Sapicco
Labels coming off
I've had some labels come off recently too. Get them away from your heating/air vents if possible! Elmer's glue stick works real well, as does Crazy Glue, but be careful with the latter. Applying too much will bleed right through the label. I've also used Elmer's liquid school glue, but it too needs to be handled sparingly. Glue stick seems to be the best method I've tried so far.
Glue sticks or use a hair dryer on Hi to re-melt the old glue (takes a bit but works better). Both work, though the later is better for the stiffer labels
I use craft shop aerosol spray glue. I mask of the entire cart, except label area, with painters tape and then lightly sptay the required areas.
Glue sticks (like for kids crafts not hot melt)
Agreed. A little UHU Purple on a toothpick inserted under the raised portion of the label and then smashed down does the trick nicely.
