Omega-TI #1151 Posted September 21, 2020 1 hour ago, arcadeshopper said: When did you report it? Sent from my LM-V600 using Tapatalk I mentioned it to Jedimatt42 in a PM a while back. He has the issue referenced on his TIPI related site. 1 Quote Share this post Link to post Share on other sites
jedimatt42 #1152 Posted September 22, 2020 I am aware. Just didn't perceive it as a priority.. more of a novelty feature to me. In diagnosing it just now, it looks like the conversion tool didn't compile during one of my image creations... hopefully just something I forgot to do/document Quote Share this post Link to post Share on other sites
jedimatt42 #1153 Posted September 22, 2020 Uh, yep, I cloned the source, but the installation script doesn't build it if the 'directory' is there, instead of checking for the executable. So I'll need to fix the update script... and build new base images. In the mean time, you can ssh into the PI as user tipi and run: sudo /home/tipi/tipi/setup/printing_setup.sh After that, your PI.PIO printing pleasantries should proceed to produce. No reboot required. This will take a while on slower devices. There are some 80-ish 3rd party packages required that it will fetch and download, and then compile the epson converter. I will craft the update fix in a way that this will not repeat if you have done it already. 2 Quote Share this post Link to post Share on other sites
Vorticon #1154 Posted September 22, 2020 4 hours ago, jedimatt42 said: I am aware. Just didn't perceive it as a priority.. more of a novelty feature to me. In diagnosing it just now, it looks like the conversion tool didn't compile during one of my image creations... hopefully just something I forgot to do/document Actually being able to print to the TIPI is super useful when developing programs on the TI itself. I will definitely be using that feature quite a bit. Quote Share this post Link to post Share on other sites
Omega-TI #1155 Posted September 22, 2020 1 hour ago, Vorticon said: Actually being able to print to the TIPI is super useful when developing programs on the TI itself. I will definitely be using that feature quite a bit. I prefer the TIPI/PDF method over the TI99Dir method myself, but have been using that method until the fix is in. 1 Quote Share this post Link to post Share on other sites
dgrissom #1156 Posted September 22, 2020 7 hours ago, jedimatt42 said: Uh, yep, I cloned the source, but the installation script doesn't build it if the 'directory' is there, instead of checking for the executable. So I'll need to fix the update script... and build new base images. In the mean time, you can ssh into the PI as user tipi and run: sudo /home/tipi/tipi/setup/printing_setup.sh After that, your PI.PIO printing pleasantries should proceed to produce. No reboot required. This will take a while on slower devices. There are some 80-ish 3rd party packages required that it will fetch and download, and then compile the epson converter. I will craft the update fix in a way that this will not repeat if you have done it already. It worked. It took a couple of times as I had an internet "brown out" in the middle of the first install. It's still slow to print (probably the pi zero). However, it works well! Thanks! Quote Share this post Link to post Share on other sites
Omega-TI #1157 Posted September 22, 2020 14 minutes ago, dgrissom said: It worked. It took a couple of times as I had an internet "brown out" in the middle of the first install. It's still slow to print (probably the pi zero). However, it works well! Thanks! Yessssss! Happy days are here again! My test print... Quote Share this post Link to post Share on other sites
jedimatt42 #1158 Posted September 22, 2020 If it is BASIC that you are messing with, you can open the source files in the TIPI browser UI. Or, you can use a properly named PC text file and just let the TIPI transform it to BASIC when loading. This takes discipline though, which can be remarkably hard in the face of 35 year old habits. Quote Share this post Link to post Share on other sites
Omega-TI #1159 Posted September 22, 2020 2 hours ago, jedimatt42 said: If it is BASIC that you are messing with, you can open the source files in the TIPI browser UI. Yeah, I've done that for small alterations here and there, but like you say, "old habits". I prefer doing my programming on the TI for nostalgic reasons, but have also been known to use Classic 99 since it can share the same files over the network with TIPI. 1 Quote Share this post Link to post Share on other sites
Vorticon #1160 Posted September 22, 2020 1 hour ago, Omega-TI said: Yeah, I've done that for small alterations here and there, but like you say, "old habits". I prefer doing my programming on the TI for nostalgic reasons, but have also been known to use Classic 99 since it can share the same files over the network with TIPI. Did not think of doing that! Pretty nifty and saves the trouble of transferring the files to the TI subsequently. Quote Share this post Link to post Share on other sites
ElectricLab #1161 Posted September 25, 2020 On 9/18/2020 at 8:58 AM, Vorticon said: Nope. That's already set to Yes. It's not it. Are you able to log in to myti99.com? If you're not, the scores won't be read or written. Quote Share this post Link to post Share on other sites
Vorticon #1162 Posted September 25, 2020 1 hour ago, ElectricLab said: Are you able to log in to myti99.com? If you're not, the scores won't be read or written. I am able to log in, so that's not the issue. Also there is a problem with the chess program display. It just shows some lines but nothing else. Can anyone else here try these 2 programs and report back? Perhaps it's local to me only... Quote Share this post Link to post Share on other sites
+arcadeshopper #1163 Posted September 25, 2020 Sounds like intermittent network issuesSent from my LM-V600 using Tapatalk 1 Quote Share this post Link to post Share on other sites
dgrissom #1164 Posted September 25, 2020 1 hour ago, Vorticon said: I am able to log in, so that's not the issue. Also there is a problem with the chess program display. It just shows some lines but nothing else. Can anyone else here try these 2 programs and report back? Perhaps it's local to me only... I just logged in. (Took me a while as I had to remember my password - Silver hair moment. I tested the Chess program. The screen looked OK. DG 2 Quote Share this post Link to post Share on other sites
Omega-TI #1165 Posted September 25, 2020 Password? Who needs a password? 1 Quote Share this post Link to post Share on other sites
+J-Data #1166 Posted September 26, 2020 17 hours ago, Vorticon said: Can anyone else here try these 2 programs and report back? Perhaps it's local to me only... I saw very similar issue a while back, but it cleared up with a Tipi update, I think to 2.5. Does not seem to be misbehaving for me now. I had to reenter my password but I do get the top score list, and chess is not getting scrambled anymore for me. Quote Share this post Link to post Share on other sites
+arcadeshopper #1167 Posted September 26, 2020 I am able to log in, so that's not the issue. Also there is a problem with the chess program display. It just shows some lines but nothing else. Can anyone else here try these 2 programs and report back? Perhaps it's local to me only...What version comes up in tipicfg?Sent from my LM-V600 using Tapatalk Quote Share this post Link to post Share on other sites
Vorticon #1168 Posted September 27, 2020 20 hours ago, arcadeshopper said: What version comes up in tipicfg? Sent from my LM-V600 using Tapatalk 2.7. That should be latest, correct? This is what chess looks like on my system. Quote Share this post Link to post Share on other sites
jedimatt42 #1169 Posted October 6, 2020 Update ver 2.8 - 2020-10-05 - Fix name handling to strip trailing whitespace when translating to the local unix filename. - Fix encoding type for native files, and suppressed encoding errors while counting lines when generated the CATALOG file. - Fix PI.PIO epson to PDF converter installation check on upgrade If you don't have the PI.PIO fix discussed a few weeks back, then this may look like a pretty slow upgrade. If the print converter is already installed, it'll skip this work. 3 Quote Share this post Link to post Share on other sites
dgrissom #1170 Posted October 6, 2020 17 hours ago, jedimatt42 said: Update ver 2.8 - 2020-10-05 - Fix name handling to strip trailing whitespace when translating to the local unix filename. - Fix encoding type for native files, and suppressed encoding errors while counting lines when generated the CATALOG file. - Fix PI.PIO epson to PDF converter installation check on upgrade If you don't have the PI.PIO fix discussed a few weeks back, then this may look like a pretty slow upgrade. If the print converter is already installed, it'll skip this work. Referenced in the Force Command Thread... But comments on the TIPI 2.8 update. Force command is working better with this version update! Still working through understanding the changes in both TIPI and Force Command 1.0. BTW. I had already done the PI.PIO fix. However, my TIPI update was still spinning at >8 hours. I shut everything down and did another CALL TIPI and restarted the update. It completed in < 5 minutes. After rebooting the version is now 2.8. (It could have been my system configuration with the attached nanoPEB. I pulled it off the chain before the final upgrade.) Quote Share this post Link to post Share on other sites
jedimatt42 #1171 Posted October 7, 2020 26 minutes ago, dgrissom said: Referenced in the Force Command Thread... But comments on the TIPI 2.8 update. Force command is working better with this version update! Still working through understanding the changes in both TIPI and Force Command 1.0. BTW. I had already done the PI.PIO fix. However, my TIPI update was still spinning at >8 hours. I shut everything down and did another CALL TIPI and restarted the update. It completed in < 5 minutes. After rebooting the version is now 2.8. (It could have been my system configuration with the attached nanoPEB. I pulled it off the chain before the final upgrade.) Thanks, I'll test on a PI Zero again sometime this week. The PrinterToPDF software looks like it has productized fixes for my custom changes, so I plan to switch us to his code. The pre-requisites are what take forever, cause it drags in a bunch of XWindows stuff. So at least that should already be there. After that, I'll probably / plan to / build an updated SD Image, so those prerequisites are preinstalled. 1 Quote Share this post Link to post Share on other sites
dgrissom #1172 Posted October 7, 2020 Yep, I wuz fixin' to use the 2.5 image and start over (after backing up my TIPI directories) when the update said done!. I've tested the PI.PIO and its working fine. Thanks again for your efforts in creating this great new hardware and software for our TI's! 1 Quote Share this post Link to post Share on other sites
Vorticon #1173 Posted October 8, 2020 On 9/26/2020 at 8:44 AM, J-Data said: I saw very similar issue a while back, but it cleared up with a Tipi update, I think to 2.5. Does not seem to be misbehaving for me now. I had to reenter my password but I do get the top score list, and chess is not getting scrambled anymore for me. Update 2.8 went without a hitch, but unfortunately I still have the same issues with Chess and Snek. Weird... 1 Quote Share this post Link to post Share on other sites
+arcadeshopper #1174 Posted October 8, 2020 Update 2.8 went without a hitch, but unfortunately I still have the same issues with Chess and Snek. Weird...Can you post your log file when this happens?Sent from my LM-V600 using Tapatalk Quote Share this post Link to post Share on other sites
Keneg #1175 Posted October 16, 2020 The mouse now just goes to the right and stays there unusable. I think this happened when I updated to version 2.8. It used to work. I have tried it with two USB mice. Has anyone else reported this issue? Quote Share this post Link to post Share on other sites
