Sign in to follow this
AMenard
Video improvment on 5 pin C64
Hi,
I'm wondering what are the option for improving the video output on a 5 pin C64 since it lacks a true chroma output via the connector ( it only offer luma and mixed composite).
Is there a way to tap a pure chroma signal on those model?
You might be able to tap directly from the VIC-II with the proper circuitry. I am not certain if there are any expansions which do this.
Oh well, I've got a C128 on the way so no big problem as it will be my main machine anyway (for commodore stuff).
That 5 pins C64 is a recent acquisition (real cheap $$ for once) and is in like new condition, beside the normal oxidation on the tin plated connectors which I cleaned with deoxit. It'll be my spare in case the C128 goes belly up.
And while I wait for the C128 to get here I took the time to fix my 1080. The composite video jack was loose and it was missing the two screw post beside the rgb jack. The speaker is also defect but since I'm using a PC speaker/sub for audio I don't really care.
Edited by AMenard
Ray Carlsen can mod your 5-pin a/v port to an 8-pin port, thus giving you true chroma and luma. He installs the 8-pin port and rewires off the RF modulator. However, you do lose any functionality of the RF modulator.
Truly,
Robert Bernardo
Fresno Commodore User Group - http://www.dickestel.com/fcug.htm
June 9-10 Pacific Commodore Expo NW 2018 - http://www.portcommodore.com/pacommex
August 11-12 Commodore Vegas Expo v14 2018 - http://www.portcommodore.com/commvex
Small sacrifice of the RF modulator. But, you might also consider there is a certain rarity of the 5-pin boards.
Yes, I would definitely keep a 5-pin C64 as a collector's item, in particular if it is in such good condition. If you insist, you are likely able to trade with a later breadbin in similar condition and get some cash inbetween or extra peripherals.
Oh, I'm keeping it as it is. I would have mod it if it was trivial to do so, but I won't start butchering it when I've got a C128 on the way. I'm also trying to get my hand on a PAL C64C...
A couple of years ago, I could have set you up with a very cheap PAL C64C (excluding shipping costs). Nowadays they're still affordable, though not the $10-15 range they used to be.
For me, I am not so much interested in a PAL C64 as a 64G. Dunno why, I just like the look :) They pop up from time-to-time.
