Sign in to follow this
Gregory DG
2600 on ST monitor
Ouch... What would it take to hook up a 2600, 5200, or 7800 to an ST monitor? Does someone have a gizmo to convert RF to RGB?
I have a PAL SCART 7800 with RGB output that works. They were sold in France. :)
You could convert one to NTSC and then you'ld be set. :D
Mitch
Doesn't the colour ST monitor have a composite video input? If it does you can just hook up your 2600 via a VHS machine and then connect the composite signal from the VHS to your ST monitor...
Not much point trying to buy a RF to RGB converter. You wouldn’t really gain any picture quality, just waste your $$$ :D
Nope. Not in an RCA style format anyway.
That's true, you would have to find the pin configuration for the monitor connector (probably available on the net somewhere) and build yourself a cable. Hmm... I am pretty certain I have the pin conf. noted somewhere, if I just could remeber where… But I dont know if the configuration was the same as on the Atari end. I think one pin was "twisted"...
aargh.. just forget my previous ramblings about "twisted" pins... I was thinking about something completely different... Man, I am too tired to think straight... Oh well.. I am of the bed... nite all :D
Ahh.. that link makes a lot more sense than I did :) ... Sorry for the rambling, but my brain had turned into porridge... Hope you get it to work Gregory ...
