Kernal #1 Posted August 28, 2018 Can some one give me a link to a cheaper SCART adapter for the VBXE 800xl i am getting from scotland? I would like to get either an scart to VGA or SCART to HDMI either one is fine.. i would prefer VGA cause thats the monitor near the bed.. but I have a bigger tv in the other side of the room with HDMI... I just want to order this so i can get it running when the 800xl gets here from scotland next week.. does any of the walmart ones work so i can just run up to walmart and get one or one from ebay with quick shipping? Quote Share this post Link to post Share on other sites
Kernal #2 Posted August 28, 2018 the hdmi on the other side of the room supports PAL composite so i guess ill go scart to HDMI or SCART to VGA on that.. it has both.. the videocord coming with the computer is a RGB SCART Quote Share this post Link to post Share on other sites
Rybags #3 Posted August 29, 2018 Does you TV have VGA (DE15) ? I've got one of the arcade video converter boards for around 25 bucks and it does the job pretty well. Realistically if you convert the video from VBXE to something inferior first like composite or S-Video then to HDMI, it'll look a whole lot worse than just going to VGA. Quote Share this post Link to post Share on other sites
Kernal #4 Posted August 29, 2018 ok so vga is the reasonable expectation then.. so i will need to go from vxbe output which is rgb/scart to cga to vga using one of those arcade converter boards on ebay?' do u have a link to a good board that goes from rgb (or the din 9 that the vxbe outputs from to vga? i believe this vxbe has a din 9.. i havent gotten it in the mail yet from bob but once it gets in i will know for certain what output this vxbe has. Quote Share this post Link to post Share on other sites
_The Doctor__ #5 Posted August 29, 2018 (edited) ???? what ??? just go from rgb to vga.... less than $3.00 https://www.ebay.com/itm/3-RCA-RGB-Video-Female-To-HD-15-Pin-VGA-Component-Video-Jack-Adapter-New/372111405508?hash=item56a39171c4:g:dfQAAOSw1cNZ6wEi scart to composite and audio 13.00 or less https://www.ebay.com/itm/Scart-to-Audio-Extractor-for-Component-YUV-RGB-Video-Converter-CVS287-CSY-2100/221190880604?hash=item338000fd5c:g:QkIAAMXQMmJRIR0I rgb scart to s-video/composite audio less than $2.00 https://www.ebay.com/itm/Popular-RGB-Scart-to-Composite-3RCA-S-Video-AV-TV-Audio-Adapter-HU/361891633921?epid=528423166&hash=item54426c1b01:g:~TcAAOSwnHZYQbxJ almost any cable or converter can be had from poland or china for less than 20 dollars give or take... Edited August 29, 2018 by _The Doctor__ Quote Share this post Link to post Share on other sites
Frankie #6 Posted August 29, 2018 Using the cable from eBay gives you 15 kHz VGA. You need an upscaler after that for most monitors. Quote Share this post Link to post Share on other sites
_The Doctor__ #7 Posted August 29, 2018 (edited) depends on your monitor, and the polish guys have a switch on theirs to go from 15 to 31 or whatever it is... my atari sc and nec multisyncs do 15 no problems find them polish fellows who make them for the dreamcast etc... send a message for a custom cable... or make your own wire with a china small pcb scaler / freq doubler Edited August 29, 2018 by _The Doctor__ Quote Share this post Link to post Share on other sites
Rybags #8 Posted August 29, 2018 I don't think VBXE has a default? Mine's an early V2 and AFAIK the latest ones are still a case of make your own output plug arrangements. The converter boards go by various names and I imagine there's a mix of quality ones and cheap clones. But mine's a GBS 8200 - that search term alone should bring up plenty. Also try CGA/EGA to VGA and similar. Expect to pay around 20-35 bucks. 1 Quote Share this post Link to post Share on other sites
Kernal #9 Posted September 2, 2018 yeh so its 13 pin din (atari St monitor.) so i should be able to get an atari st to vga cable and then a 15khz upscaler correct? I know best electronics has one.. Quote Share this post Link to post Share on other sites
