docbain Posted July 4, 2021 Share Posted July 4, 2021 Is the other 10 pin connector designed for installing Raspberry Pi on the inside of PEB? Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 5, 2021 Author Share Posted July 5, 2021 It is for programming the CPLD. When installing in the PEB, you still use the cable to connect from the rear RPI port to the PI. 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 5, 2021 Share Posted July 5, 2021 The relocatable mouse driver is working great! Here's a quick demo in XB with ALC support. 20210705_150716.mp4 Quick question: is there a way to determine if the system has a TIPI installed from XB? 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 5, 2021 Share Posted July 5, 2021 The relocatable mouse driver is working great! Here's a quick demo in XB with ALC support. 20210705_150716.mp4 Quick question: is there a way to determine if the system has a TIPI installed from XB? 2 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted July 5, 2021 Share Posted July 5, 2021 The relocatable mouse driver is working great! Here's a quick demo in XB with ALC support. 20210705_150716.mp4 Quick question: is there a way to determine if the system has a TIPI installed from XB?Open the tipi. Device?Sent from my LM-V600 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 5, 2021 Share Posted July 5, 2021 31 minutes ago, arcadeshopper said: Open the tipi. Device? Sent from my LM-V600 using Tapatalk That's a little cryptic for me. Can you please clarify? 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted July 5, 2021 Share Posted July 5, 2021 That's a little cryptic for me. Can you please clarify?Ok try this110 OPEN #1:"PI.CLOCK"120 INPUT #1:A$,B$,C$150 PRINT A$,B$,C$160 CLOSE #1If that works you have a tipiSent from my LM-V600 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 5, 2021 Share Posted July 5, 2021 Call tipi Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 5, 2021 Author Share Posted July 5, 2021 42 minutes ago, GDMike said: Call tipi You cannot call DSR subroutines like "CALL TIPI" from within XB programs. They are only available in immediate mode. Doing something like what Arcadeshopper suggested, combined with use of ON ERROR to handle the failure case, should get the job done. I don't know, but wouldn't be surprised if ON ERROR handled io issues from a CALL LOAD as well .. so you could setup the error handler, attempt to load the tipi mouse driver from the TIPI. drive, and if it succeeds, set a hasTipi variable. Which you could then check to skip the CALL LINKs later. Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 5, 2021 Author Share Posted July 5, 2021 2 hours ago, Vorticon said: The relocatable mouse driver is working great! ... I have to admit, that is a bit of a relief. I didn't have a working system at the time, so I only tested the new link routine in Classic99. 2 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 6, 2021 Share Posted July 6, 2021 1 hour ago, jedimatt42 said: You cannot call DSR subroutines like "CALL TIPI" from within XB programs. They are only available in immediate mode. Doing something like what Arcadeshopper suggested, combined with use of ON ERROR to handle the failure case, should get the job done. I don't know, but wouldn't be surprised if ON ERROR handled io issues from a CALL LOAD as well .. so you could setup the error handler, attempt to load the tipi mouse driver from the TIPI. drive, and if it succeeds, set a hasTipi variable. Which you could then check to skip the CALL LINKs later. I'll run a quick test. 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 21, 2021 Share Posted July 21, 2021 Today I apparently lost the ability to access the tipi share on my Win10 machines although I can still access it via Putty. I rebooted the router and the tipi to no avail. I've had no issues with this prior. Any thoughts as to where the problem might lie? Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted July 21, 2021 Share Posted July 21, 2021 Today I apparently lost the ability to access the tipi share on my Win10 machines although I can still access it via Putty. I rebooted the router and the tipi to no avail. I've had no issues with this prior. Any thoughts as to where the problem might lie?Try with the ip some routers drop dns entries after a time.. you can also try restarting the pis connection to the network or the pi itself Sent from my LM-V600 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 21, 2021 Share Posted July 21, 2021 7 hours ago, arcadeshopper said: Try with the ip some routers drop dns entries after a time.. you can also try restarting the pis connection to the network or the pi itself Sent from my LM-V600 using Tapatalk I tried using the IP address with no luck. I don't know what a pis connection is... I can SSH into the PI and also ftp into it using Filezilla. I checked the daemon log and it looks like it's failing to start the Samba server. Isn't that service used for connecting to Windows systems? Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 21, 2021 Share Posted July 21, 2021 Reimage the pi if you're network cable is ok. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 21, 2021 Share Posted July 21, 2021 2 minutes ago, GDMike said: Reimage the pi if you're network cable is ok. Do you mean re-flash the SD card on the PI? 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 21, 2021 Share Posted July 21, 2021 (edited) Yes sir. It's not that terrible to do. Need a card reader, PC or laptop and follow the directions on matt's site. https://github.com/jedimatt42/tipi/wiki/tipipeb-installation Edited July 21, 2021 by GDMike Added the link Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 21, 2021 Share Posted July 21, 2021 22 minutes ago, GDMike said: Yes sir. It's not that terrible to do. Need a card reader, PC or laptop and follow the directions on matt's site. https://github.com/jedimatt42/tipi/wiki/tipipeb-installation Yup I've done it several times before. I'll just have to back up all my tipi folders first. I'll give it a shot. Out of curiosity though, what could have gone wrong on the tipi side? 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 21, 2021 Share Posted July 21, 2021 Power spike comes to mind. But not sure of you just got a cat 5 issue. Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 21, 2021 Share Posted July 21, 2021 Power spike comes to mind. But not sure of you just got a cat 5 issue. Oh, btw. I've had 2 raspberry Pi's die on me. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted July 21, 2021 Share Posted July 21, 2021 Yeah if something's not starting then either troubleshoot that service by looking at the log and finding out why it's not starting or you could reimage the SD card like he is suggesting that seems like hitting a fly with a sledgehammer but if you're not up to troubleshooting a service on Linux it is the easiest solutionSent from my LM-V600 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted July 21, 2021 Share Posted July 21, 2021 3 hours ago, arcadeshopper said: Yeah if something's not starting then either troubleshoot that service by looking at the log and finding out why it's not starting or you could reimage the SD card like he is suggesting that seems like hitting a fly with a sledgehammer but if you're not up to troubleshooting a service on Linux it is the easiest solution Sent from my LM-V600 using Tapatalk As long as I have ftp and SSH access it's no big deal. Is was nice however to have TIPI mapped to a drive letter. Come to think of it, we had an outage about week ago, and I suspect that might have been the culprit. If someone can tell me what's the likely broken service is on the Rpi, and can try to figure it out. As I stated earlier, the daemon log shows the smb service is not starting correctly. No other errors that I can see. Could that be it? We need input from a linux guru here Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 21, 2021 Author Share Posted July 21, 2021 If you are relying on your router's DNS server, I've found in the last couple years that the convention of <hostname>.local works more consistently... why it might change? Microsoft changes what version of windows you are running every week.. Some of their mechanisms used WINS... Last I looked, samba on linux was trying to find and register with WINS (WINS is a deprecated alternative to DNS) anyway, it is possible nothing changes or broke on your PI... but a patch to Windows changed how network file share access looks for hosts. Before reflashing, just try \\tipi.local\TIPI 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 21, 2021 Author Share Posted July 21, 2021 2 minutes ago, Vorticon said: As long as I have ftp and SSH access it's no big deal. Is was nice however to have TIPI mapped to a drive letter. Come to think of it, we had an outage about week ago, and I suspect that might have been the culprit. If someone can tell me what's the likely broken service is on the Rpi, and can try to figure it out. As I stated earlier, the daemon log shows the smb service is not starting correctly. No other errors that I can see. Could that be it? We need input from a linux guru here Oh, I didn't see that you knew smb wasn't starting... this is necessary for the drive... let me get some reference material... Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 21, 2021 Author Share Posted July 21, 2021 TIPI's Samba configuration for /etc/samba/smb.conf: [TIPI] comment=TI-99/4A Files path=/home/tipi/tipi_disk public=no browseable=Yes writeable=Yes only guest=no guest ok=Yes create mask=0644 directory mask=0755 force user=tipi then, you should be able to force some restarting: sudo systemctl reenable smbd sudo systemctl restart smbd If there are issues, they'll be in the /var/log/daemon.log, I believe... you can also sudo systemctl status smbd 3 Quote Link to comment Share on other sites More sharing options...
