HOME AUTOMATION #351 Posted January 9 4 hours ago, globeron said: This often happens when one is in close proximity to a quantum singularity.🌌 ...don't eat any!☢️ 1 Quote Share this post Link to post Share on other sites
+InsaneMultitasker #352 Posted January 9 7 hours ago, Shift838 said: I decided to purchase a few 20 pin shrouded keyed connectors. Which part # did you use and from where? That's a nice modification 2 Quote Share this post Link to post Share on other sites
Shift838 #353 Posted January 9 3 hours ago, InsaneMultitasker said: Which part # did you use and from where? That's a nice modification i actually bought the shrouded keyed connectors of amazon for $7 for 20 pieces. HERE 1 Quote Share this post Link to post Share on other sites
globeron #354 Posted January 10 13 hours ago, HOME AUTOMATION said: This often happens when one is in close proximity to a quantum singularity.🌌 ...don't eat any!☢️ I reinstalled the HRD3000, removed batteries, etc. then both SWAN and DRAGON (different resolution are okay in MYART). But the problem with EXB80DEMO exists, my gut feel is to do with the GBS8200 (v4) device not be able to sync. properly in this text/graphic mode when in GPL (TIMODE). In MDOS i tried different Mode 40, 60, 90, 80 all working fine when doing a directory listing. Quote Share this post Link to post Share on other sites
+InsaneMultitasker #355 Posted January 10 7 minutes ago, globeron said: But the problem with EXB80DEMO exists, my gut feel is to do with the GBS8200 (v4) device not be able to sync. properly in this text/graphic mode when in GPL (TIMODE). Your XB demo looks as if it is in 26.5 line mode. What version of GPL are you using? The version number will display on the GPL start screen, before the TI press any key screen. When at the OS command prompt type: "MODE 80" "DIR" Then try: "MODE 90" "DIR" Any change in sync? Quote Share this post Link to post Share on other sites
HOME AUTOMATION #356 Posted January 10 GBS8200 (v4) ...Dunno. LTT 10380, LHS 1050, ...I'm your man!🛸 1 hour ago, globeron said: Dragons And Swans... P.S. No offense if you're a big fan of swans or dragons. 1 Quote Share this post Link to post Share on other sites
globeron #357 Posted January 10 3 hours ago, InsaneMultitasker said: Your XB demo looks as if it is in 26.5 line mode. What version of GPL are you using? The version number will display on the GPL start screen, before the TI press any key screen. When at the OS command prompt type: "MODE 80" "DIR" Then try: "MODE 90" "DIR" Any change in sync? Hmm. Are there different GPL versions? I did not know that, maybe that is the issue. Need to figure out where the different software is. GPL,GPM,GPN,GPO. Maybe hijack of @mizapf disk as there it is working. My MDOS is 6.5 In MDOS Mode 40,60,80,90 are all the DIRs okay. Quote Share this post Link to post Share on other sites
globeron #358 Posted January 10 1 hour ago, HOME AUTOMATION said: GBS8200 (v4) ...Dunno. LTT 10380, LHS 1050, ...I'm your man!🛸 Dragons And Swans... P.S. No offense if you're a big fan of swans or dragons. Interesting game. Need to try it out. I am going to change my startup loader 'as it was a Dragon' to get this Geneve 9640 up running till now. Very stable now. Only this latest graphic issue. And was wondering if there is memory issue As my has the upgrade. But I see a different number here in the manual in CHKDSK in bytes free (my total memory is okay) see http://www.mainbyte.com/ti99/geneve/geneve32k.html Quote Share this post Link to post Share on other sites
globeron #359 Posted January 10 (edited) 3 hours ago, InsaneMultitasker said: What version of GPL are you using? The version number will display on the GPL start screen, GPL Interpreter version 6.50 Modified June 30, 1996 (Ignore the errors on the screen, thats fixed after resetting all) Edited January 10 by globeron Quote Share this post Link to post Share on other sites
globeron #360 Posted January 10 I think it is he GBS8200 device having issues with the sync. (I also used the GPL of the MAME). see video it first shows okay for a split second, then it syncs. to the corrupted one. @shift838 can you check EXB80DEMO with your GBS device to see if it works at your side? Otherwise maybe I will try to replace the VDP9938. 20210110_160833.mp4 Quote Share this post Link to post Share on other sites
Shift838 #361 Posted January 10 10 hours ago, globeron said: I think it is he GBS8200 device having issues with the sync. (I also used the GPL of the MAME). see video it first shows okay for a split second, then it syncs. to the corrupted one. @shift838 can you check EXB80DEMO with your GBS device to see if it works at your side? Otherwise maybe I will try to replace the VDP9938 Are you using the standard firmware that came with the GBS control unit or the newer gbscontrol firmware? Quote Share this post Link to post Share on other sites
globeron #362 Posted Thursday at 01:14 PM (edited) On 1/11/2021 at 2:46 AM, Shift838 said: Are you using the standard firmware that came with the GBS control unit or the newer gbscontrol firmware? Confirmed it is a GBS8200 issue. I have the 80 mode working in Extended Basic (on stock firmware). But spent a lot of time upgrading the D1 mini. And trying out, but now i cannot get a stable screen anymore and one in a while loose the signal. Looks like a lot of fine tuning to get it stable again. Will try another GBS board. Edited Thursday at 01:14 PM by globeron Quote Share this post Link to post Share on other sites
