jedimatt42
TIPI Usage and Support
Downloaded it from matts download page, going to try it now.
It says its v 1.3 , i am not running the burn in test.
So far so good.
... " Pass >0001"
... "all 32k passed"
Edited by jrhodes
So far so good.
... " Pass >0001"
So if it doesn't say Sams detected there's an issue with the console connector
Sent from my LM-V600 using Tapatalk
Hmmm.
Took the speech off, took off the sams and tipi sidecar, opened it up, nothing looks out of place there.
Put it all back together.
CALL TIPI from RXB works ok now.
So does RUN TIPI"..." and OLD TIPI.
Loose connection i guess. (?)
The memtest definitely does not say anything about sams detected.
From RXB, i can do CALL AMSINIT and SIZE, it shows the expected results.
Have not tried running anything sams specific like "in the dark" yet though.
1 hour ago, jrhodes said:
Just tried the disk version of the megademo and picked 512k version, its working.
Where did you get the v1.5 memtest?
The one on https://www.jedimatt42.com/downloads/32kexptest.zip
Only seems to be v1.3
Oops, I should fix that link...
Does the megademo run from TIPI? That would be good news, it didn't last time I tried it.
Yes, tipi + sidecar sams + disk based megademo = sams version worked.
Did not let the whole thing run, but it booted. Watched the first minute or so before i killed it and went back to XB.
Edited by jrhodes
Last time I updated to the new image (buster) on RPI 3B+
(I think I turned it 1x off without proper shutdown).
now I cannot do CALL TIPI.
(TIPI is on >1000)
* but I can reach it via Wi-Fi and can see the files and directories,
   (and I can ssh into it)
* tipi.log does not exist (I now created a tipi.log file)
*  but get all these errors
     * "settings" and "RPI configuration" does not do anything
    * "about" does not work
    * daemon shows errors
TIPI-About.docx
TIPI-Daemon.docx
Is there a way to fix this (or completely re-image and drag and drop the files again?)
Hi Globeron,
in such cases I always created a fresh SD card. Everything else just brings strange problems.
Hope you are doing well.
Wolfgang
3 minutes ago, Vorticon said:
Quick question: Do I set up backspace in telnet?
Hi Vorticon,
in the tipi Telnet the backspace is working without any configuration.
If I use the PC Telnet client also, but in putty I configured Backspace to ctrl+H.
1 minute ago, wolhess said:
Hi Vorticon,
Do you use FCTN-9 or the back arrow?
17 minutes ago, wolhess said:
Hi Globeron,
Wolfgang
Hi Wolfgang!  Good to hear from you!
I will try to create a fresh SD card in that case, I thought there was maybe an easy script to use.
(I still have my other SD-card of the older Raspbian version 1.6x ).
Today I had some problems with my BBS system to write a message. After I made a fresh SD card and copied all the files back the BBS works fine also with long messages. The problems comes only when I had a power loss without doing a shutdown.
What I made sure of was this.
Prepare a good backup/restore strategy.
My ti- on TIpi, docs file structure are backed up daily to my windows share backup folders.
Then onto tape, yup an LTO tape daily, along with other data.
After you design a bootable SD card for TIpi rasberry pi, make sure to backup a good dated copy.
You should be back to operation within an hour of any crash, unless a hardware fault exists.
