tmp
AVGCART
thanks for all the testing you did, i wish i had your patience ;-)
just a quick update:
games that already worked in v9:
Great Escape
Heli in the Caves
MazezaM
Same Game
after some fixes the rest seems to be working now except for Ms. Bulimia
Gangsters and Superfly are .atr
Yes, Gangsters and Superfly XL are ATR, sorry.
So we are getting near perfect compatibility for XEX too.
We cannot say 100% because we would need to test thousand games.
Anyway, if someone find a not working XEX, he can post it here so you can fix firmware.
We now need to investigate the problem of XEX and memory expansions.
Regarding ATR compatibility, if I am not wrong, the file to put in the root is Altirra OS.
Perhaps the original OS could improve compatibility?
you can try this update to see whether it fixes reported xex files and issues on your expanded XL
instructions are in the zip
http://avgcart.tmp.sk/files/atari/avgcart-0010.zip
regarding .atr support, most issues are probably due to game/program either overwriting ram under kernel or reenabling rom and by doing that, removing the patches needed to redirect disk reads to cart
.atr support is just a bonus since it probably can't be done properly via cart slot
Instructions: "Wait until "All OK" is printed and then powercycle your Atari".
"All done" message appeared so I waited "All OK" message but it never appeared. :lol:
64KB
L.E.M. and Same Game still don't work
>128KB results (800XL with U1MB installed):
Alien 8 128 hangs after title screen
Amaurote 128 OK
Booby Jackpot 128 OK
Bomb Jack 320 hangs after title screen
Bosconian 128 hangs after title screen
Cropky 128 hangs after having played one game
Crownland 128 OK
Duszpasterz Jan Rzygon 320 hangs after title screen
E-Type 128 doesn't start
International Karate Enhanced Edition 128 OK
Jack The Nipper 128 OK
Laura 128 OK
Pang 256 OK
Speed up!! 128 OK
Stunt Car Racer 192 OK
Tecno Ninja 128 OK
Treasure Island Dizzy 128 OK
I attach not working games.
Not working.zip
interesting, i've tried all those attached games and they worked for me (although on 800XE)
i will probably have to move u1mb to 800XL
i'm wondering , this version of bomb jack doesn't work either?
Bomb Jack (320 XE).xex
Edited by tmp
I disabled U1MB and installed a 320XL external memory expansion and now all not working games work, Duszpasterz Jan Rzygon and Bomb Jack (2 versions) excluded.
bad apple works, atari blast goes into black screen when new game is started
what firmware do you have in your u1mb? did you try to play with its settings to see if it makes any difference?
BIOS version: 1.22
Plugin: SC 1.00
All options disabled (RAM apart)
Atari Blast! and Bad Apple both load OK here via the SIDE loader on an U1MB machine. There isn't really much trace of U1MB left once the OS starts.
BTW what about AVG2600cart too??? I will donate you with Atari 2600 when you will do adapter and firmware...
There is a SD Card adapter available already made by Electrotrains the Uno-2600
So Electrotrains is selling a800 to a2600 adapte???
No he is selling a Multi Cart for the 2600.
http://atariage.com/forums/topic/274832-unocart-2600-a-diy-sd-multi-cart-for-the-2600
You did not sound like you were talking about a XL/XE to VCS2600 adapter.It seemed like you wanted a new Multi Cart for the VCS off tmp
The cart arrived today
That took longer than I would have expected. Do you have this problem whenever you order?
Hopefully we will see a YouTube video about the AVG Cart sometime soon. :)
Nir, if you read previous posts, you know that CAR and 64KB XEX compatibility is very good.
It remains to do more tests regarding >64KB XEX compability.
WIP: (S)IDE emulation
Fantastic. :) The deadlocked quest for a single device which does everything and works with existing frameworks nears an end. :)
  • Like 6
