DVDfever Posted August 13, 2019 Share Posted August 13, 2019 Awesome fun! Here's some gameplay on Standard difficulty 4 Quote Link to comment Share on other sites More sharing options...
MissCommand Posted August 14, 2019 Share Posted August 14, 2019 Is the latest ROM supposed to have the voices? I don't have any on mine. Quote Link to comment Share on other sites More sharing options...
Jstick Posted August 14, 2019 Share Posted August 14, 2019 25 minutes ago, MissCommand said: Is the latest ROM supposed to have the voices? I don't have any on mine. Do you have an Atarivox plugged in? 1 Quote Link to comment Share on other sites More sharing options...
MissCommand Posted August 15, 2019 Share Posted August 15, 2019 On 8/13/2019 at 10:23 PM, Jstick said: Do you have an Atarivox plugged in? Yes, the voice is playing on the first ROM he posted. I noticed the gameplay video that DVDFever posted does not have the voices either, so I guess it is disabled in the latest ROM. Quote Link to comment Share on other sites More sharing options...
+groundtrooper Posted August 15, 2019 Share Posted August 15, 2019 Vox+ is playing voices for me. I played up to 2-3 levels without the Vox+ starting to glitch. I didn't have time to play longer. But the Vox works fine on my Harmony Encore via 7800 & Vox+ on the 20190812 version of the rom. Quote Link to comment Share on other sites More sharing options...
MissCommand Posted August 15, 2019 Share Posted August 15, 2019 1 hour ago, groundtrooper said: Vox+ is playing voices for me. I played up to 2-3 levels without the Vox+ starting to glitch. I didn't have time to play longer. But the Vox works fine on my Harmony Encore via 7800 & Vox+ on the 20190812 version of the rom. Doh... thanks Groundtrooper. You got me to thinking about me using an emulator... ? I had forgot to set the second port to AtariVox. All is good now. ? 1 Quote Link to comment Share on other sites More sharing options...
DVDfever Posted August 17, 2019 Share Posted August 17, 2019 On 8/15/2019 at 7:32 PM, MissCommand said: Yes, the voice is playing on the first ROM he posted. I noticed the gameplay video that DVDFever posted does not have the voices either, so I guess it is disabled in the latest ROM. I'm just playing it on Stella. Is there a way to access it through that? Thanks. Quote Link to comment Share on other sites More sharing options...
MissCommand Posted August 17, 2019 Share Posted August 17, 2019 8 minutes ago, DVDfever said: I'm just playing it on Stella. Is there a way to access it through that? Thanks. No, you do have to have an AtariVox for the voices. I have mine hooked up through a 9-Pin/USB converter and my computer speakers have an audio mix in for the AtariVox out. 1 Quote Link to comment Share on other sites More sharing options...
+stephena Posted August 18, 2019 Share Posted August 18, 2019 A real AtariVox is required for sound/voices, since the chip that does it is proprietary, and we cannot duplicate its behaviour in Stella. Quote Link to comment Share on other sites More sharing options...
Swami Posted August 19, 2019 Share Posted August 19, 2019 6 hours ago, stephena said: A real AtariVox is required for sound/voices, since the chip that does it is proprietary, and we cannot duplicate its behaviour in Stella. This may sound crazy, but does the AtariVox, AtariVox+ voice work with any of the 2600daptors? Quote Link to comment Share on other sites More sharing options...
+stephena Posted August 19, 2019 Share Posted August 19, 2019 11 hours ago, Swami said: This may sound crazy, but does the AtariVox, AtariVox+ voice work with any of the 2600daptors? You should speak with @dualcam (creator of the 2600-daptor, http://www.2600-daptor.com), but I'm pretty sure it's only the D9, and possibly the version II. But don't quote me on that. Quote Link to comment Share on other sites More sharing options...
+Karl G Posted August 19, 2019 Share Posted August 19, 2019 1 hour ago, stephena said: You should speak with @dualcam (creator of the 2600-daptor, http://www.2600-daptor.com), but I'm pretty sure it's only the D9, and possibly the version II. But don't quote me on that. Actually, it's the "2600 II" that supports the AtariVOX, and it requires a special firmware that makes it only usable with the AtariVOX (not other controllers). I have one, and have successfully used it with my AtariVOX+. 1 1 Quote Link to comment Share on other sites More sharing options...
MissCommand Posted August 19, 2019 Share Posted August 19, 2019 (edited) Yes, I also use the 2600II for my AtariVox+... the special firmware allows it be seen as a COM port on your computer which Stella can connect with. The 2600II can also be reflashed online so it can be used with a joystick/controller. Edited August 19, 2019 by MissCommand 1 Quote Link to comment Share on other sites More sharing options...
+Karl G Posted August 19, 2019 Share Posted August 19, 2019 20 minutes ago, MissCommand said: Yes, I also use the 2600II for my AtariVox+... the special firmware allows it be seen as a COM port on your computer which Stella can connect with. The 2600II can also be reflashed online so it can be used with a joystick/controller. Right ... flashing it for use with the AtatiVOX isn't a one-way trip. I was just trying to say it couldn't be used for both functions at the same time. I personally have two so that I can use one for controllers, and the other for the AtariVOX. 1 Quote Link to comment Share on other sites More sharing options...
dualcam Posted August 19, 2019 Share Posted August 19, 2019 (edited) 14 hours ago, Swami said: This may sound crazy, but does the AtariVox, AtariVox+ voice work with any of the 2600daptors? Yes, as already posted there is a firmware for the 2600 II to turn it into an AtariVox adapter. I have ported the code over to the D9, but there is a problem with the interface for the AtariVox's I2C EEPROM that I have yet to look into. Probably be winter before I get to that. Tom http://2600-daptor.com/ Edited August 19, 2019 by dualcam 2 Quote Link to comment Share on other sites More sharing options...
Richard H. Posted August 21, 2019 Share Posted August 21, 2019 Demo doesn't work on my UNO cart. Anyone know why ? Quote Link to comment Share on other sites More sharing options...
+johnnywc Posted August 21, 2019 Author Share Posted August 21, 2019 13 minutes ago, Richard H. said: Demo doesn't work on my UNO cart. Anyone know why ? Hi Richard, I don't believe any CDF/DPC+ games run on the UNO cart (Draconian, Mappy, Scramble, Galaga, etc.) but I believe someone in the UNO cart community may be working on that. Quote Link to comment Share on other sites More sharing options...
Albert Posted August 22, 2019 Share Posted August 22, 2019 Here's a peak at the boxes for Wizard of Wor Arcade. Dave Dries did a stupendous job with this artwork and design!! 18 1 Quote Link to comment Share on other sites More sharing options...
+groundtrooper Posted August 22, 2019 Share Posted August 22, 2019 5 minutes ago, Albert said: Here's a peak at the boxes for Wizard of Wor Arcade. Dave Dries did a stupendous job with this artwork and design!! WOW! Just WOW! pun intended I guess. 3 Quote Link to comment Share on other sites More sharing options...
Brian O Posted August 22, 2019 Share Posted August 22, 2019 4 minutes ago, Albert said: Here's a peak at the boxes for Wizard of Wor Arcade. Dave Dries did a stupendous job with this artwork and design!! Holy shit. That is a work of art. 2 Quote Link to comment Share on other sites More sharing options...
Isaiah Austin Posted August 22, 2019 Share Posted August 22, 2019 Amazing! This is one of the best box artwork designs I've ever seen! Will the cartridge label evaentually look the same? 2 Quote Link to comment Share on other sites More sharing options...
Albert Posted August 22, 2019 Share Posted August 22, 2019 2 minutes ago, Isaiah Austin said: Amazing! One of the best box artwork designs I've ever seen! Will the cartridge label look the same? Similar, yes. ..Al 2 Quote Link to comment Share on other sites More sharing options...
VectorGamer Posted August 22, 2019 Share Posted August 22, 2019 1 hour ago, Albert said: Here's a peak at the boxes for Wizard of Wor Arcade. Dave Dries did a stupendous job with this artwork and design!! I've seen better. Just kidding. That fucking rocks! 1 3 Quote Link to comment Share on other sites More sharing options...
TrekMD Posted August 22, 2019 Share Posted August 22, 2019 Wow, that is one awesome box design! Fantastic art! Fitting for the fantastic games the box houses. 3 Quote Link to comment Share on other sites More sharing options...
+sramirez2008 Posted August 22, 2019 Share Posted August 22, 2019 (edited) Truly amazing art! @Albert I call dibs on the poster that will certainly be on display at PRGE.? <Edit> @johnnywc Is there an ETA for the QuadTari adapter? Man I can't wait for PRGE...56 days and counting. Edited August 22, 2019 by sramirez2008 QuadTari 1 Quote Link to comment Share on other sites More sharing options...
