smbaker
My homemade 5200 controller
The jumper is installed, and I double-checked all my solder points, so maybe it is just a bad thumbstick. I'll desolder it tomorrow and try a different thumbstick to see if that fixes it.
Thanks for the help!
@animan99: I just got a 3D printer and printed your case design yesterday, in PETG. A little bit of an issue with nastiness around the supports on the beveled edge (I'm trying a PLA print to see if it looks nicer), but nothing some sanding couldn't clear up. Great design, and thanks for sharing it!
Scott
No problem, I always wanted a replacement joystick for 5200, so your board and my case did the trick.
What printer did you get?
I was able to print w/o supports using PLA. My Gray PLA printed pretty good, but my White PLA needed some sanding to make it look better.
One thing to note is that the fire buttons and the keypad are connected directly to the 5200. The only thing that uses the microcontroller is the analog stick portion of the controller. So anything in the thumbstick, microcontroller, or digital pot could be causing the issue.
One other thing to check is that you programmed the fuses into the microcontroller. One of the fuses sets the clock speed multiplier and perhaps too slow a clock (I have not tried it) could cause an issue.
I ended up getting a Prusa I3 MK3. So far it's been a pretty good experience, I've printed several things.
I might try the case in PLA without supports. In PETG there was quite a bit of stringing, and some deformed layers when I tried it without support material.
Edited by smbaker
The Prusa I3 MK3 is one of the best 3D printers.
Yeah, it came highly recommended to me by several people. So far I'm pretty happy.
Posted a new video today, showing off the 3D case!
Scott
Scott
I just saw your new video, controller looks nice and I like those yellow buttons.
One tip if the case has some gaps. Use a hair dryer to heat up (not too much) the top plastic of the fully assembled controller, then squeeze it tight till it cools down. That should close the small gaps you may have.
I need to get a pair of cases printed! :)
In the meantime, even with just a bare PCB screwed into a wood backing plate, I set a personal best for myself on DEFENDER last night. Thanks again for a great, fun-to-build design, Scott!
(Reflection on the screen is my 1088XEL running on a CRT across the room)
Also - took me a minute to find Scott's new video (on Youtube but not - yet? - linked from his blog). For those who want to see animan99's case design in action:
  • Like 4
I finally got my boards put together and the work perfectly! Thanks Scott!
And thanks to DrVenkman for the step by step instructions on how to program the ATtiny85!!!
-Bobby
I ordered all parts for myself and a friend from Digikey ..
Q: the BOM does not list the two resistors .. are they necessary??
What two resistors? I’ve built two of these and they don’t have any resistors.
It's not hard. The BOM has all the parts on it you need, less the two resistors and 4 capacitors (and sockets, unless you want to solder the ICs in place). The parts for two will come to about $25, per my order a few weeks ago. :)
Perhaps your post on Oct. 19th is where the idea of two resistors came from. I haven't seen a board that requires fixed resistors (ignoring the thumbstick and ignoring the IC).
Ah, yeah. This is what I get for trying to reply on my phone via Tapatalk, without access to my build photos. R1 and R2 are not on the BOM though they are on the schematic (and the pics of the ones I built, d'oh!). They're 10K resistors.
Hope this helps the fellow who asked. :)
i built one of these this morning. works perfectly. amazing job with the boards and micro code.
I've got three 5200s and about a dozen controllers, but only a few controllers work properly. And I've been hesitant to use the working ones.
Ok, It took alot of work, but here it is:
(The round edges are not perfect, because I printed w/o supports to make it faster)
@Amiman99, would you share your tinkercad files?
This reminds me, a friend of mine (research professor of biochemistry at a large, nationally-known local university) runs a 3D printing side business as a hobby. He just picked up a DLP-based resin printer capable of extremely high resolution. He also designed a new shell for the sample board I built for him to use as a model. He's making me some shells (including very high-res printed buttons for the keypad) and once he's satisfied, he'll make them available on his eBay store. Here's a teaser image:
  • Like 5
Looks great, Will he make a case if the joystick is on the right side.
I mentioned that when I met up with him a couple months back for beers and hanging out. He said it shouldn't be a problem. I'll ask him again specifically whenever he's done with the shells he's making for me. This image was his model as of about a week ago - he hasn't updated me on progress since then. He may have had a snag with those buttons. :)
Thank you. Appreciate any updates.
This is sweet and an instabuy for me!
