tf_hh
SRAM-Charger for Indus-GT - interest poll
Thanks!
I'll just edit this one...
What about the Z80 piggyback boards for IDE hard drives? Could we squeeze a 2.5" laptop drive into an Indus? Imagine if an Indus could run a full blown NZ-COM system!!!
Many possibilities.
SIO commands to use a partition of the Indus's HD, data exchange between Atari and NZ-COM system... WordStar running really FAST! Lots of possibilities!
Edited by Kyle22
  • Like 4
Hi,
the SRAM charger boards are ready. Take a look at the final version:
As you can see in the picture, two versions exists. The left one for the genuine Indus GT drive with right-angled connector and the other version with straight connector for the clone drives LDW Super 2000 and CA-2001.
Users of the genuine Indus GT drive just need to open the case, plug the SRAM Charger board in and that´s all. Users of the LDW Super 2000 or CA-2001 must do some solder jobs to make the SRAM Charger board usable. In the manual I will link to Trub´s site with some additional infos.
If you want to place an order, please look about the handling into my catalogue PDF file with all infos.
Click here to read the info PDF
Jurgen
P.S.: The manual isn´t ready today, I will complete it in the next days, so that the manual will be finished before the first parcels received their destination :)
  • Like 8
Hello,
I'd like to buy at least one. I already PM'd you last week. :)
Thank you.
Got mine today :thumbsup: . Looks very nice. Thank you :) .
Thanks for feedback!
Will make the manual ready in the next few days. Heavy workload these weeks at the office, eldest daughter married and much more :)
Hi Jurgen
mine arrived too! - will fit it later today
thanks again
Received my two uniits... PROMPTLY shipped, arriving safely and relatively QUICK (!!!) Well packed, with proper anti-static protection...
Boy, these boards are TINY (!!!) They take almost NO space on the drive, and are installed in a breeze! No contact with either drive's mech. frame or externa cover.
Have been extensively testing one (1) and put the drive through its paces... works like a CHARM!!!!
Now my my two IndusGT are fully upgraded with RamCharger, supporting both Track Buffering, and CP/M !
Cheers!!!
I got mine in the mail today. Is there text file or PDF about usage or installation
I´m working on it. Will be published tomorrow.
Hi,
sorry, again a little later than expected... here are the installation instructions for the SRAM Charger board for the Indus GT and compatible drives:
SRAM_Charger.zip
Jurgen
  • Like 6
I'll post this here...
a) I received my board, installed it, tests show all is good
b) booting CPM, no matter which terminal I use (tt05 from trub, e.com or f.com), once I boot the CPM disk I get the 'Indus CPM 2.2 Rev 1.1, Hit return to continue' prompt but nothing I type does anything....
Am I missing something else? I'm using an Incognito 800, with the programs loaded from SDX.
Thanks!
Thanks!
Did you create your CP/M disks as described here? Sounds like what mine did many years ago befor someone figued out how to repair the first 3 sectors.
http://trub.atari8.info/index.php?ref=indus_cpm_en
Sounds like you didn´t patch the CP/M discs! Look into the manual and links to Trub´s website. Short how-to:
- Copy the needed / wanted CP/M discs using any sector copier to real 5.25" floppy discs
- Boot the CP/M tool from Trub
- Use the repair function to each disc
This procedure must be done at last to files "Indus RAM Charger CPM BIOS" and "Indus RAM Charger CPM Boot".
After running CPMTOOL option 1 I get the drive display counting up to FF and on the screen I get an error 59 notification.
Questions about the CP/M Tool...
I followed the links to Trub's page on CP/M which has the link to the tool. But when I try to download the tool, I just get garbage on the screen -- Foxfire and Chrome both try to open it as some type of text file rather than a downloadable file. (Right click doesn't help.) I see it is an ARC file, and they typically show up as regular downloadable archives with no issue. But this one does. Or perhaps I'm bot understanding this correctly. I presume that the Tool is a Windows executable file?
Can someone help, and if available, attach a copy of a Zipped copy of the tool?
Thanks,
Larry
Thanks,
Larry
no you use the indus drive to make the fixes, if using a PC you need anadisk and an old 5.25 dsdd 360k drive..
right click and find save as..... works on both browers you mentioned for me....
CPMTOOL.ARC
indusrcutil.zip
the rest of the files are all accessible from trub's site as well as others... take your time and wait a second to look down at right click options when trying to download..
Edited by _The Doctor__
