to get a proper signal.  Assuming the mod board is properly attenuated.
Edited by zanaxe
Sorry, what I meant was if the mod board was not designed to work with an SNES cable, you shouldn't use an SNES cable.  To save costs on the consoles, Nintendo and Sega put some of the necessary passive components for RGB in the cable itself instead of the consoles.  I don't know enough about that mod board to know what modifications would be required in order to support an SNES cable.
16 hours ago, Retro_Game_Lover96 said:
The R23 has the SMD resistor code, 562 which is 5.6k Ohms. While the OSHPark says 5K6.
Unless something has changed in electronics labeling I'm not aware of...5.6K and 5K6 are the same thing. Just two different ways of writing it with the 5K6 being more correct.
I can tell that they’re the same thing.
I just want to remind people that this is a TMS-RGB development thread, not a citrus3000psi RGB tech support thread.
  • Haha 1
It started as a Citrus3000psi thread :)
  • Haha 1
Oh wow, I am so divorced from the origins of this thread, and have done the exact thing I was complaining about.
Reminds me of the defining moment when the power shifted in my marriage:
Her cat: Isis
Me: "What a stupid name of a cat. Who names a cat something with two S sounds in it?"
Her: "What, like Sassy?"
My cat: Sassy
Sorry Retro_Game_Lover, and go right ahead :D
  • Haha 1
15 hours ago, Retro_Game_Lover96 said:
I got it working on the PVM, but the sync issue and all green, so any ideas how to fix?
It appears that you have fused all the jumpers.  They should remain unconnected.  They bypass the pots, making them useless.
With the jumpers unbridged, you can adjust the pots to attempt to get proper hues.  Each one adjusts a different color.
Her cat: Isis
My cat: Sassy
:) Yeah you should probably start a dedicated new thread when you release your new mod.
I was planning to (when the instructions are finished). :D
Her cat: Isis
My cat: Sassy
If it makes you feel any better, I actually forgot this was the Citrus3000psi thread too. 😁
