tmp
AVGCART
Welcome to the forum, you will find the AVG a really great cart and with the cable from Mr Robot the cart becomes even more useful. At the moment the cart is doing stuff people thought not possible or incredibly hard, the SIO side means proper reliable loading of various formats just as you would do from Tape or Disk, now with ATX support and HSIO (OS rom allowing). tmp is working really hard and its paying off.
Good luck with Carina BBS and have a look at Fujinet as well...The old Atari is a lot more modern now :)
I appreciate the welcome and yes, I checked out some of the videos on Fujinet as well.  I suppose it might be able to allow the 130xe to connect to remote TELNET BBSes but I got the impression it was more like a over-the-internet  car/xex/atr/cas loader.  I'll research that more once I learn all I can when/if using the AVG card.
OK, I did something stupid. I got an SIO add-on cable, but did not read closely how to connect it.
It fits, so I connected it to the JTAG port. Plugged that into the SIO port, then powered up the Atari. It didn't boot.
I removed the cable, and now the Atari boots, but the AVGCART now appears to be lifeless. The Atari doesn't see that it's installed.
Can it be reflashed from the Atari? Through that JTAG port? Or... did I just fry it?  Nothing appears burned or smells burned.
Edited by R.Cade
Pull your SD card and see if there is any life.
You only chance is the debricker or jtag progammer... if that fails you toasted something... I suspect toast as voltage may have been at play.
SD card or no SD card doesn't matter. It acts like there is no cart in the slot.
I actually have an Xilinx programmer box, but I would need instructions on making an adapter cable and the programming files.
Edited by R.Cade
unfortunately my guess is that it's dead (it shorted 3.3v rail (which shouldn't be a problem) and put 5V on jtag pins (which could be a problem))
if you have a DMM, measure resistances on that jtag connector (on the solder side (top side with AVGCART label), black probe on the rightmost pin (ground) and measure against the remaining 5 pins), i can compare it with a healthy one (it's non-conclusive but there's not much that can be done remotely at this point)
i'd be very surprised if reflashing would help since flash is a separate chip
On 4/26/2020 at 8:01 AM, tmp said:
6 pin jst connectors, 1.25mm pitch (ebay/aliexpress are full of them, including some crimped cables although majority of them is quite short), the one on pcb is 90deg
molex picoblade should work too
red pcb is the one from the video, black pcb has connector flipped to the other side so pcb fits into unmodified shell, green pcbs have the connector flush with the edge so no need for a flip
white and red are connected together
if you decide to mod the shell, expect pain and tears, those polish shells are pure crap, they warp once you screw them together so nothing lines up with anything anymore, you have been warned
I guess now is a good time to resurface this comment so it isn't lost back on page 32
I don't show any resistance on any of the lines except between 1 and 6, which is about 1.93k ohms. I also checked that there is 3.3v on those lines when the Atari is powered on.
Edited by R.Cade
with no power...
from ground to each pin you had how much resistance?
from the 3.3 rail to each pin you had how much resistance?
from 5 v rail you had how much resistance to each pin
with power on
how much voltage do you see on each pin... using ground for you negative dmm lead
still think you have toast...
with no power...
with power on
There is no measurable resistance from either the leftmost or rightmost to any other pin except each other, which is 1.92k.
All of the lines have 3.3v once it's powered on (respective to the rightmost pin, GND).
Sorry I missed part of your question. Where should I measure from the 5v rail?
Edited by R.Cade
You've already given the answer, all pins are high... that sounds like it's done. @tmp, do you agree?
Edited by _The Doctor__
Thanks very much to tmp's eagle eye! He spotted in the pictures that I must have knocked a diode off the board. By a huge stroke of luck I found it inside the Atari and reattached it, and the AVGCart lives again.  When I was testing it outside the cart shell, I was holding open the flaps on the XL, but at some point I must have let it scrape against the board a little and knocked it off. Even more luck that it didn't pull up the trace or anything.
Now I just need to source the correct socket for the SIO plug...
Edited by R.Cade
  • Like 6
@tmp@R.Cade
Shouldn't have been possible to do so, but as luck would have it, it looks like that diode is from power in...  that may have saved the AVG carts life!
super happy accident that saved a mistake from becoming disaster!
it might have heated up and melted it's own solder then fell off?
so the problem was power,  I was heading towards that in my line of questions... too bad I cut bait a split second too soon. shame on me as you posted the pictures at the same time I posted , I never saw the photos!
still that diode couldn't have been soldered properly, the trace wasn't pulled and the diode came off?  it would be asking for flaky behavior sooner than later.... unless it got hot enough to de-solder itself... or blew off... if you found it intact, I'd test it!
more concerning is the crack on the component slightly above and to the right of the regulator transistors and above the two diode next to those two regulators ... is appears to have a crack in it's lower left area and a divot like it was impacted or blew out...
I don't like it.
There was a connector in the bag with the cable. Pushed into a bit of conductive foam
can't wait for my Robot cables to arrive!
I'll be sure to locate the connectors immediately as this is one heck of a pay attention to everything or this can happen to you example.
I grabbed the bag and looked again and I must have misplaced it. I'll be happy to pay you for another one+postage if you have one. Otherwise I'll have to wait a couple months for the slow boat.
11 hours ago, _The Doctor__ said:
@tmp@R.Cade
I don't like it.
I noticed the white spot on that chip and thought the same thing at first, that it overheated and blew it. That still could have happened, but it is perfectly smooth (not a missing chunk) and seems to just be a white spot. It could still be heat damage. I didn't even notice the crack until you mentioned it and I zoomed in. I'll check that to see if it's real and not a photo anomaly.
Everything seems to be working with the cart, though. What does that chip do?
Edited by R.Cade
This was all just the spares I had from the parts I ordered, I have none left now, sorry. Look around, it has to be there somewhere!
Otherwise @AtariGeezer may have some spares which could save you the long wait.
Does look like a crack going towards pin 1.
I think that chip is the flash which holds the FPGA code.
Missed part of the conversion, is it the connector on the AVG pcb you are missing?
I've got two left left, if you want one I'll be happy to post one over from the UK..Not as fast in internal USA but better than Aliexpress..
Paul.
Paul.
I ordered some longer cables last week and they arrived in 6 days from AliExpress
