+hueyjones70 #1 Posted July 23, 2018 I have an interesting problem with an 800XL. I was running Pole Position and after a collision, my car partially changed colors. The right side turned to light blue and the tires disappeared. After rebooting several times and observing the results it seems that a sharp change in direction such as running off the track and coming back on or a collision with another car or an object will cause the change. I tried switching out the 4050 chip and that had on effect. It occurs whether I am using composite video or luma/chroma. Has anyone else experienced a similar incident or does anyone have any suggestions concerning a fix. Quote Share this post Link to post Share on other sites
_The Doctor__ #2 Posted July 23, 2018 hmmm, did you try other copies, versions of Pole Position... if it were a hardware issue it normally would manifest in other titles and games as well Quote Share this post Link to post Share on other sites
+Nezgar #3 Posted July 23, 2018 I've seen the colours change when the power supply voltage is too low, ie 4.7V to 4.5V. (when I was using an insufficient USB power source). This also causes problems with SIDE2 reading CF cards. Have you checked your PSU voltage under load with system on? I think the car and/or tires in Pole Position might be using PMG, which is generated by GTIA, not ANTIC, so maybe check if the GTIA is bad / swapping the GTIA chip with another machine 2 Quote Share this post Link to post Share on other sites
+DrVenkman #4 Posted July 23, 2018 I think the car and/or tires in Pole Position might be using PMG, which is generated by GTIA, not ANTIC, so maybe check if the GTIA is bad / swapping the GTIA chip with another machine GTIA going flaky was my first thought too, followed by a possible power issue. But I’ve had two GTIA’s fail on me in different machines as well as a bad TIA in a 2600 (similar symptoms) so I’m primed to look for problems there. 2 Quote Share this post Link to post Share on other sites
+tf_hh #5 Posted July 23, 2018 I have an interesting problem with an 800XL. I was running Pole Position and after a collision, my car partially changed colors. The right side turned to light blue and the tires disappeared. After rebooting several times and observing the results it seems that a sharp change in direction such as running off the track and coming back on or a collision with another car or an object will cause the change. I tried switching out the 4050 chip and that had on effect. It occurs whether I am using composite video or luma/chroma. Has anyone else experienced a similar incident or does anyone have any suggestions concerning a fix. I have two GTIAs in my "defects drawer" with problems in collision detection. Both GTIAs will be detected bad by the SuperSALT diagnostic cartridge - you don´t need the external fixture for the GTIA test. One of the GTIAs is also detected bad by SysInfo utility. So first test is SysInfo, then SuperSALT 3 Quote Share this post Link to post Share on other sites
+hueyjones70 #6 Posted July 23, 2018 Thanks for all of the input, I switched out the GTIA and everything is working as it should. 4 Quote Share this post Link to post Share on other sites
+hueyjones70 #7 Posted September 29, 2020 I have a different 800XL with a similar problem. The computer boots, BASIC works. Carts will not boot so I can't run supersalt. Usually when I plug in a cart, I get nothing but a blank screen. On a couple of occasions I got some random characters on the screen. Star Raiders doesn't boot. Quote Share this post Link to post Share on other sites
Sugarland #8 Posted September 30, 2020 What have you tried so far? Reseated the chips yet? Quote Share this post Link to post Share on other sites
+hueyjones70 #9 Posted September 30, 2020 I have reseated the ones that are socketed I am going to try and load a game from disk and if that works I may be able to eliminate a few options. Quote Share this post Link to post Share on other sites
+hueyjones70 #10 Posted September 30, 2020 I can run a disk loaded game so the problem is specific to carts. I have tried 5 different ones. Quote Share this post Link to post Share on other sites
+Nezgar #11 Posted October 1, 2020 Hmm maybe bad contact in the cart port? Use a flashlight and inspect the cartridge port carefully for damaged fingers or debris. If all looks good, douse the contacts on a cartridge card edge with isopropyl alcohol, and quickly/repeatedly insert/remove it in the cartridge port to clean the connectors in the port. Quote Share this post Link to post Share on other sites
+hueyjones70 #12 Posted October 2, 2020 Thanks for the advice, I went one extra step and folded some emery paper and rubbed it up and down in the slot. Now everything works as it should. Quote Share this post Link to post Share on other sites
R0ger #13 Posted October 2, 2020 We were changing GTIA in friends 800XL, and one of the drawer GTIA we put in there did mad stuff with PMGs, so that would be my guess too. Glad to see you solved it. Quote Share this post Link to post Share on other sites
