+acadiel Posted May 18, 2018 Share Posted May 18, 2018 I’m all setup. Now have to find time to actually use it. Sent from my iPad using Tapatalk 3 Quote Link to comment Share on other sites More sharing options...
Casey Posted May 18, 2018 Share Posted May 18, 2018 Just got mine set up today also. Very excited to explore it this weekend! 2 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted May 19, 2018 Author Share Posted May 19, 2018 For those who don't like to type, there is an easier way to load TIPI network programs on the TI. You can use a program like BOOT, or the 9640 Menu System. When you configure the path, instead of something like DSK1.PROGNAME, you type in URI1.PROGNAME then save the update. Of course this requires you to go into your TIPICFG and make the appropriate change... Now when you load TIPI stuff, it'll feel like you are loading it right off your own system, it's essentially 'transparent'. It works with every program listed (so far) in << GREG'S NEW THREAD >> for TIPI enabled software. Have I ever mentioned that I LOVE my TIPI? Oh yeah... if you load stuff THIS WAY, you'll always be using the latest and greatest version. 1 Quote Link to comment Share on other sites More sharing options...
+acadiel Posted May 20, 2018 Share Posted May 20, 2018 A couple suggestions so far: In the editing program: 1) Put stars for the password after you type it [emoji4] 2) When I tried to type a SSID with a space, it didn’t like it. When I tried to go correct it afterward, the editing acted somewhat strange (FCTN 1, 2, 3, S, D) Hardware hookup: 3) Key the eight pin cable if we can Quote Link to comment Share on other sites More sharing options...
Casey Posted May 20, 2018 Share Posted May 20, 2018 I had the issue with the spaces in SSID also. It accepted them as input but everything after the first space disappeared (though if you positioned the cursor over the characters after the space, they would blink). I ended up changed my SSID to remove the spaces to solve that problem. Otherwise I really didn't have much trouble getting up and running. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted May 20, 2018 Share Posted May 20, 2018 A couple suggestions so far: In the editing program: 1) Put stars for the password after you type it [emoji4] 2) When I tried to type a SSID with a space, it didn’t like it. When I tried to go correct it afterward, the editing acted somewhat strange (FCTN 1, 2, 3, S, D) Hardware hookup: 3) Key the eight pin cable if we can 1 then you couldn't verify the PW is correct. Maybe a toggle 2 the editor is fixed in git waiting for Matt to push an update 3 I'm thinking about a label with obvious orientation as you can't key either side Sent from my LG-H872 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted May 21, 2018 Author Share Posted May 21, 2018 (edited) @JediMatt42 or @ElectricLab I'm wondering, would it be possible to get ALLOW "RemindMe!" to save & load it's data file over MYTI99.COM using the URI path method? If so, it would be a great way for everyone to schedule online Chatti sessions, Chess games as well as other games with one shared community calendar. If not, does any know of a URL and or site we might be able to use for that purpose? Edited May 21, 2018 by --- Ω --- Quote Link to comment Share on other sites More sharing options...
+acadiel Posted May 21, 2018 Share Posted May 21, 2018 1 then you couldn't verify the PW is correct. Maybe a toggle 2 the editor is fixed in git waiting for Matt to push an update 3 I'm thinking about a label with obvious orientation as you can't key either side Sent from my LG-H872 using Tapatalk For #3, you can get a keyed cable like this https://www.ebay.com/itm/10Pcs-IDC-10Pin-Hard-Drive-Data-Extension-Wire-Flat-Ribbon-Cable-Connector-50cm/171911897420?hash=item2806bf614c:g:ZswAAOSwgQ9V4aHpand just make sure you mark both sides Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted May 21, 2018 Author Share Posted May 21, 2018 For those who do not like cords sticking out all over the place, << THESE 90o ADAPTERS >> might interest you for your TIPI's RPi. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted May 21, 2018 Share Posted May 21, 2018 If your cable is longer than the one included you may not see the same performance and we will tell you to go back to the included cable to fix it. For #3, you can get a keyed cable like this https://www.ebay.com/itm/10Pcs-IDC-10Pin-Hard-Drive-Data-Extension-Wire-Flat-Ribbon-Cable-Connector-50cm/171911897420?hash=item2806bf614c:g:ZswAAOSwgQ9V4aHpand just make sure you mark both sides Sent from my LG-H872 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+acadiel Posted May 21, 2018 Share Posted May 21, 2018 If your cable is longer than the one included you may not see the same performance and we will tell you to go back to the included cable to fix it. Sent from my LG-H872 using Tapatalk There are shorter ones https://www.ebay.com/itm/10-Pin-2x5-Female-to-Female-2-54mm-Pitch-10-wire-IDC-Flat-Ribbon-Cable/292106612325?hash=item4402e92e65:m:mvzcU2hayZjCIOibRoLPv3w Quote Link to comment Share on other sites More sharing options...
+acadiel Posted May 25, 2018 Share Posted May 25, 2018 Man you yahoos need to get online 4 Quote Link to comment Share on other sites More sharing options...
ElectricLab Posted May 25, 2018 Share Posted May 25, 2018 I'll definitely be on later tonight Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted May 25, 2018 Author Share Posted May 25, 2018 Me too! Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted May 26, 2018 Author Share Posted May 26, 2018 Extended BASIC DIRECTORY for TIPI (CUT & PASTE) 10 CALL CLEAR 20 DIM TYP$(5) 30 TYP$(1)="DIS/FIX" 40 TYP$(2)="DIS/VAR" 50 TYP$(3)="INT/FIX" 60 TYP$(4)="INT/VAR" 70 TYP$(5)="PROGRAM" 80 INPUT "Directory Disk (1-3)?":A 90 CALL CLEAR 100 A=INT(A) 110 IF A<1 THEN 80 120 IF A>3 THEN 80 130 OPEN #1:"DSK"&STR$(A)&".",INPUT ,RELATIVE,INTERNAL 140 INPUT #1:A$,J,J,K 150 OPEN #2:"PI.CLOCK",INPUT 160 INPUT #2:CLK$ 170 CLOSE #2 180 PRINT "Disk Number: ";STR$(A);:"Disk/Folder: ";A$: 190 PRINT 200 PRINT CLK$ 210 PRINT :"FILENAME SIZE TYPE P":"__________ ______ ________ _" 220 FOR LOOP=1 TO 127 230 INPUT #1:A$,A,J,K 240 IF LEN(A$)=0 THEN 320 250 PRINT :A$;TAB(11);J*256;TAB(19);TYP$(ABS(A)); 260 IF ABS(A)=5 THEN 290 270 B$=" "&STR$(K) 280 PRINT SEG$(B$,LEN(B$)-2,3); 290 IF A>0 THEN 310 300 PRINT TAB(28);"P"; 310 NEXT LOOP 320 CLOSE #1 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted May 28, 2018 Share Posted May 28, 2018 To add support for including directories, you should increase the size of the TYP$ array by one, and set type 6 to "DIR" Quote Link to comment Share on other sites More sharing options...
jjh76 Posted May 28, 2018 Share Posted May 28, 2018 when loading the telnet program, is there a way to make it so that you don't have to setup the backspace key every time? Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted May 28, 2018 Author Share Posted May 28, 2018 To add support for including directories, you should increase the size of the TYP$ array by one, and set type 6 to "DIR" You also have to change line 120 to "IF A>4 THEN 80" so you can directory the TIPI root directory, but if you do that, you get BAD VALUE in 280 without changing line 260 to "IF ABS (A)=6 THEN 290 " and then it works until it hit's a PROGRAM file and promptly crashes with another BAD VALUE in 280. Quote Link to comment Share on other sites More sharing options...
Casey Posted May 28, 2018 Share Posted May 28, 2018 (edited) when loading the telnet program, is there a way to make it so that you don't have to setup the backspace key every time? Yes. Add this line to your .profile file: stty erase ^H To do this directly from the TI: Telnet to the raspberry pi, and login as the tipi user. Copy the .profile file to a backup: cp .profile .profile_orig Add the line to your .profile: echo 'stty erase ^H' >> .profile Log out and back in again and it should be effective. Verify that the file was updated: cat .profile Type the ^H in the echo statement as 2 separate characters and it will still work. Edited May 28, 2018 by Casey Quote Link to comment Share on other sites More sharing options...
jjh76 Posted May 28, 2018 Share Posted May 28, 2018 got it, ty Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted May 28, 2018 Share Posted May 28, 2018 There is a better fix: sudo usermod -s /bin/bash tipi Backspace works correctly without the stty command, and ctrl-i is tab, so tab completion works. I intend to make this fix to the stock image and update scripts. -M@ Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted May 30, 2018 Author Share Posted May 30, 2018 Got my old black & silver wireless mouse working with TI-Artist today! 3 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted July 3, 2018 Author Share Posted July 3, 2018 Man you yahoos need to get online Agreed! To that end, a "Community Calendar" program written that could save and load data just like Chatti or SNEK would allow people to notify the TIPI community of events or setup meeting times in advance. For instance, I plan to spend quite a bit of time in my den on the 4th doing video work, so Chatti will be on... FOR HOURS! I would welcome a chat with a member or two to break up the tedium. Quote Link to comment Share on other sites More sharing options...
RXB Posted July 3, 2018 Share Posted July 3, 2018 (edited) Extended BASIC DIRECTORY for TIPI (CUT & PASTE) 10 CALL CLEAR 20 DIM TYP$(5) 30 TYP$(1)="DIS/FIX" 40 TYP$(2)="DIS/VAR" 50 TYP$(3)="INT/FIX" 60 TYP$(4)="INT/VAR" 70 TYP$(5)="PROGRAM" 80 INPUT "Directory Disk (1-3)?":A 90 CALL CLEAR 100 A=INT(A) 110 IF A<1 THEN 80 120 IF A>3 THEN 80 130 OPEN #1:"DSK"&STR$(A)&".",INPUT ,RELATIVE,INTERNAL 140 INPUT #1:A$,J,J,K 150 OPEN #2:"PI.CLOCK",INPUT 160 INPUT #2:CLK$ 170 CLOSE #2 180 PRINT "Disk Number: ";STR$(A);:"Disk/Folder: ";A$: 190 PRINT 200 PRINT CLK$ 210 PRINT :"FILENAME SIZE TYPE P":"__________ ______ ________ _" 220 FOR LOOP=1 TO 127 230 INPUT #1:A$,A,J,K 240 IF LEN(A$)=0 THEN 320 250 PRINT :A$;TAB(11);J*256;TAB(19);TYP$(ABS(A)); 260 IF ABS(A)=5 THEN 290 270 B$=" "&STR$(K) 280 PRINT SEG$(B$,LEN(B$)-2,3); 290 IF A>0 THEN 310 300 PRINT TAB(28);"P"; 310 NEXT LOOP 320 CLOSE #1 Using RXB has CALL CAT(1) and you can use space bar to pause the listing. Also RXB does Directories already. CALL CAT("WDS.MYXBPGMS.GAMES1.") Edited July 3, 2018 by RXB Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted July 3, 2018 Share Posted July 3, 2018 Using RXB has CALL CAT(1) and you can use space bar to pause the listing. Also RXB does Directories already. CALL CAT("WDS.MYXBPGMS.GAMES1.") Rxb2015 crashes if the directory has a large number of files. TIPI has no limit Sent from my LG-H872 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
