swapd0
Sound system with vbcc
Hello
I'm coding a Jaguar game and I need a sound system that allows me to play mod files and some sound effects at the same time.
I've tried u235se but the object file is not compatible with vbcc, if I try to use rln as linker it doesn't recognise the compiled c source code.
Thanks
Never used SMAC to build any of my stuff so this may not work. Didn't throw out any warnings or errors. But could you try the attached object file instead of the release version and let me know if it works for you?
U-235SE-0.22-SMAC.zip
attachicon.gifU-235SE-0.22-SMAC.zip
I'm using rmac on OSX, and the problem that I've is that it looks that it can't link c files compiled with vbcc, but I've DrTypo's tube source code and he uses vbcc, but sln as linker.
rln -v -e -l -rd -a 4000 x x -o game.jag obj/main.o obj/imgobjects.o obj/blitter.o obj/player.o obj/playerGrfx.o obj/cpuPlayer.o obj/backgroundGrfx.o obj/overlaysGrfx.o obj/playfield.o obj/sprite.o obj/sound.o obj/joypad.o obj/video.o u235se/u235se.obj
Reboot's Linker for Atari Jaguar
Copyright (c) 199x Allan K. Pratt, 2014 Reboot
V1.2.2 Feb 23 2018 (OSX/Linux)
dofile() : `obj/main.o' NORMAL
dofile() : `obj/imgobjects.o' NORMAL
dofile() : `obj/blitter.o' NORMAL
dofile() : `obj/player.o' NORMAL
dofile() : `obj/playerGrfx.o' NORMAL
dofile() : `obj/cpuPlayer.o' NORMAL
dofile() : `obj/backgroundGrfx.o' NORMAL
dofile() : `obj/ballGrfx.o' NORMAL
dofile() : `obj/overlaysGrfx.o' NORMAL
dofile() : `obj/playfield.o' NORMAL
dofile() : `obj/sprite.o' NORMAL
dofile() : `obj/sound.o' NORMAL
dofile() : `obj/joypad.o' NORMAL
dofile() : `obj/video.o' NORMAL
dofile() : `u235se/u235se.obj' NORMAL
Output file is game.jag
Read file obj/main.o
obj/main.o is not a supported object file
Link aborted.
make: *** [build] Error 1
Just saying, latest rln version is v1.5.2. Maybe try compiling the latest version from http://shamusworld.gotdns.org/git/rlnand try that? (link points to the git repo btw).
Downloaded and compiled, It's the same version that I have.
I've downloaded sln source code, let's try it. If it doesn't work I'll try the Remover's library.
Why my sound effects only sound on channel 4?
If I send command $42 I can hear the sound effect but if I use commands, $52, $62 or $72 nothing sounds...
I assume you are using U235 SE ?
Have the volumes of those channels been set?
Another thing that bit me a few times was my SCART cable was slightly out of the TV, so either left or right wasn't connected :D It doesn't sound like that is the case as at least one of the other SFX channels would work.
There is no reason why a sample that plays on channel 4 won't play on any of the other channels, volume setting is all I can think of off the top of my head. Have you tried playing it on channels 0-3 as well?
Yes, I'm using U235 SE, I'm playing a module on channels 0-3.
I'll try later, I've wasted a lot of time with this, I haven't set any volume for any channel... but channel 4 works.
IIRC command $4053 will set the volume of Channel 5 to 100% (range being 0-64) might be worth trying 63 if that doesn't work, its been so long I cannot quite remember the max.
I think I remember having the exact same issue in rb+, and it was as linko suggested, I wasn't setting the volume for that channel.
Setting the volume has no effect :(
With this code I've sounds on channel 0, 2, 4 & 6
_play_sound::
	move.l 4(sp),d0							; Put address of sample bank in d0
	move.l	d0,U235SE_ptr_sample_bank
	and.w #$fff0,d0							; mask off the low nibble
	or.w #$b,d0								; add Set Sample Bank instruction
	lea playlist,a0							; The address of the sound effect playlist
	move.l d0,(a0)+							; Write Set bank to playlist
	move.w next_voice,d0
	addq.w #2,d0
	and.w #$e,d0
	move.w d0,next_voice
	move.l volumes(pc,d0.w),d1
	move.l d1,(a0)+
	move.l voices(pc,d0.w),d1
	move.l d1,(a0)+
	move.l #0,(a0)+		; terminate the end of the list - Or the SE will skip off through RAM making a mess
	move.l	#playlist,U235SE_sfxplaylist_ptr	; set the playlist pointer
	rts
next_voice:
	dc.w 0
voices:
	dc.l $02
	dc.l $12
	dc.l $22
	dc.l $32
	dc.l $42
	dc.l $52
	dc.l $62
	dc.l $72
volumes:
	dc.l $4003
	dc.l $4013
	dc.l $4023
	dc.l $4033
	dc.l $4043
	dc.l $4053
	dc.l $4063
	dc.l $4073
	data
.phrase
playlist:
	dc.l 0,0,0,0,0,0,0,0,0,0
	dc.l $ff		; playlist termination
With this version I got sound on channels 0 & 4 (look at voice table, I start with channel 4 now)
_play_sound::
	addq.w #2,d0
	and.w #$e,d0
	move.l d1,(a0)+
	move.l d1,(a0)+
	rts
next_voice:
	dc.w 0
voices:
	dc.l $42
	dc.l $52
	dc.l $62
	dc.l $72
	dc.l $02
	dc.l $12
	dc.l $22
	dc.l $32
volumes:
	dc.l $4043
	dc.l $4053
	dc.l $4063
	dc.l $4073
	dc.l $4003
	dc.l $4013
	dc.l $4023
	dc.l $4033
	data
.phrase
playlist:
Also I don't know why I need the last dc.l $ff if I remove it I got no sound (the docs don't say anything about this), and If I remove it and write the code like this it doesn't work...
	move.l d1,(a0)+
	move.l d1,(a0)+
	move.l #$ff,(a0)+
	move.l #0,(a0)+
	rts
Edited by swapd0
This is the problem when you can't debug your code...
I should spend some time to make my remote debugger to work with the skunkboard and port it to OS-X
For debugging I have used the skunk console mode, then written some simple 68K debug routines that will send strings back via the console. Trivial to write something that will dump registers or hex values into strings and send them over the link.
It's certainly no full featured debug system but for a few minutes of quick hacking you can get a very useful library of functions together that will give you at least some visibility of what is going on in that black box of Jaguar goodness :)
Not sure about the $ff command at the end of the list. That is documented as being there to shutdown the SE completely, from reports back the current release build it doesn't work properly in all cases (just my test cases :/ ) so YMMV with it. But you shouldn't need to issue it on every list. As long as there is a terminator all should be good. I'd possibly also try and keep the lists long aligned too, I may be misremembering but I know unaligned long reads from RISC RAM = wacky fun times and not what you want, I cannot remember if the same is true for main RAM and the DSP (with it's 16bit bus)
I don't suppose this ever happened?  If not, I'd love to take a stab at this myself if you have the old source sitting around.
