wolhess Posted March 25, 2018 Share Posted March 25, 2018 Hallo Wolfgang! Es ist wirklich Lange her seit wir uns gesehen haben! Hi Wolfgang! It is really a long time since we've seen each other. (Jim, the crazy American that was at all of the early TI Treffen). Quote Link to comment Share on other sites More sharing options...
wolhess Posted March 25, 2018 Share Posted March 25, 2018 Hi Ksarul, I can not remember a TI meeting but it's a very interesting hobby with the TI99. Now I am urgently waiting for the next F18A cards. Currently Im learning new programming XB and assembler. Quote Link to comment Share on other sites More sharing options...
sparkdrummer Posted March 25, 2018 Share Posted March 25, 2018 (edited) VOL1.dsk VOL2.dsk VOL3.dsk VOL4.dsk VOL5.dsk VOL6.dsk VOL7.dsk VOL8.dsk VOL9.dsk For these to work properly on your nanoPEB they must be installed as shown VOL1 thru VOL9. VOL1 is my system disk and BOOT loads the disk selections. Once you have made a selection from BOOT, The system will mount the proper VOL and execute the LOAD file contained therein. once finished playing, the system will go back to VOL1 in dsk slot 1. I think it works great! Edited March 25, 2018 by sparkdrummer 6 Quote Link to comment Share on other sites More sharing options...
wolhess Posted March 25, 2018 Share Posted March 25, 2018 VOL1.dsk VOL2.dsk VOL3.dsk VOL4.dsk VOL5.dsk VOL6.dsk VOL7.dsk VOL8.dsk VOL9.dsk For these to work properly on your nanoPEB they must be installed as shown VOL1 thru VOL9. VOL1 is my system disk and BOOT loads the disk selections. Once you have made a selection from BOOT, The system will mount the proper VOL and execute the LOAD file contained therein. once finished playing, the system will go back to VOL1 in dsk slot 1. I think it works great! Thank you very much. This is what I want. I will have a deeper look to the BOOT Routine to make my own menue. Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted March 25, 2018 Share Posted March 25, 2018 (edited) VOL1.dsk VOL2.dsk VOL3.dsk VOL4.dsk VOL5.dsk VOL6.dsk VOL7.dsk VOL8.dsk VOL9.dsk I no longer have a Nano-PEB, but I wonder how many man-hours it took to setup and arrange all that? Pretty impressive bit of work there Sparky! This is such an awesome post that I also decided to link your post from my blog entry in the Nano-PEB. Edited March 25, 2018 by --- Ω --- Quote Link to comment Share on other sites More sharing options...
sparkdrummer Posted March 25, 2018 Share Posted March 25, 2018 it ain't nothing but a thang. I have been and will always be a user. I believe with the advent of XMOUNT a user could set up BOOT to bring in an endless stream of menus using [ (GET) and ] (PUT) to increase the productivity of our little 'puter. I already use those two things on my main system for PagePro and artwork (MENU_ART), Word processing (MENU_WP), XB utility (MENU_XBU), etc. Using these two things makes the nanoPEB much more powerful and useful. 3 Quote Link to comment Share on other sites More sharing options...
globeron Posted June 30, 2019 Share Posted June 30, 2019 I am having issues to get the Mechatronic 80 Column card to work with the NanoPeb (both individually work all okay when I test it on another system. Also I checked different type of CRU settings). I can open TI-Basic (but have a blank screen, the button the Mechatronic 80 does not work with NanoPeb inserted, without nanopeb it works to get the TI-Basic screen. I guess something todo with the graphic mode. I can run a program you can see the screen go green) Extended Basic - same problem In Disk Utilities, I can only list DSK2 and DSK3, but it hangs on DSK1 Video: Does someone know what the 2x jumpers do on the NanoPeb? https://www.nanopeb.com/downloads/nanoPEB/docs/nanoPEB-SIO_V1.pdf I indicated the jumpers here in yellow (I only have the top jumper on my NanoPeb, but it seems to work normally) Quote Link to comment Share on other sites More sharing options...
Tursi Posted July 1, 2019 Share Posted July 1, 2019 They are probably labelled on the back of the Compact Flash adapter board. JP1 should be the mast/slave select, and JP2 should be the 5v/3.3v select. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted July 2, 2019 Share Posted July 2, 2019 On 6/30/2019 at 5:02 AM, globeron said: I am having issues to get the Mechatronic 80 Column card to work with the NanoPeb (both individually work all okay when I test it on another system. Also I checked different type of CRU settings). I can open TI-Basic (but have a blank screen, the button the Mechatronic 80 does not work with NanoPeb inserted, without nanopeb it works to get the TI-Basic screen. I guess something todo with the graphic mode. I can run a program you can see the screen go green) Extended Basic - same problem In Disk Utilities, I can only list DSK2 and DSK3, but it hangs on DSK1 Video: Does someone know what the 2x jumpers do on the NanoPeb? https://www.nanopeb.com/downloads/nanoPEB/docs/nanoPEB-SIO_V1.pdf I indicated the jumpers here in yellow (I only have the top jumper on my NanoPeb, but it seems to work normally) they don't do anything. don't change any settings if you want your nanopeb to function.. likely the DSR is the compatibility issue, and you will need to discuss it with the manufacturer.. http://nanopeb.com is his website. pretty much nobody else can help you as he hasn't released any information to the community.. when i had the f18a issue (where the f18a reset vdp ram AFTER the nanoPEB had used it for something, because it's a smidge slower to reset than the 9918a..) i had to contact him and he fixed his DSR to delay a few more milliseconds to wait for the f18a to do it's thing first. Greg Greg Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 9, 2019 Share Posted July 9, 2019 I still need to have one of my NANOs fixed. I separated the flash card board and tried it with another NANO and it was fine, but the other part of the NANO chkd out bad. It went South after connecting to a speech synth...so I learned to not do that again as I have 2 that work perfect. I need to see if he'd fix the one bad one.. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted July 9, 2019 Share Posted July 9, 2019 8 minutes ago, GDMike said: I still need to have one of my NANOs fixed. I separated the flash card board and tried it with another NANO and it was fine, but the other part of the NANO chkd out bad. It went South after connecting to a speech synth...so I learned to not do that again as I have 2 that work perfect. I need to see if he'd fix the one bad one.. sounds like you should also check that speech synth for voltage on pins that arent supposed to have voltage.. Greg 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 9, 2019 Share Posted July 9, 2019 I put it away, but I did use it to see if it would work when I got it and it worked in xb and forth. I haven't tried it anywhere else...now I'm synth shocked...(don't want to use any around anything)..lol I guess I could chk voltage to verify the ss. But still, I ain't connecting to NPEB! But good idea Greg. Thx Quote Link to comment Share on other sites More sharing options...
