+orpheuswaking #226 Posted July 17, 2018 Got my cart yesterday, now I need to find time to test it out. Does anyone have a good test image? 1 Quote Share this post Link to post Share on other sites
+CharlieChaplin #227 Posted July 18, 2018 (edited) Got my cart yesterday, now I need to find time to test it out. Does anyone have a good test image? If test image means ATR image, then no, tested several of them and most did not work (even many ATR images that do NOT require RAM under the OS did not work). After testing approx. 20-30 ATR images (with OS.XEX in the main dir. and also in the ATR subdir) and only one of them worked, I gave up. Think I will use the AVG-cart mainly for CAR images, XEX files and PDM soundfiles. But there are also some (emulation) files from the SIDE/SIDE-2 cart available for the AVG-cart, like SIDE XEX loader and SIDE SDX. Maybe these can be used to load ATR images also ? Or maybe these can be used to get phaeron`s 50fps / 60fps video player working on the AVG cart ?!? I do not know and have not tested this yet... There are thousands of XEX files available, e.g. at Homesoft's webpage which can be downloaded with one click (download all): http://www.mushca.com/f/atari/index.php?dl=FAI There are also hundreds of CAR images available for download in several AA topics, e.g. here: http://atariage.com/forums/topic/278317-any-done-a-full-cart-to-car-conversion-as-yet/ (posts #8, #14, #15 and #18) http://atariage.com/forums/topic/215811-thecart-new-128mb-flash-cartridge/page-30?do=findComment&comment=3973222 (post #735) or at pigwa: http://ftp.pigwa.net/stuff/collections/RK-DVD/Atari%20800%20Images%20und%20Files/Cartridges%20And%20Roms/ I wrote a small info text about AVG cart, firmware and PDM files in this topic, post #219. Edited July 18, 2018 by CharlieChaplin 1 Quote Share this post Link to post Share on other sites
_The Doctor__ #228 Posted July 21, 2018 (edited) Okay mine are here, I am looking for OS.XEX I am looking for the latest firmware as well. The XEX loader needs a tweak, it have real time clock issues with the AVG cart, if the real time clocks are ICD R-TIME-8 compatible and are inserted or part of an add on board.... the XEX's will fail to load and may mess up the time..... As this doesn't happen with other cartridges (ultimate etc), I pretty certain it can be fixed easily enough. Edited July 21, 2018 by _The Doctor__ Quote Share this post Link to post Share on other sites
AtariGeezer #229 Posted July 21, 2018 (edited) Okay mine are here, I am looking for OS.XEX I am looking for the latest firmware as well. I received 1 today also OS.XEX is in the firmware zip and the latest is at: http://avgcart.tmp.sk/files/atari/avgcart-0013.zip Thank you Tmp :thumbsup: ;-) Edited July 21, 2018 by AtariGeezer Quote Share this post Link to post Share on other sites
_The Doctor__ #230 Posted July 21, 2018 What is the maximum .ATR size offhand? Quote Share this post Link to post Share on other sites
tmp #231 Posted July 22, 2018 (edited) .atr file is currently being loaded into upper half of sram before emulation starts (so it's limited to 512kB), it was just a quick test i started rewriting .atr support to read/write sectors on demand so it should be only limited by 16 bit sector index as for r-type 8 clash, i'm not yet sure what's going on there (if altirra hardware reference manual is correct and it is only mapped to $d5b8-$d5bf), i need to look into that are you sure it only affects .xex files? Edited July 22, 2018 by tmp 1 Quote Share this post Link to post Share on other sites
_The Doctor__ #232 Posted July 22, 2018 (edited) loaded standard .rom works loaded .car up to 1 Mbit works load .xex fail load .atr fail remove rtime8 loaded all including the .xex works load .atr still fails , i will try smaller atr as suggested standard 130XE ntsc. have made sure no other devices connected to sio or pbi Edited July 22, 2018 by _The Doctor__ Quote Share this post Link to post Share on other sites
tmp #233 Posted July 22, 2018 you can attach or pm me some non-working .atr files, although i won't look into them until i rewrite the atr support but test files are always useful (i'm especially interested in those .atr files that do work with unocart but don't with avgcart) (i assume you also tried to hold option key to disable basic when trying those .atr files) 1 Quote Share this post Link to post Share on other sites
_The Doctor__ #234 Posted July 22, 2018 (edited) Yes option held and option not held.... If anyone else has tried running .atr with AVG cart 0013 let me know if you succeeded, and post the working ATR arrows keys navigate the list and highlights choice - when using arrows with control key it will jump to beginning or end of current page or listed directory enter key pressed while on a highlighted slot or pressing letters from left of list chooses xex/rom/cat/atr in that slot backspace backs out of directory listshift-S starts IDE emulation and reboots ? will show firmware versionesc disabled the cart and rebootedshift-ctrl-u Updates firmware Edited July 22, 2018 by _The Doctor__ Quote Share this post Link to post Share on other sites
+Philsan #235 Posted July 22, 2018 AVGCart keys - arrows to navigate the list, with ctrl jump to beginning/end of page/list- backspace is parent dir- enter or letters choose item - ? shows firmware version- esc disables cart and reboots- shift-s enables IDE emulation and reboots- shift-ctrl-u starts update Quote Share this post Link to post Share on other sites
tmp #236 Posted July 22, 2018 i just had to build an unbricker to send out because one cart was bricked during update yesterday (user error if i understand it right), chances of bricking should be minimal if you follow the instructions but just in case, if you have basic soldering skills (solder 5 wires to pcb), you can order these two items (should be under $4 shipped) and build one instead of buying xilinx platform cable (which is quite expensive) or shipping the cart back to me for unbricking (which is probably also not cheap especially from USA) https://www.aliexpress.com/item/ESP8266-ESP-12-ESP12-WeMos-D1-Mini-Module-Wemos-D1-Mini-WiFi-Development-Board-Micro-USB/32688079351.html https://www.aliexpress.com/item/5PCS-1-25mm-Pitch-Male-Connector-Wire-15CM-Long-28AWG-2-3-4-5-6-7/32787305004.html(6P version) i'll provide the instructions and what to flash to esp8266 (via usb) so it can act as unbricker (it will configure fpga so the update procedure can be ran again and flash chip reprogrammed) 7 Quote Share this post Link to post Share on other sites
_The Doctor__ #237 Posted July 24, 2018 (edited) put side on, put pdm player on, loaded pdm file, listened to some tunes... worked perfectly and returned to pdm player screen at songs end... This sounds very nice indeed! PDM converted Music file thread might be a great idea! loaded the avgsdx car and it gave me SDX, and with rtime8 in - typed device=rtime8.sys td on and it worked...time and date displayed... did some directory of drive etc.... though it seemed a little touchy... I wasn't able to launch bobterm1.21 though... X /C BOBTERM yields an unrecoverable screen of garbage... it doesn't seem to talk with a MIO serial port at that point... will try 850 instead at a later time *edit* same results with MIO disconnected tried using 1050 disk drive and 850 interface. same result.... Edited July 24, 2018 by _The Doctor__ Quote Share this post Link to post Share on other sites
+CharlieChaplin #238 Posted July 24, 2018 (edited) put side on, put pdm player on, loaded pdm file, listened to some tunes... worked perfectly and returned to pdm player screen at songs end... This sounds very nice indeed! PDM converted Music file thread might be a great idea! loaded the avgsdx car and it gave me SDX, and with rtime8 in - typed device=rtime8.sys td on and it worked...time and date displayed... did some directory of drive etc.... though it seemed a little touchy... I wasn't able to launch bobterm1.21 though... X /C BOBTERM yields an unrecoverable screen of garbage... it doesn't seem to talk with a MIO serial port at that point... will try 850 instead at a later time Yeah, a seperate topic for PDM files would be nice. Alas, the problem I see, if the converted songs are too popular and can be found easily by Google (e.g. Nothing else matters by Metallica) then the copyright owners and/or record companies may send their lawyers... and some not so nice letters or writings... In the meanwhile I have converted 80 songs into PDM format (mono 44khz and stereo 22khz) for use with FJC's PDM player, some old songs from the 60s and 70s, some songs from the 80s and 90s and very few songs from the 2000s onward... Edited July 24, 2018 by CharlieChaplin 1 Quote Share this post Link to post Share on other sites
_The Doctor__ #239 Posted July 24, 2018 (edited) 130XE with avgcart inserted holding option and turning on computer, will not boot a spartados disk..... drive off... will go into self test like it should and memory test will only make the first 40 blocks last 8 blocks will show as bad... with avgcart inserted not holding option and turning on computer goes into cart menu hold option press esc... will boot a spartados disk... drive off... will go into self test like it should and memory test will show 48 blocks pass with avgcart inserted not holding option and turning on computer goes into cart menu not holding option press esc will boot a spartados disk.... drive off.... will go into self test like it should and memory test will show only 40 blocks pass and last 8 blocks don't show at all! is holding option on power up some special mode? or is it suppose to disable the avgcart, but it hasn't set something up and then conflicts with memory? the mystery unfolds... Edited July 24, 2018 by _The Doctor__ 1 Quote Share this post Link to post Share on other sites
pseudografx #240 Posted July 24, 2018 "Another Versatile Game Cartridge" Quote Share this post Link to post Share on other sites
tmp #241 Posted July 24, 2018 does anyone have a collection of .atr files that are working with unocart? i'd need some test files but i have no means to check the compatibility with unocart thanks Quote Share this post Link to post Share on other sites
_The Doctor__ #242 Posted July 24, 2018 (edited) SS posted a UNO cart collection several times in the threads, he tested the daylights out of it, and it's the best collection I think so far. I'll pm him, I can't seem to do a proper search on the forum here for some reason... http://atariage.com/forums/topic/275796-sd-cart-guidance/?p=3972266 this has everything that works on an UNO, I am of the impression, .ATR are in there too! The AVGCart is excellent, loving the SIDE loader and PDM player.... it's rather good music from my 8 bit! Edited July 24, 2018 by _The Doctor__ 1 Quote Share this post Link to post Share on other sites
Mclaneinc #243 Posted July 24, 2018 (edited) Oops, same link Dr posted but kept the atr list Its not huge to be honest....No dig at SS intended...... I made a set of the ATR's used to make it easier.. From the zip.. Uno atrs.rar Edited July 24, 2018 by Mclaneinc 1 Quote Share this post Link to post Share on other sites
SS #244 Posted July 24, 2018 I will do some digging tonight if I can to see what I can come up with. The number of ATR files on my UNO Cart is honestly kind of small because I put the highest priority on CAR and ROM format, second on XEX, and ATRs were only the things that I had trouble finding elsewhere. I think that I further cleaned it up after that posting too. However, what I can do is put the card from my SIO2SD into the UNO and see what runs. I've got tons more ATRs on that. Then I will copy the ATRs that work into a separate file and will post that. Maybe tonight if I don't pass out too early. 2 Quote Share this post Link to post Share on other sites
Mclaneinc #245 Posted July 24, 2018 Relax good sir, its too damn hot to be rushing anything and anywhere in the world....Even Siberia is having BBQ's Take it easy... 2 Quote Share this post Link to post Share on other sites
_The Doctor__ #246 Posted July 25, 2018 (edited) when playing PDM's I find an SD card of speed rating 10 give or take, a very much more gratifying and satisfying thing as you get to hear it play right away! Edited July 25, 2018 by _The Doctor__ Quote Share this post Link to post Share on other sites
SS #247 Posted July 25, 2018 when playing PDM's I find an SD card of speed rating 10 give or take, a very much more gratifying and satisfying thing as you get to hear it play right away! No kidding. I went on the cheap for my SD cards and used a couple of old, low capacity cards that I had lying around. Normally it's not that big of a deal but when I'm trying to check a lot of files quickly like I am tonight, that slight pause on each game can get a little tedious. Quote Share this post Link to post Share on other sites
SS #248 Posted July 25, 2018 I'm up through letter "L" and have found about 75 ATRs that run on the UNO Cart. I am giving up for today, though. We'll see how far that I can get tomorrow. I'm pretty sure that I will be able to post the lot before the weekend. 4 Quote Share this post Link to post Share on other sites
tmp #249 Posted July 25, 2018 great, thanks! btw, what's the ratio of working/non-working so far? Quote Share this post Link to post Share on other sites
SS #250 Posted July 25, 2018 btw, what's the ratio of working/non-working so far? I'd say 60-65% working. 1 Quote Share this post Link to post Share on other sites
