Tpapp54321 #1 Posted May 25, 2018 Okay so I am having trouble getting my ZoomFloppy up and running. Im using it under Windows 10 and to the best of my knowledge I was able to successfully install the driver. However, when running the test I get that theres no connection. Heres some photos that hopefully will help with some troubleshooting: Quote Share this post Link to post Share on other sites
+OLD CS1 #2 Posted May 25, 2018 At least when using the XU1541 You have to configure the cbm* utils using instcbm.exe : C:\CBMXfer>instcbm -hinstcbm Version 0.4.99.97, built on Apr 7 2014 at 22:21:13Usage: instcbm [options] pluginname [plugin-options] [pluginname [plugin-options] ...]Install OpenCBM and one or more plugins on the system, or remove it.pluginname is the name of the plugin to install. Any subsequent option ispassed to the plugin, and it will have a different meaning! See thedescription of each plugin for details.Options: -h, --help display this help and exit -V, --version display version information about OpenCBM -r, --remove remove (uninstall) OpenCBM or a plugin -u, --update update parameters if driver is already installed. -c, --check only check if the installation is ok -n, --nocopy do not copy the driver files into the system directory from an elevated command prompt. This tells the utilities which driver to use. Quote Share this post Link to post Share on other sites
