Kernal #1 Posted September 12, 2018 Does anyone have a copy of tipconv.jar.. i need it to start making the animations for daleks of skaro.... Much thanks 0-=Rick=-0 Quote Share this post Link to post Share on other sites
devwebcl #2 Posted September 12, 2018 here you go. tipconv-1.0.0.zip Quote Share this post Link to post Share on other sites
+CharlieChaplin #3 Posted September 13, 2018 (edited) Here is a bigger package with Tip-Converter 1.1.1, Tip Animator 2.9 (no double-buffering, min. 64k RAM), Tip-Animator 2xB (double-buffering, min. 128k RAM) and several other useful files. The old Tip-Converter was a little awkward, one had to convert every single frame by hand, not nice if one wants to convert dozens or hundreds of frames. With the newer Tip Converter version it is enough to make one or two test conversions (with a chosen palette and brightness setting, without saving) and if you are satisfied with the result start a batchfile-conversion that will convert hundreds of frames with just one click... Here is what I do normally: 00) make sure that the animation or movie is either in GIF, MOV or AVI format. (If not, convert into one of these formats, using DIVX or XVID for movies is fine) 01) extract all frames as PNG or BMP with e.g. Irfan-View into your Tip-Animator / Tip-Converter folder 02) rename the frames to 0000.png, 0001.png, 0002.png, etc. (or 0000.bmp, 0001.bmp, 0002.bmp, etc.) with an automatic renamer program, e.g. Ant-Renamer 03) resize the frames to 160x100 pixels for a fullscreen A8 animation (or downsize to a smaller resolution e.g. 100x70 pixels and then create a black border / black frame around each frame, so that it has 160x100 pixels again) with e.g. Irfan-View or XnView 04) start the Tip-Converter and do a few test-conversions of some frames (without saving) to find a good palette, brightness, luminance, etc. (if all colour-palettes fail, use greyscale only) 05) when you found a good palette and brightness, start one of the batchfiles (e.g. if you want to use Laoo palette with brightness 2.0, start Laoo_20.bat) 06) when all PNG or BMP frames have been converted into TIP frames, start the TIP-Animator and convert the TIP frames into a TIP animation. Hints: a) If you extract frames from a movie you often end up with thousands of frames, since the Tip-Animator cannot handle so many frames and would never create an animation of them, try to use only every 2nd, 4th, 8th or 16th frame (advantage: the TIP animator may create a working animation then, dis-advantage: the animation might be much too fast or too flickery, even when slowing it down with some delay); b) if there is a lot of frame-drawing in the animation (created with Tip-Animator 2.9), try Tip-Animator 2xB for a better result (does not always work, since the 2xB version requires more RAM) c) if the animation is too fast, try slowing it down with some delay (e.g. delay5, delay7, delay9, etc.) d) if the animation is much too slow, try downsizing the fullscreen 160x100 PNG/BMP frames to a lower size/resolution (e.g. use 100x70 pixels and then create a black border around each frame so it has 160x100 pixels again), this should give more speed e) if the TIP-Animator cannot create a working animation, try moving more stuff into XRAM, by using V4-V9 and/or h96 or h80 (but the size of the animation dictionary is still limited to base RAM and may still create an error and thus a failure)... Good luck! TIP Animator.zip Edited September 13, 2018 by CharlieChaplin Quote Share this post Link to post Share on other sites
Kernal #4 Posted September 13, 2018 (edited) dalek1.xex dalek2.xex dalek3.xex THANK YOU!!! Heres some test animations i did from cinema4d > TipConv > Tipanimator.. exported as jpeg, ran jakub15.bat to rename and output as *.tip then ran tip animator its a little dark.. any tips on how to get it lighter and more colors to the palettes.. also im going to be making a vbxe version (may in fact be the main version with a non vbxe version also being made.... ) is there a vbxe palette option? so we can use the expanded colour selection available with vbxe? Edited September 13, 2018 by Kernal Quote Share this post Link to post Share on other sites
Kernal #5 Posted September 13, 2018 Also i am exporting them as 8bit 160x100 jpegs... should i use PNG or BMP for better results? Also with the vbxe question above.. how would i integrate these into a basic program... such as load one of these as the intro to a game and then user hits the space bar to continue on to the main menu.... Quote Share this post Link to post Share on other sites
Heaven/TQA #6 Posted September 13, 2018 Andreas...can you include your how to into a readme and include in your pack? Quote Share this post Link to post Share on other sites
+CharlieChaplin #7 Posted September 13, 2018 Andreas...can you include your how to into a readme and include in your pack? Oh, I wrote several (similar) "how to's" for Tip Animator / Tip Converter in the meanwhile, so which of them do you prefer - the one above (post #3) or one of the older ones... (attached here)... ?!? HOW_TO_1.rtf HOW_TO_2.rtf Quote Share this post Link to post Share on other sites
Kernal #8 Posted September 13, 2018 heres some more tests Cinema 4d (output 8bit jpeg) -> Ant renamer -> tipconv (jakub15.act) -> TipAnm (4 part animation framed 1-30, 30-45,.45-60, 60-70) dalek4.xex dalek5.xex dalek6.xex dalek7.xex Quote Share this post Link to post Share on other sites
Kernal #9 Posted September 13, 2018 what palette might make these brighter they are really dark. Quote Share this post Link to post Share on other sites
+CharlieChaplin #10 Posted September 13, 2018 (edited) what palette might make these brighter they are really dark. Alas, only the greyscale palette does make them brighter. Other choices: Search for another (brighter) Dalek video or animation or if you really really want this video/animation, extract all frames and then use a GFX converter (e.g. Irfan View, XnView, etc.) to brighten all these frames. When done convert them again with Tip Converter... Attached are two Dalek videos (downloaded from youtube) and the converted TIP animations, which do require 320k RAM. The longer animation uses 86 frames with visible resolution of 100x70 pixels in greyscales, whereas the shorter animation uses 51 frames with visible resolution of 100x70 pixels in OlivierP (PAL) palette. Unpacked length of the longer TIP animation is 298kbytes (worked only with TipAnm29), the shorter TIP animation has a length of 228kbytes (also worked with TipAnm2xB); both animations could be packed quite good with Superpacker/Exomizer... As always: Keep a distance of 2 or 3 meters from the screen when watching the TIP animations, due to their low resolution... Gold Daleks on Skaro in 4K.mp4 Skaro Corridor - Dalek Animation.mp4 Gold_Daleks_on_Skaro_320k.xex Gold_Daleks_on_Skaro_320k_packed.xex Skaro_Corridor_Dalek_Animation_320k.xex Skaro_Corridor_Dalek_Animation_320k_packed.xex Edited September 13, 2018 by CharlieChaplin Quote Share this post Link to post Share on other sites
_The Doctor__ #11 Posted September 13, 2018 ugh PAL... Quote Share this post Link to post Share on other sites
+CharlieChaplin #12 Posted September 13, 2018 (edited) ugh PAL... ugh NTSC... ugh Secam... ugh ugh... Who wants to convert "Ugh" (available for PC/Amiga/C64) to the A8 ? https://en.wikipedia.org/wiki/Ugh! Besides, I am from Germany (a PAL country) and I am using PAL Ataris and tv's... Edited September 13, 2018 by CharlieChaplin Quote Share this post Link to post Share on other sites
_The Doctor__ #13 Posted September 13, 2018 Yes Ugh! coverted from Amiga/64 with some improvements would be quite nice. Quote Share this post Link to post Share on other sites
Kernal #14 Posted September 22, 2018 Very good!!! did u use cinema 4d to make the original frames? Quote Share this post Link to post Share on other sites
Kernal #15 Posted September 22, 2018 do you have a copy of those models thats the dalek models ive been looking for ,, and that set =D if you have it.. please send.. and ill give u full credit in the game credits. Quote Share this post Link to post Share on other sites
+CharlieChaplin #16 Posted September 22, 2018 (edited) Very good!!! did u use cinema 4d to make the original frames? do you have a copy of those models thats the dalek models ive been looking for ,, and that set =D if you have it.. please send.. and ill give u full credit in the game credits. Errrm, if these questions are directed at me (not sure if they are), then sorry, as stated in post 10 above, I simply downloaded the videos from youtube (and also uploaded the smaller resolution youtube videos in post 10) and then converted these videos into TIP animations. I do not own Cinema 4D nor did I ever create any models, movies or animations myself on the PC or Atari. I am simply converting material I find on the internet (youtube, google, etc.) into A8 usable or playable stuff (GFX, SNDs, ANIs, etc.)... The original Dalek videos are here: [youtube https://www.youtube.com/watch?v=IZCy58Rf05s] and here: [youtube https://www.youtube.com/watch?v=ksXrvoV7-fc] and you can find many more with the search string "Dalek" with youtube or google. You may ask one of the original authors then, how they did their animation or video... Edited September 22, 2018 by CharlieChaplin Quote Share this post Link to post Share on other sites
Kernal #17 Posted September 23, 2018 all my dalek animations ive been making by my own hand in cinema 4d.. the cyberman models and dalek models are ones i constructed origianly for the game and if u check out my thread i have written a precursor game called mission to the unknown which will eventually become part of the daleks of skaro video game./long form animation will be released simultaneously.. i do need help though.. making intro movies and thickening the plot i am using cinema 4d to do the animations and untiy 3d for the video game programming. Quote Share this post Link to post Share on other sites
