Sign in to follow this
repetto74
Atari 800XL PSU and caps replacement
Hi,
the PSU of my 800 XL is this one below
3) CO61763-11
Input: 220VAC 50Hz 26VA
Output: 5VDC 1,5A
Fuse: T 2.5A
Thermal fuse: 125 degr.C
T40/E
Approval signs: VDE (German) GS (Geprüfte Sicherheit (="tested safety", German)
Brand: FWGB which stands for Friwo Gerätebau GmbH. from Germany
Notes: The FW1599 Typenr. is a factory Friwo number. Although it doesn't say it was made in Germany it was produced by a German company and the unit is over a very very good quality. Construction, lay-out are excellent. I haven't checked the schematics, but the set-up is pretty extensive for a "simple" 5V DC power supply.
The big filter cap is of the Frako brand (www.frako.com), a very high quality German capacitor brand. FRAKO stands for FRAnkfurter KOndensatorenfabrik or "capacitor factory of Frankfurt". I couldn't see the brand of the smaller caps but I measured all of them with a high quality ESR meter and all show excellent values still.
I think this supply is the most common one for the XLs around here and my preferred power supply.
I am glad to hear it is a quality one compared to others. I have checked the PSU pcb recently and did not noted anything suspicious but was thinking to replace the tree elec caps as a precaution. I have a doubt concerning the two 100uF 25V caps as I am not sure if they are or not polarised. Both caps have a white band on one side so I assume this is to identify the negative lead? It is the first time I see caps with this odd marking.
Thanks
Rick
Hey Rick....
I'd have to open mine up again to check, can you post pictures ?
I'd personally check the caps with a good ESR meter but not everyone has one of course.
You can also check for any poor cap performance by measuring the output voltage with a multi-meter in _AC_ setting to measure any ripple.
Be sure to get QUALITY replacement caps, Nichicon and Panasonic are good brands, Panasonic usually a bit cheaper. While you are at it, buy 105 degree ones with a low ESR. It's worth investing a bit more if you take the trouble to replace them.
Hi Level42,
I have this picture here if that can help otherwise I may open the PSU case again and take some better pictures.
As you can see I do not know if the two 100uF caps are or not polarised.
Hi Level42,
Yes those are DEFINITLY polarized. They are electrolytic caps just like the bigger ones.
Hi Level42,
Good! I will replace the three of them for precaution then. I have them in stock here with me so it will be a quick job to do :-).
Thanks a lot.
Rick
I so hope you have goog quality ones, not Chinese no-name caps since you might actually make things worse with those...
Could you do me a favor and ID the brand of the smaller caps (maybe a sharp close-up picture) ? I see the big ones are Nippon Chemi-Con on your picture....
Hi Level42,
I will open the PSU tomorrow and let you know the brand no problem ;-). Yes the replacement caps are good quality ones I bought from my local electronic reseller here.
Hi Level42
Here is a picture of one of the 100 uF cap I removed today. There is no name on it but if you zoom the picture there is a small logo and you may guess the brand ;-)
Cheers,
Rick
