--- Ω ---
OT: pɐǝɹɥʇ ƃuıdɯnp ;)
Gotchya...
I appreciate the info and the recommendation. It looks like the link you provided at Amazon is even cheaper than ebay for that model.
I don't have the Morningstar CP/M card, Vorticon, but I do have the other one that was commercially produced for the TI: the one from Foundation. That one solved your 40-column CP/M problem by connecting to a monochrome 80-column card in the PEB via serial connection. I only know of two or three other people with one of the cards--and none of them have the 80-column card (and I got mine by accident--I bought a PEB on eBay mostly sight unseen because I didn't recognize one of the visible cards in it and it turned out to have both the CP/M card and the 80-column card in addition to a bunch of normal TI cards).
Nice! The closest I got to true CP/M on the TI was by using a P112 SBC plugged into the PEB for power only. It did not utilize any of the TI resources, but connected to the RS232 card for a serial video display using Term 80 for a pseudo-80 col experience. It worked, but it was more of a cheat than a truly TI CP/M card...
P112 1
P112 2
Note: the MorningStar card didn't use much other than the keyboard, IIRC. It had its own disk controller, its own RS-232, and I think it even had its own monitor output. . .the Foundation used many of the rest of the TI cards though (making it a bit more flexible).
I dunno. If the power supply does not blow, it might rattle the whole PEB apart starting up. :)
...arrived today, for a bit playing around :) SCSI to MFM/RLL-Adapter, maybe Adaptec ACB-4070
EDIT:
Anybody knows about this red/black power-cables on the corner ?
OK. found it, it is for the LED :)
Edited by schmitzi
EDIT:
This is very interesting! Which direction does the adapter work? Does it allow you to use a SCSI drive as an MFM drive? (I hope, I hope, I hope) or is it the reverse? (bad, bad, bad).
If it is the first option, someone with an HFDC could end up with a CF card as their hard drive! (MFM to SCSI to IDE to CF)
Gazoo
No, sorry. It is SCSI to MFM/RLL, so just the other way around.
So, i.e. you can connect a ST251 to a SCSI-controller I think
And, as I have no SCSI-controller for the PEB (looking for a long long time for that),
I now have built up an old PC with P2-300 and 2 ISA-slots, and will play around a bit
with my old adaptec-controllers. Have some of them, maybe AHA1540er ? Have to look.
I also will use that PC for checking my MFM-Controllers (WD1003, 1006 ....)
and my pile of old MFM and RLL-harddisks.
schmitzi
Oh, I never realized that. But now I know why. see the full section-scan below :)
..but I think I will scan the book. but real TI-books first :)
I made an offer: for 1/4 of their new HVAC bid I would not only supply one of my spare 2000s and parts, but I would also deliver it to them.
I'm going to try to take a vacation from the board for a while.
If you need anything, I'll try to check my PM's on the weekends.
L8R
I wonder if this should be considered a hint that I should focus on some TI development this week? :D
There's a problem with that chart. The temperature readings max out at 2 digits. It's really going to be much hotter than that. :-D
