sanny Posted September 25, 2018 Share Posted September 25, 2018 Hi, I'm currently implementing clock_gettime/clock_settime functions for CC65. I have a working implementation for SpartaDOS-X. What other DOSes keep track of date/time and have a (program) interface to get/set the system time? regards, chris Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted September 26, 2018 Share Posted September 26, 2018 Hmmm, afaik date+time is only(?) supported with DOS versions that use the SDFS (Sparta DOS File System), e.g. Sparta DOS 1.x, Sparta DOS 2.x, Sparta DOS 3.x, Sparta DOS 4.x (SDX), Bewe-DOs and RealDOS. There is also Atari DOS XE that supports the date (but not the time). Do not know of any other DOS that makes use of date and time. But since there are dozens or hundreds of Atari DOS versions, I would not be surprised if there is another (maybe uncommon, maybe not widespread) DOS that makes use of date/time, that I am currently not aware of... Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 26, 2018 Share Posted September 26, 2018 (edited) ICD made a driver for the R-time 8 and DOS XE, I think it was called the DOS XE integration driver or some such blather, I will look for it. setting the time called an outside program that could set time and date... but the date could still be set from within DOS XE menu. Edited September 26, 2018 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
dmsc Posted September 26, 2018 Share Posted September 26, 2018 Hi! Hi, I'm currently implementing clock_gettime/clock_settime functions for CC65. I have a working implementation for SpartaDOS-X. What other DOSes keep track of date/time and have a (program) interface to get/set the system time? BW-DOS should be compatible with SpartaDOS, the documentation says: TABLE IN PAGE 7 In the page 7 there is a little table, that shows version of the DOS, and allows machine code programs to use a few special functions: - $700: There is allways the character "S" to provide the best compatibility with SpartaDOS. Many programs will determine by this adress, if they can use advanced SpartaDOS (BW-DOS) functions. - $701: There is allways the number $32 to provide the best compatibility with SpartaDOS. - $703 (two bytes): There are the letters "BW" when any version of BW-DOS is installed. - $705: BW-DOS version. $10 is for version 1.0x, $13 is for version 1.3x etc. - $706 (two bytes): Adress of the "GETTD" routine. This routine reads the date and time from BW-DOS's clock, and store it into "DATER" and "TIMER" in the "COMTAB". - $708 (two bytes): Adress of the "SETTD" routine. This routine reads the date and time from "DATER" and "TIMER" in the "COMTAB", and store it into BW-DOS's clock. The location of the "DATER" and "TIMER" fields is given relative to "COMTAB": THE COMTAB TABLE This table allows machine code programs to get parameters from the CP, and to use many other features of BW-DOS. Adress of this table is stored in the "DOSVEC" vector (at $0A); numbers in the following description are relative positions in the table. Bytes, which are not mentioned in the description, are reserved for compatibility with several SpartaDOS versions; such a bytes may not be changed by any program! ... +13: DATER +16: TIMER This is the main variable for date and time (3+3 bytes). It is in the format "day, month, year; hour, min., sec." This variable is used by "GETTD" and "SETTD" routines, and while creating a file. 2 Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted September 28, 2018 Share Posted September 28, 2018 Depending how far you want to go - the ICD R-Time 8 disk includes zhand.sys (or something like that) to allow a program on Atari DOS and other DOS that don't natively do date/time to read time from Z: device. 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 28, 2018 Share Posted September 28, 2018 (edited) doesn't amodem and a few other terminal programs read and/or write to the rtc direclty? I know at the very least reads it. express 850 not cart might be like that... Edited September 28, 2018 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
sanny Posted September 29, 2018 Author Share Posted September 29, 2018 Depending how far you want to go - the ICD R-Time 8 disk includes zhand.sys (or something like that) to allow a program on Atari DOS and other DOS that don't natively do date/time to read time from Z: device. This could be interesting for more support in other DOSes. Is there information available about how to access the Z: device, and do all Z: handlers follow that interface? Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted September 29, 2018 Share Posted September 29, 2018 Heres the R-Time 8 Manual: https://archive.org/details/R-Time-8_SDCS_Supplement_1985_ICD/page/n7 Z: handler is covered starting on page 3. Makes it really easy to get/set the time/date in BASIC for instance. 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted October 26, 2018 Share Posted October 26, 2018 Z: is also supported in Jon's BIOS (for free). It takes NO RAM away from the computer, unlike loadable Z: handlers. 1 Quote Link to comment Share on other sites More sharing options...
sanny Posted October 27, 2018 Author Share Posted October 27, 2018 What is, and where can I find, "Jon's BIOS"? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted October 27, 2018 Share Posted October 27, 2018 Unless you have an Ultimate 1MB or Incognito in your machine, it's irrelevant. If you do, however, you can find the firmware on my website. 2 Quote Link to comment Share on other sites More sharing options...
