Inky #1 Posted June 2, 2003 I've been going back over the forums here, and have heard that a serial mouse WILL work with the ST with a software patch, and then I've hear that you SHOULDn'T use one at ALL with the ST. Which is it? What's the final deal on it? Quote Share this post Link to post Share on other sites
Tyrant #2 Posted June 2, 2003 The ST mouse ports use bus mice (the mouse outputs the optical signals directly instead of having its own microprocessor). Thus if you put a serial mouse into the mouse port on an st it would be a bad thing (Im not sure how bad, in theory it could destroy chips tho hopefully there's some protection against that). However, the ST has a serial port on the back, and with a 9 to 25 way gender changer, and some suitable driver software, you could put a serial mouse in that way. While Im not an ST guru by any stretch of the imagination, I wouldnt expect many games would work using a serial mouse, but most gem applications should be able to handle it, with an apropriate driver loaded. Quote Share this post Link to post Share on other sites
