Albert
Wanted: Common 7800 Carts
Greetings,
I am running low on Atari 7800 shells and need to replenish my stock so I can continue to sell Atari 7800 homebrew games. I will pay $4 in AtariAge Store credit plus shipping costs for every good Atari 7800 cartridge you send me I can use. Cartridges must be clean, with no permanent markings, scratches or etchings on the plastic, and for carts with no dust cover, both pegs must be present.
I can also use red-label Atari 2600 carts, as well as later Atari 2600 "gray" label shells. These basically use the same shells as 7800 carts.
Hopefully in the near future I'll be able to use new cart shells.
Thanks in advance for your help!
..Al
  • Like 7
Greetings,
..Al
So like, these guys?
Yes, exactly those. The later copyrights (1986+) also give them away. :)
..Al
Excellent. Will dig through the ol' spares box later and see if I have anything to offer.
Thank you! :)
I have had a few PP2 carts that I have been sitting that I got for a steal. I will go hit my local shops and see if I can find some more "commons" to help with the cause.
I know that I don't need Froggie delayed any longer than it already has been because you don't have "shells" to drop the boards in.
I had never thought to pick up "Red or Gray" label late carts for this option. I know there are some of those around in local shops so I will see if I can get some deals on these.
Al needs shells. I need new homebrews.
PM sent!
I have a nice 8 pound box ready to go!
Awesome, you rock, thanks!
..Al
What would it cost to 3d print cart shells for the 7800? Or would they just be junk anyways?
I thought some guy was going to get a mould made or something along those lines..
Some guy where are you?
Edited by Jinks
Not sure what it would cost, but they would be relatively expensive compared to injection-molded parts, that is, once you get beyond the very pricey molds you need to first purchase for injection molding. Even if the advertised cartridges worked with 7800 boards, I don't like the very coarse (and obviously 3D-printed) nature of the carts, or the four exposed screws on the back side of the case. And I'm curious how smooth the label surface areas are. If they are not very smooth and level, you'll easily notice these imperfections when the labels are applied.
3D printers are getting better, though. I may have to invest in a higher-end printer at some point (such as the Formlabs Form 2) to play around with.
..Al
3D printing is still far too expensive per cubic inch, and it still can't quite match the quality of injection-molded shells (although the newer printers are getting better). It will be a long time yet before 3D printing makes sense cost-wise.
(EDIT: Never mind, Albert beat me to it!)
Anyone ever send out a CAD file for a quote and find out how much it costs? Like thousands?
Edited by Jinks
I'm actually trying one of the 3-D printing cart shells out now... (I'm printing one of those carts - the .STL was available... should be done by midnight) :-/
Just curious on how well they work.
Edited by PacManPlus
Depending on where you go, it can be 5 digits.
Ok, so I printed the case referenced above.
Pro: It will work with a standard 7800 game
Con: because of two of the screw placements, it will not fit the large Atari 7800 boards, or CPUWIZ' versa board... unless you dremel out the top two screw holes.
At some point I will see if I can modify the mold to move those screw holes down.
I stopped by a local game shop this afternoon to see what their loose Atari stock was looking like. Fairly awful: not a single 7800 game, nor any gray label 2600 games. Came across two red label 2600 games: Midnight Magic and Desert Falcon. Told him I would take them both off his hands for $5. He countered at $20. I walked out.
Al, Ill be sending 23 carts that fit your listed criteria within the next 10 days or so!
Awesome, thank you!
