Umberto #1001 Posted January 30, 2020 1 hour ago, MADRAFi said: I would suggest redesigning the interface so it could present long filenames on the file list. It does on the SDrive ATR that auto boots Quote Share this post Link to post Share on other sites
MADRAFi #1002 Posted January 30, 2020 I know it kind of do on atr. but I am used to the screen in the sdrive-max. I am talking about whole list with long name. This doesn't look like it: Quote Share this post Link to post Share on other sites
tajvdz #1003 Posted January 31, 2020 (edited) 7 hours ago, Umberto said: It does on the SDrive ATR that auto boots with control-L you can display long file names but the option doesn't stay like that. after a reboot it is gone. is it possible to set it permanent? Edited January 31, 2020 by tajvdz Quote Share this post Link to post Share on other sites
darwinmac #1004 Posted January 31, 2020 1 hour ago, tajvdz said: with control-L you can display long file names but the option doesn't stay like that. after a reboot it is gone. is it possible to set it permanent? If you press Control-W, the change is written into the config file and it is permanent. I suggest @Mr Robot’s excellent website on everything to do with Sdrive Max. I consider it my online manual. https://atari8bit.net/everything-sdrive-max I believe I am crediting the correct person. If I am not, my sincere apologies. Bob C 2 Quote Share this post Link to post Share on other sites
kbr #1005 Posted January 31, 2020 On 1/29/2020 at 2:04 PM, Mclaneinc said: My question is this, the SD-Max is a drive emulator but has anyone thought of expanding on the principle and making it a multi drive type emulator, as in emulating a Happy, an Archiver etc as optional drive types. Now I accept there may be pitfalls about the happy code ownership but by the way there's other happy stuff about it can't be a huge problem. Excuse my lack of knowledge but is this even viable, is there enough storage to flash the chip with? Obviously it needs the coding as well but Altirra has pretty much fully emulated the hardware and is the source is free to use (I think). This would be difficult, because the 32K flash is nearly full, and the intention of SDrive-MAX is KISS(keep it small and simple). 16 hours ago, MADRAFi said: Is there any one who is actively working on the firmware development? I would suggest redesigning the interface so it could present long filenames on the file list. Without it usability is very poor. I know that this device is not very fast but is there a possibility to implement screen scrolling when previewing list of itmes? Especially when you do have a sd card with all the games or demos that was made This is not possible, because we have no screen buffer, and must draw each pixel manually. Otherwise this would be very slow on this interface with 16MHz, and we cannot make the font too small, because one should be able to select filenames with fingers. Quote Share this post Link to post Share on other sites
MADRAFi #1006 Posted January 31, 2020 3 minutes ago, kbr said: This is not possible, because we have no screen buffer, and must draw each pixel manually. Otherwise this would be very slow on this interface with 16MHz, and we cannot make the font too small, because one should be able to select filenames with fingers. What about redesign of buttons layout? put them on the bottom? and make more space horizontally so longer filenames are present? Use icons instead of words, reduce number of buttons? I would say Last and Top are not required. Quote Share this post Link to post Share on other sites
kbr #1007 Posted January 31, 2020 (edited) Do you really think, this 5 or 6 chars more, makes the Kraut fett? Icons are no option, because icons needs much more memory, that we don't have, than simple chars. Edited January 31, 2020 by kbr Quote Share this post Link to post Share on other sites
MADRAFi #1008 Posted January 31, 2020 Redefine Character set make an icon from a letter. Anyway the way it works now makes is much worse option comparing with sio2sd when it comes to browsing large archives of games with long name especially when the directory have multiple file versions. Quote Share this post Link to post Share on other sites
kbr #1009 Posted January 31, 2020 Good idea, may need only 5 bytes/icon, but poor b/w and 5x8 resolution. I will keep it in mind... Quote Share this post Link to post Share on other sites
archeocomp #1010 Posted February 5, 2020 On 11/15/2019 at 11:02 PM, Mr Robot said: $5.55 for 3 from OSHpark, cheaper for 100 from China Mr Robot will you post link to OSH? Thank for continuous refinements:-) Quote Share this post Link to post Share on other sites
+Mr Robot #1011 Posted February 6, 2020 When I have something to post, I'll post it. Other priorities (mostly personal) are keeping me from getting to finish some of the projects I'm currently involved in. I did make one of these and test it, it didn't work but I haven had time to look at what I screwed up and fix it Quote Share this post Link to post Share on other sites
mamejay #1012 Posted February 17, 2020 Hey Team, I have made a few of these and had a bunch of 2.4" screens that came in a lot. I managed to find the right firmware to use to get them working. What i have found is that on a cold boot the Atari does not see the drive and i have to do a quick power cycle of the machine to get it to recognize. i suspect it is something to do with the sdcard not initializing fast enough on boot up. My system is a Pal 130XE and I am getting power from the SIO port. Wondering if there is any hack that can be done to the uno to get it to initialize faster is that is what the problem is. Thanks Quote Share this post Link to post Share on other sites
+DrVenkman #1013 Posted February 17, 2020 1 hour ago, mamejay said: and I am getting power from the SIO port. That’s the problem - the Atari boots up faster than the Arduino gets up and running. You either need to alter your device for external power and have it running before the Atari boots, or do some kind of mod to your Atari that lets you cold boot without a power cycle. Quote Share this post Link to post Share on other sites
mamejay #1014 Posted February 18, 2020 14 hours ago, DrVenkman said: That’s the problem - the Atari boots up faster than the Arduino gets up and running. You either need to alter your device for external power and have it running before the Atari boots, or do some kind of mod to your Atari that lets you cold boot without a power cycle. I was advised here to move away from powering externally. Strange that I have one 2.8" screen and that works perfectly. just seems to be the 2.4" screen. Could it be something to do with the LCD and SDcard hardware on it? i might just reformat the sdcard and see if that makes any difference. Could be the sdcard being a ms too slow Quote Share this post Link to post Share on other sites
kbr #1015 Posted February 20, 2020 Maybe it depends on the display type, some needs more code and time for initialization, than others. Hold down the reset key during power on until sdrive-max is ready! 2 Quote Share this post Link to post Share on other sites
michomis #1016 Posted March 9, 2020 (edited) Sorry for being little lazy, but reading 42 pages can take some time... Is there any reason why 140KB ATX discs won't run on my SDrive Max? These are mostly polish games, like Robbo etc. http://ftp.pigwa.net/stuff/collections/Atari 8bit Preserved Software 2020-01-25/Robbo (1989)(L.K. Avalon)(PL)[disk].zip All other stuff loads normally: 90KB discs, cas, atr's. Of course, I have tried many OS, turn on/off basic, setup SDM as 1050 etc. All I get is BOOT ERROR at first sector each time. My machine is 65XE with Ultimate 1MB. I use 1.2c firmware on SDM. Can it be fixed in SDM firmware maybe? Edited March 9, 2020 by michomis forgot to ask question Quote Share this post Link to post Share on other sites
Umberto #1017 Posted March 10, 2020 8 hours ago, michomis said: Sorry for being little lazy, but reading 42 pages can take some time... Is there any reason why 140KB ATX discs won't run on my SDrive Max? These are mostly polish games, like Robbo etc. http://ftp.pigwa.net/stuff/collections/Atari 8bit Preserved Software 2020-01-25/Robbo (1989)(L.K. Avalon)(PL)[disk].zip All other stuff loads normally: 90KB discs, cas, atr's. Of course, I have tried many OS, turn on/off basic, setup SDM as 1050 etc. All I get is BOOT ERROR at first sector each time. My machine is 65XE with Ultimate 1MB. I use 1.2c firmware on SDM. Can it be fixed in SDM firmware maybe? Bad file, I have had very few atr's not work. But have had plenty of atx files not work. Try to find it in a atr. Quote Share this post Link to post Share on other sites
michomis #1018 Posted March 10, 2020 3 hours ago, Umberto said: Bad file, I have had very few atr's not work. But have had plenty of atx files not work. Try to find it in a atr. Well, all of these "bad" files work fine on Altirra. All of "bad" files are 140KB, so my assumption is that firmware do not support 140KB ATX files. And, I like to run "original" disk images on my Atari, and most ATR are cracked files. This is main reason I have built SDrive Max, as for ATRs, I use mostly SIO2SD. Quote Share this post Link to post Share on other sites
michomis #1019 Posted March 11, 2020 Today I have checked all these problematic for SDM ATX files on newest RespeQT, and loaded them all using SIO2USB with no problem. Is there any chance to update SDM firmware I wonder... Quote Share this post Link to post Share on other sites
darwinmac #1020 Posted March 11, 2020 (edited) I think you would need to contact @kbr The Github page is here: https://github.com/kbr-net/sdrive-max I think your diagnosis is correct. However, I do not know how easy it would be to work with those ATX files. I don’t know if LK Avalon created disks in a non-standard format. On the ST, I know you could format disks to a greater number of tracks and sectors. Though I only have an 8-bit now, I’m assuming you can do something similar to the ST. I have had good luck with ATX files on my SDM, but this might explain the problems I have had with some files. Bob C Edited March 11, 2020 by darwinmac Grammar Quote Share this post Link to post Share on other sites
ijor #1021 Posted March 12, 2020 On 3/10/2020 at 4:37 AM, michomis said: All of "bad" files are 140KB, so my assumption is that firmware do not support 140KB ATX files. Most ATX files that are ~140K, including that Robbo polish title, are images of enhanced density disks. Seems that the current firmware has some issues or limitations with enhanced density ATX images Quote Share this post Link to post Share on other sites
darwinmac #1022 Posted March 12, 2020 @ijor - Thanks for that response. Obviously, you know how the ATX format works. Looking at the beginning of this thread, @Farb was the person to add ATX support to the Sdrive Max. While it would be nice if enhanced density ATX files were supported, I have looked at ATX support as a nice to have feature. For me, the main points are the touchscreen (easier to switch multi-disk programs than with my old SIO2SD) and the great 3D printed cases available for it. With that said, it would be nice if this could be fixed. Bob C Quote Share this post Link to post Share on other sites
Mclaneinc #1023 Posted March 12, 2020 Do these titles work on any real disk drives? If not then its no real fault of the SD MAX, Altirra as we know depending on what if you use software emulation or device emulation will or will not boot certain disks while in software they will run. Quote Share this post Link to post Share on other sites
michomis #1024 Posted March 12, 2020 35 minutes ago, Mclaneinc said: Do these titles work on any real disk drives? But how would one check it? I have no possibilities to copy ATX on real drive. Originals of these games (ex. from Retronics) load normally from real fdd, and images from what I know, are made exactly like them, with bad sectors etc. Fact that these "bad" ATX files load through SIO2USB, is enough for me to consider something is wrong with SDM or SDM firmware. Quote Share this post Link to post Share on other sites
Mclaneinc #1025 Posted March 12, 2020 Obviously others with different drives can check the titles out, I'm just interested if they will load from real drives. The point being if they do load from real drives then the SD MAX needs tweaking, the fact they load by SIO2USB is down to IF the software is checking drive emulation 100% or like software mode in Altirra, it allows some abnormalities through and just is very good general emulation. Obviously we all would like the SD MAX to be as open to all formats but there's only so much flash space on the item so I suppose there could be problems with some emulation requests. I'm, clearly not the programmer.. Quote Share this post Link to post Share on other sites
