Dalta Posted December 5, 2018 Share Posted December 5, 2018 Unfortunately not. I thought of that, everything starts at x=0 and I even changed it to x=1 or x=5 and I still get the bizarre behaviour were parts of the sprite don't collide. Just to clarify, I added 'set collisionwrap on' too and nothing changed. Quote Link to comment Share on other sites More sharing options...
RevEng Posted December 5, 2018 Share Posted December 5, 2018 Yeah, not sure. Maybe if you post some code we can pin the problem down. The boxcollision code is pretty simple and well-tested at this point. Quote Link to comment Share on other sites More sharing options...
Dalta Posted December 16, 2018 Share Posted December 16, 2018 (edited) set zoneheight 8 set collisionwrap on dim playerx=a playerx=75 playery=176 dim playery=b dim platx=c c=142 dim platy=d d=152 dim platx2=g:platx2=platx-16 dim platx3=h:platx3=platx-32 dim platx4=i:platx4=platx-48 dim prevx=e dim prevy=f incgraphic face1.png incgraphic plat.png rem ***' set the colors of palette 0, which we'll use to draw the happy face P0C1=$82 P0C2=$48 P0C3=$fb main clearscreen prevx=playerx prevy=playery ;'joystick if joy0left then playerx=playerx-1 if joy0right then playerx=playerx+1 if joy0down then playery=playery+2 if joy0up then playery=playery-2 ;if joy0fire0 then ;if joy0fire1 then ;'stop player moving off screen if playerx<1 then playerx=playerx+1 if playerx>150 then playerx=playerx-1 if playery<1 then playery=playery+2 if playery>176 then playery=playery-2 ;'COLLISION DETECTION ;'bottom right wall if playerx>prevx && boxcollision(playerx, playery, 8, 8, 94, platy, 64, 2) then playerx=playerx-1 if playerx<prevx && boxcollision(playerx, playery, 8, 8, 94, platy, 64, 2) then playerx=playerx+1 if playery>prevy && boxcollision(playerx, playery, 8, 8, 94, platy, 64, 2) then playery=playery-2 if playery<prevy && boxcollision(playerx, playery, 8, 8, 94, platy, 64, 2) then playery=playery+2 ;'bottom left wall if playerx>prevx && boxcollision(playerx, playery, 8, 8, 0, 152, 64, 2) then playerx=playerx-1 if playerx<prevx && boxcollision(playerx, playery, 8, 8, 0, 152, 64, 2) then playerx=playerx+1 if playery>prevy && boxcollision(playerx, playery, 8, 8, 0, 152, 64, 2) then playery=playery-2 if playery<prevy && boxcollision(playerx, playery, 8, 8, 0, 152, 64, 2) then playery=playery+2:plotsprite plat 0 0 0 ;'top left wall if playerx>prevx && boxcollision(playerx, playery, 8, 8, 15, 48, 64, 2) then playerx=playerx-1 if playerx<prevx && boxcollision(playerx, playery, 8, 8, 15, 48, 64, 2) then playerx=playerx+1 if playery>prevy && boxcollision(playerx, playery, 8, 8, 15, 48, 64, 2) then playery=playery-2 if playery<prevy && boxcollision(playerx, playery, 8, 8, 15, 48, 64, 2) then playery=playery+2 ;'top right wall if playerx>prevx && boxcollision(playerx, playery, 8, 8, 94, 48, 64, 2) then playerx=playerx-1 if playerx<prevx && boxcollision(playerx, playery, 8, 8, 94, 48, 64, 2) then playerx=playerx+1 if playery>prevy && boxcollision(playerx, playery, 8, 8, 94, 48, 64, 2) then playery=playery-2 if playery<prevy && boxcollision(playerx, playery, 8, 8, 94, 48, 64, 2) then playery=playery+2 ;' middle wall upper if playerx>prevx && boxcollision(playerx, playery, 8, 8, 79, 68, 32, 2) then playerx=playerx-1 if playerx<prevx && boxcollision(playerx, playery, 8, 8, 79, 68, 32, 2) then playerx=playerx+1 if playery>prevy && boxcollision(playerx, playery, 8, 8, 79, 68, 32, 2) then playery=playery-2 if playery<prevy && boxcollision(playerx, playery, 8, 8, 79, 68, 32, 2) then playery=playery+2 ;' middle wall lower if playerx>prevx && boxcollision(playerx, playery, 8, 8, 22, 120, 32, 2) then playerx=playerx-1 if playerx<prevx && boxcollision(playerx, playery, 8, 8, 22, 120, 32, 2) then playerx=playerx+1 if playery>prevy && boxcollision(playerx, playery, 8, 8, 22, 120, 32, 2) then playery=playery-2 if playery<prevy && boxcollision(playerx, playery, 8, 8, 22, 120, 32, 2) then playery=playery+2 ;' debug line, draws a line in the top right of the screen when player hits the bottom left line if boxcollision(playerx, playery, 8, 8, 20, 120, 32, 2) then plotsprite plat 0 0 0 plotsprite face1 0 playerx playery ;'DRAWING WALLS plotsprite plat 0 platx platy plotsprite plat 0 platx2 platy plotsprite plat 0 platx3 platy plotsprite plat 0 platx4 platy plotsprites plat 0 0 platy plotsprites plat 0 16 platy plotsprites plat 0 32 platy plotsprites plat 0 48 platy ;'enemy base walls plotsprites plat 0 0 48 plotsprites plat 0 16 48 plotsprites plat 0 32 48 plotsprites plat 0 48 48 plotsprites plat 0 142 48 plotsprites plat 0 126 48 plotsprites plat 0 110 48 plotsprites plat 0 94 48 ;'middle walls plotsprites plat 0 79 68 plotsprites plat 0 95 68 plotsprites plat 0 22 120 plotsprites plat 0 38 120 drawscreen goto main Pff, it's already been over 10 days. Sorry for the delay, I'm hoping to carve out some time soon to work on this consistently soon but not there yet. If you still even remember what we were talking about and are interested, I would appreciate the help, thanks for the offer. I just hope it's not something embarrassingly simple, though that's what it feels like it will turn out to be to be honest. I hope you don't mind me posting it all, I figured it would probably take me longer to explain it than to just write out the entire code. Edited December 16, 2018 by Dalta Quote Link to comment Share on other sites More sharing options...
+frankodragon Posted December 17, 2018 Share Posted December 17, 2018 For one thing I noticed, I don't think 7800Basic recognizes "plotsprites" unless it's something new that's been added recently. Quote Link to comment Share on other sites More sharing options...
RevEng Posted December 17, 2018 Share Posted December 17, 2018 Ok, you've done nothing wrong, but it seems you've run up against the limits of the boxcollision function. It was always intended for sprite sized objects (it's under the heading "sprite collisions with boxcollision" in the manual) and objects wider than 48 pixels cause certain checks to break. I could squeeze in larger objects by adding in a bunch of checks, or switching to 16-bit math, but it would complicate the routine a fair bit. It's designed to be as lean as possible, so as not to bog down games with typical requirements. I'll update the docs with the boxcollision limitation next chance I get. For your project, I'd recommend you use peekchar to look for tiles at certain points under your sprite. There's more on that here. For one thing I noticed, I don't think 7800Basic recognizes "plotsprites" unless it's something new that's been added recently. Nice catch. I think the parser is just taking it as a "plotsprite" command. More homework for me. Quote Link to comment Share on other sites More sharing options...
Dalta Posted December 17, 2018 Share Posted December 17, 2018 (edited) Thanks a lot guys for the help. Yes, I thought about making a tile map originally, but I was just trying to get something quick and dirty up and running. Thanks for the link, I will go through and reformulate the code with its help. Edit: Ah, I've seen that link before haha, I was planning to come back to tiles and that after getting this game going, it looks my hand has been forced Edited December 17, 2018 by Dalta Quote Link to comment Share on other sites More sharing options...
