madness77 #1126 Posted June 8, 2020 33 minutes ago, Mr Robot said: yes ...or you can compile and flash diagnostic example from that library (with Arduino IDE): https://github.com/prenticedavid/MCUFRIEND_kbv it's LCD_ID_readreg.ino https://github.com/prenticedavid/MCUFRIEND_kbv/tree/master/examples/LCD_ID_readreg I think (if there's still some free space available in the UNO) that should be in the firmware as a feature. Quote Share this post Link to post Share on other sites
_The Doctor__ #1127 Posted June 8, 2020 (edited) I think space is fairly used up now... and anything left would be for other features. though it's more than likely already being read as part of detection Edited June 8, 2020 by _The Doctor__ Quote Share this post Link to post Share on other sites
+MacRorie #1128 Posted June 8, 2020 8 hours ago, bazza666 said: where can I get the UNO2SIO boards from? If you send me a SASE, I will send you one for free (well, the cost of the envelope and a stamp). If you are out of the states, you can either send an International Reply Coupon or somehow get me USPS postage for a later to your address. The Brewing Academy 15 Court St Woodland, CA 95695 This is JUST for a blank UNO2SIO board, you have to put it together. 3 Quote Share this post Link to post Share on other sites
+MacRorie #1129 Posted June 8, 2020 3 hours ago, ijor said: Firmware upgrade: I am trying to upgrade the firmware but I don't know which LCD controller I have (I didn't build it). Is there anyway to know which firmware variant was flashed before? Or should I just try to reflash the firmware for every controller one by one, until one that works? Probably I am missing something here: Last version is supposed to have autodetection? Then why there are still multiple versions for each LCD controller? Thanks, If anyone buys an assembled unit from me, it will be an ili9341 if it has no indication of model. If it is anything but that, I will have noted it in the backside of the UNO where I date and sign it. 2 Quote Share this post Link to post Share on other sites
ijor #1130 Posted June 9, 2020 Re: Firmware upgrade Thanks everybody for the comments. I finally could upgrade the firmware to the latest. I won't bore you with the details, but it took some time and it wasn't easy. Quote Share this post Link to post Share on other sites
_The Doctor__ #1131 Posted June 9, 2020 Please bore us with details, it may help someone... warts and all. 1 Quote Share this post Link to post Share on other sites
ijor #1132 Posted June 9, 2020 (edited) 1 hour ago, _The Doctor__ said: Please bore us with details, it may help someone... warts and all. Ok, if you insist First problem was to install the arduino USB driver that is required to flash the device over USB. Note that I never do that kind of stuff in my main machine. I used a system running Windows 7. I downloaded Xloader from this page: https://atari8bit.net/de-re-sdrive-max because it was supposed to automate the whole process installing the drivers among other things. Well, it didn't install any drivers. So as recommended on other pages I downloaded the whole Arduino IDE which is supposed to have drivers for every type of Arduino, or so I thought. I didn't install the IDE, I just unzipped it and pointed Windows to search for a driver in the Arduino folder, but it couldn't find anyone matching the Sdrive-Max. So I decided to went along and actually install the Arduino IDE and let it install every driver it asked me during the process. I would never do something like that in my main machine, of course. Even then, after full install and reboot, the Sdrive-Max was still unrecognized by Windows. It was at this point that I checked the properties of the USB device and looked up the USB VID/PID (the USB device ID) and performed some research. It turns out that the USB interface in my Arduino is made by some obscure Chinese manufacturer. Windows 10 can automatically detect the device and install the corresponding driver, but for some reason Windows 7 doesn’t and can’t even find any driver online. Seems the only way is to download the driver manually from some Chinese web page. And of course that it took some time to find out all of this. So I had to browse and navigate a web page in Chinese only, guess what file I need to download, and more important, guess which one is the right button to initiate the download. I hoped that the Chinese text I clicked meant “download” and not something like "Yes, I agree to participate in some kind of coronavirus trial" Finally I had the right driver installed and Windows could recognize the Max and I could use Xloader to flash the new firmware. But as I said before, I didn’t know which LCD controller I have and then didn't know which version of the firmware to install. As hinted by The Doctor, indeed the Max flashes the current LCD controller for a fraction of a second at boot time. I seemed to read ILI9340 (guess I’m getting older ...) and tried to flash that version. The firmware upgrade worked, at least apparently as I could calibrate the touch and the Max booted the new firmware ok. So I thought that I flashed the correct version. But then when inserting the card and trying to actually use it, it didn’t work well. I thought the problem might be something particular to the latest version not being fully stable. So I downgraded to an older version, but now even the touch calibration wouldn’t even work. It was only at this point that I realized I might have flashed the version with the wrong controller. It didn't occur to me before, because I thought that in that case it wouldn't work at all and it would show nothing on the LCD. I guess that the reason that the latest version worked partially, even when using the wrong controller, it's because it has some kind of auto detection? Lastly I flashed the last version with the ILI9341, as it seems that is the most common LCD controller, and it also turned out that this was the one I actually have. And then, a couple of hours later and a handful of flash erase cycles wasted, my Max is finally happy Edited June 9, 2020 by ijor 2 Quote Share this post Link to post Share on other sites
Kyle22 #1133 Posted June 9, 2020 This works PERFECTLY under XP32. I have yet to get good Android or Fire Stick drivers working on Win 7. Yuck. Stick with what WORKS. (And they can't spy upon). XP32 is the SAFEST OS to run... Don't believe me? History will prove me correct. Wanna bet? Win 7-10 is (or can be) infiltrated by evil Bill Gates M$ $pyware. This goes MUCH deeper than anyone can imagine. Prove me wrong. I DARE ANYONE to PROVE me wrong. BTW, if I get blocked, then it means I am over the target. :) 1 Quote Share this post Link to post Share on other sites
+remowilliams #1134 Posted June 13, 2020 I thought I posted this before, but perhaps not. In Windows 10, the easymode to build and flash the sdrive-max code is to install WSL/Ubuntu (or use native linux if that's your thing) Then it's pretty much just this inside WSL/Ubuntu. ttyS3 refers to COM3: change as required for your setup. Substitute whatever your screen type is for atmega328-ili9341. sudo apt update sudo apt upgrade sudo apt install build-essential git binutils gcc-avr avr-libc uisp avrdude flex byacc bison git clone https://github.com/kbr-net/sdrive-max cd sdrive-max make cd atmega328-ili9341 sudo chmod 666 /dev/ttyS3 avrdude -carduino -pm328p -P /dev/ttyS3 -U flash:w:eeprom_writer.hex avrdude -carduino -pm328p -P /dev/ttyS3 -U flash:w:SDrive.hex To download and build the xa cross compiler (needed for Atari 8 bit executable generation): curl -o xa-2.3.11.tar.gz https://www.floodgap.com/retrotech/xa/dists/xa-2.3.11.tar.gz tar -xvf xa-2.3.11.tar.gz cd xa-2.3.11 make To grab a specific branch of the sdrive-max code you can do (ex) inside the sdrive-max directory: git checkout v13 1 Quote Share this post Link to post Share on other sites
ijor #1135 Posted June 14, 2020 (edited) 9 hours ago, remowilliams said: I thought I posted this before, but perhaps not. In Windows 10, the easymode to build and flash the sdrive-max code is to install WSL/Ubuntu (or use native linux if that's your thing) Useful info, thanks. But my problem was that I did it on Windows 7 that doesn't have the USB driver. Otherwise it wouldn't have been much of a problem. Actually Xloader from the link I posted above it does work quite well and makes the whole process very simple and quick. That is assuming you do have the USB driver and you don't want to build the code yourself, just flash. Btw, I forgot that I have a clone Atmel AVR programmer that I bought a few years ago but I never used it. Guess I could use it to flash the AtMega directly bypassing the USB altogether. Not sure it is really worth except to test the programmer Edited June 14, 2020 by ijor Quote Share this post Link to post Share on other sites
+MacRorie #1136 Posted June 14, 2020 Just now, ijor said: Btw, I forgot that I have a clone Atmel AVR programmer that I bought a few years ago but I never used it. Guess I could use it to flash the AtMega directly bypassing the USB altogether. Don’t think that is going to work. When I started trying to make these, thought I could just use the header and flash it that way. It appears to work, but won’t see the SD correctly. I had to reflash via the USB 1 Quote Share this post Link to post Share on other sites
ijor #1137 Posted June 14, 2020 10 minutes ago, MacRorie said: Don’t think that is going to work. When I started trying to make these, thought I could just use the header and flash it that way. It appears to work, but won’t see the SD correctly. I had to reflash via the USB Interesting. Did you research why it didn't work? May be something to do with the eeprom writer? Quote Share this post Link to post Share on other sites
ijor #1138 Posted June 24, 2020 (edited) Touch screen controller technical info: Anybody has any technical info and datasheet for the analog touchscreen interface controller? I can find plenty of data for the LCD controller, but barely anything at all about the touch analog interface. Thanks Edited June 24, 2020 by ijor Quote Share this post Link to post Share on other sites
Jayemaitch #1139 Posted July 12, 2020 Hey guys! Brand new to the forum and a long time Atari user since childhood. Been wanting to build an sdrive max for sometime now. Purchased a DIP style arduino with screen flashed it and its now running and ready to wire up and have a question regarding wiring for power and future firmware updates. I understand that u can put in a spdt switch to facilitate firmware updates so there's no need to reseat the #2 pin on the chip. Also I have seen another switch that can be used to switch between sio power and barrel/USB power, but I have only seen diagrams of that with the other style arduino that needs the sio2uno board. Is there a way to wire that up with the dip style arduino? Or shall I just not wire 5v from sio and use external power? I want to install a switch for future firmware anyways. Just looking to cover all bases... Thanks in advance for all your advice... 😊 Quote Share this post Link to post Share on other sites
marcokitt2000 #1140 Posted July 12, 2020 Hello to all atari users, I have without the sio fixer. My question is i see that sio out to rx and sio in to tx same as sio2pc but why must rx chaned tx sio2 1050 can this work with sdrive max to when its connect to 1 1050 and 1050 to atari. And why must there a buffer chip with 2 ristors? Is there a easy way to solve the problem. Gr. Marco Quote Share this post Link to post Share on other sites
_The Doctor__ #1141 Posted July 13, 2020 if externally powered (not from SIO) and no other device is connected SIO2-1050 mode would more than likely work even without modification...You would still need to rename sd card atr's from being called new.atr to whatever the name is ... just make extra steps, just as easy to put the sd card in your wintel/lintel x86 x64 box and copy the files to the sd card... Quote Share this post Link to post Share on other sites
marcokitt2000 #1142 Posted July 13, 2020 15 hours ago, _The Doctor__ said: if externally powered (not from SIO) and no other device is connected SIO2-1050 mode would more than likely work even without modification...You would still need to rename sd card atr's from being called new.atr to whatever the name is ... just make extra steps, just as easy to put the sd card in your wintel/lintel x86 x64 box and copy the files to the sd card... Thanks for the info. Quote Share this post Link to post Share on other sites
Dropcheck #1143 Posted September 17, 2020 I'm wondering what is needed to use an Arduino Pro Mini board instead of the UNO. Same Atmega 328P chip. Assuming I matched the pinout of the UNO to the pinout of the Pro Mini. I would have to use an external USB to UART board to program it. Quote Share this post Link to post Share on other sites
cbelcher #1144 Posted September 17, 2020 This is what I did: Quote Share this post Link to post Share on other sites
Dropcheck #1145 Posted September 17, 2020 47 minutes ago, cbelcher said: This is what I did: I want to keep the touch screen, just swap out the board. Quote Share this post Link to post Share on other sites
Fred Olivas #1146 Posted September 26, 2020 Good evening all, I have a wiring question that I can't seem to find an answer to on this board. I got all the pieces to make the SDriveMax and it is running version 1.1 at the moment. My question is: I installed the UNO2SIO daughter board and this question is about the external power switch pads. SIO/SW. Leave unattached and only power from external power, connect via a switch then one has a choice between external power or power supplied by the Atari computer BUT DO NOT RUN BOTH at the same time! So with the switch attached (SPST toggle) the red LED power light lights up (added) and the unit runs as expected. When I toggle the switch, the power light still stays on and the screen runs like normal so it is still getting power externally. I thought the switch killed external power but it doesn't. My fear is that when I attach to my Atari then BOTH power sources will be running into the Arduino and brick it. What does the switch do besides nothing? Perhaps I have it wired incorrectly. Any help would be most appreciated. Quote Share this post Link to post Share on other sites
+Mr Robot #1147 Posted September 26, 2020 The switch cuts pin 10 of the sio connector (+5v) so there is no way for the power sources to conflict. you can power the sdrive from usb, sio or the power jack. So even if the switch is set to disconnect the sio but you are plugged into usb you are still getting power Quote Share this post Link to post Share on other sites
Fred Olivas #1148 Posted September 28, 2020 Hi all, I have soldered the UNO2SIO board onto my Arduino board and when I power up with an external 9v power supply everything works just dandy. The problem I'm experiencing is that I get NO power from my Atari Computer so the Arduino doesn't turn on. As printed in the UNO2SIO board numbers 3,4,5,7,10; #4 is ground & #10 is 5v. When powered externally with a power supply, and working, I placed my volt/ohm meter to pins 4 & 10 thinking I'd see 5vDC. I get nothing which explains why my Atari Computer won't/can't power my SDrive Max. Anyone else experience this same problem? Quote Share this post Link to post Share on other sites
+Mr Robot #1149 Posted September 28, 2020 and the switch is set to SIO power? Quote Share this post Link to post Share on other sites
Fred Olivas #1150 Posted September 29, 2020 Problem solved. Turns out that my cable wiring was wrong. Both ends didn't match. Silly me. Quote Share this post Link to post Share on other sites
