Coolcrab
Realaports carts as donor?
I found a site that sells realsports football and volleyball for very cheap. I was wondering if anyone knew how the board looks? Would it work to use those as a donor.
Yes, those games should work as donors. The boards have a standard 24-pin footprint for the ROM, so if you want to make a 2K or 4K cartridge, a 2716 or 2732 EPROM should do the job; you'll just need to remove the old ROM, solder in the new one, and add an inverter to generate the chip enable signal (see this thread for more information). A game that is 8K or larger would require a special board, since a plain EPROM does not have the necessary bankswitching circuitry for games of that size.
FYI - I used a "Realsports Baseball" as a donor shell a little while ago and that label was a nightmare to get completely off!
Great thanks! I was asking because I remember buying a realsports game that had 2 chips on it. But I forgot which one that was.
If it was a sports game, it was probably Super Football. That was one of a number of SuperChip games that contained an extra 128-byte memory chip called SARA. This thread has a complete list of the games that used this chip, along with a picture of the board.
Yes this was it! Can you use that board as an ordinary 4k one?
I've never tried, so anyone who knows differently should correct me, but I don't see why not. No 4K games used the SuperChip, so it will end up going to waste inside the cartridge, but the ROM should work.
Yes, remove SARA (or be barbaric and cut off the 5V line) and connect the 2 pins of where the SARA resided.
