tmp #151 Posted June 16, 2018 new firmware update is available http://avgcart.tmp.sk/files/atari/avgcart-0012.zip not much changes from 0010, some compatibility fixes and (S)IDE emulation IDE emulation can be currently enabled by - shift-s will reboot with IDE registers in cctl area enabled and no cart mapped - useful for u1mb machines, internal sdx and side loader should be able to access sd card as if it was IDE device - http://avgcart.tmp.sk/files/atari/side2car.zip- booting this .car will load side loader with emulation enabled, currently probably useful to try stuff like PDM IDE emulation will be improved later, possible making it a toggle switch in selector so any cart or xex will be able to use it (or at least those bankswitching types where there is no collision with SIDE registers) also be sure to backup your sd card if you're going to try the write support thanks to Philsan, Vyper68 and ndary for testing and feedback and to flashjazzcat for valuable info 8 Quote Share this post Link to post Share on other sites
Lastic #152 Posted June 16, 2018 What is the difference between this cartridge and for ex. the UNOcart ? Quote Share this post Link to post Share on other sites
+Philsan #153 Posted June 17, 2018 What is the difference between this cartridge and for ex. the UNOcart ? In Topic for newbies there's a comparison chart. http://atariage.com/forums/topic/176545-topic-for-newbies/ Both cards load XEX and CAR files. UNO cart, more expensive, doesn't load XEX and CAR >128KB (for example Atari Blast!, Bomb Jack, Commando) but loads single disk ATR. AVGCart, less expensive, doesn't load single disk ATR (at the moment it loads them but compatibility is very low). 3 Quote Share this post Link to post Share on other sites
Lastic #154 Posted June 17, 2018 In Topic for newbies there's a comparison chart. http://atariage.com/forums/topic/176545-topic-for-newbies/ Both cards load XEX and CAR files. UNO cart, more expensive, doesn't load XEX and CAR >128KB (for example Atari Blast!, Bomb Jack, Commando) but loads single disk ATR. AVGCart, less expensive, doesn't load single disk ATR (at the moment it loads them but compatibility is very low). <facepalm> didn't realize that the comparison chart had been updated, thanks for the info. Convinced now and waiting on pre-order thread 1 Quote Share this post Link to post Share on other sites
manterola #155 Posted June 17, 2018 What is the maximum rom size it can take? Is it the same or more than the UnoCart? Quote Share this post Link to post Share on other sites
tmp #156 Posted June 17, 2018 max is 1MB, i believe unocart is 128kB Quote Share this post Link to post Share on other sites
+Philsan #157 Posted June 17, 2018 What is the maximum rom size it can take? Is it the same or more than the UnoCart? http://atariage.com/forums/topic/278212-avgcart/?p=4051013 Quote Share this post Link to post Share on other sites
Mathy #158 Posted June 17, 2018 Hello tmp How big is the chance that the next batch will be using the AtariMax cases? Sincerely Mathy Quote Share this post Link to post Share on other sites
tmp #159 Posted June 17, 2018 I can't use something i don't have so zero or close to it. I promised to deliver 30 carts so that's what I'll be working on. Also there is quite some work on firmware pending so those are my current priorities and time is limited. 3 Quote Share this post Link to post Share on other sites
Wrathchild #160 Posted June 17, 2018 Having been experimenting with the UNO Cart, I would be interested when the firmware is likely to become open source in order to learn if similar things will be possible with the AVG Cart?As these demos are written mainly in C, I should hope they will port over easily enough. 1) GameBoy VRAM emulation - using Pokemon village tile-map dump to demonstrate scrolling with soft-sprites 2) Variation on Gameboy-VRAM - Mode 7 style projection 3) Variation on Gameboy-VRAM - Mode 7 style projection with rotation 4) Glenz vectors 15 Quote Share this post Link to post Share on other sites
flashjazzcat #161 Posted June 17, 2018 Let me be the first to say how remarkable that looks. 1 Quote Share this post Link to post Share on other sites
Mathy #162 Posted June 17, 2018 (edited) Hello guys Good news. Steven Tucker just responded. He's willing to sell us his cartridge cases, but we'll have to take the colors he has in stock since he's not going to produce new ones for a while. (But maybe if we buy enough of them.... ) Sincerely Mathy PS me so happy! Edited June 18, 2018 by Mathy 4 Quote Share this post Link to post Share on other sites
commander #163 Posted June 18, 2018 Philsan asked me to do a Label, like I done for The!Card. Here we go. It is designed for the "old" classic Atari 400/800 Cartridges. If you give me the dimensions of your plastic. I can adjust the size. 7 Quote Share this post Link to post Share on other sites
+Philsan #164 Posted June 18, 2018 Thank you very much. Perhaps a COMPUTER PROGRAM or PROGRAMS version could be nice because carts load applications, music, demos... 1 Quote Share this post Link to post Share on other sites
commander #165 Posted June 18, 2018 Thank you very much. Perhaps a COMPUTER PROGRAM or PROGRAMS version could be nice because carts load applications, music, demos... 4 Quote Share this post Link to post Share on other sites
tmp #166 Posted June 18, 2018 enclosure is roughly 90x68mm also there is no joystick support because that's still on todo list one more thing, although i do slap some sticker on the cart that i put together in 5 mins in some drawing program and printed on some sticker paper i had laying around, it's basically "this side up" guide because i'm sure it will peel itself off if you'd stare at it long enough so please no complaints about it as it's not an advertised "feature" 1 Quote Share this post Link to post Share on other sites
commander #167 Posted June 18, 2018 Here is the current update. This is 5,59cm in width 5 Quote Share this post Link to post Share on other sites
+orpheuswaking #168 Posted June 18, 2018 Hello guys Good news. Steven Tucker just responded. He's willing to sell us his cartridge cases, but we'll have to take the colors he has in stock since he's not going to produce new ones for a while. (But maybe if we buy enough of them.... ) Sincerely Mathy PS me so happy! Is he looking to sell bulk to you? Or is he selling them individually? Also did he mention price? Quote Share this post Link to post Share on other sites
Franco Catrin #169 Posted June 18, 2018 Awesome work!!!!! Now waiting for the topic for purchasing them :-) Quote Share this post Link to post Share on other sites
Sam83 #170 Posted June 18, 2018 Awesome work!!!!! Now waiting for the topic for purchasing them :-) I was also waiting the pre-order thread but there was no announcement in this thread and all 30 carts are already gone! http://atariage.com/forums/topic/279849-avgcart-preorder-thread-i/page-2 Quote Share this post Link to post Share on other sites
Mathy #171 Posted June 18, 2018 Hello orpheuswaking Is he looking to sell bulk to you? Or is he selling them individually? Also did he mention price? I asked if he'd sell him a bunch and he said: "Sure". I've asked him how many he's willing to sell, which colors he still has and what the price would be. After he said: "Sure". That was not even 24 hours ago. Sincerely Mathy Quote Share this post Link to post Share on other sites
Level42 #172 Posted June 19, 2018 (edited) Price, check SD card, check CAR and XEX, check ATR, any is a bonus SIDE....awesome.... Updatable firmware through SD card....brilliant !! This looks like a huge winner The last, but most important one for me: does it support a search command like The!cart does ? I absolutely hate having to search for a certain game through menus and lists. Having the possibility to put in the cartridge, smply start typing and it immediately starts looking for the matching files still makes The!cart the winner for me. But the update process simply makes me barely ever add stuff....so SD is brilliant. But I'm always surprised how few people seem to find this an issue, for me it's THE key element of using a multi cart. A menu system is OK like for the Lynx, where the software library is quite limited, but with the gazillion games and apps on the A8..... So please.....if it's not there yet....could it be implemented in the firmware ? [edit] I'm convinced this will be possible, I want one anyway when you're doing a second batch ) [edit2] you are WAYYYYYYY too modest calling this an average cart ! 😂😂 Edited June 19, 2018 by Level42 1 Quote Share this post Link to post Share on other sites
Matej #173 Posted June 20, 2018 TMP so cases worked... 2x for me please!!! I am from Slovakia... Quote Share this post Link to post Share on other sites
tmp #174 Posted June 20, 2018 The last, but most important one for me: does it support a search command like The!cart does ? no search yet but it's one of the features that must be implemented sooner or later no ETA though 1 Quote Share this post Link to post Share on other sites
commander #175 Posted June 20, 2018 @tmp I am a fan of original cases. And I put mine The!Cart in an original Atari 400/800 "Left Cartridge" case. http://wolfsoft.de/wordpress/?p=2663 Please check the dimensions of you AVGCart PCB for me if it fits into an original cart case. The!Cart dimensions: 51mm x 73mm. The 73mm is a little to high. If your dimensions bigger, consider please to redesign the pcb if possible to smaler dimensions.. so it fits into an original cart. Thanks for your great work. It is looking very impressing :-)))) Have Fun Quote Share this post Link to post Share on other sites
