Lillapojkenpåön Posted May 21, 2020 Author Share Posted May 21, 2020 19 minutes ago, Andrew Davie said: I totally don't understand your usage of "align" or what you're trying to do here. If it's to get bankswitching code in the right place, then I've not seen it done using aligns. It might work. Generate a listing file, and have a look at the assembly. That will clearly show you what is where. I have only ever used "align" to get to page boundaries. The "align 133" would, I assume, align to the 133rd byte in the current page, except where you're already past that, in which case it will be the 133rd byte in the NEXT page. It's still bizarre usage to me, tough. You code, as shown, does not seem to have much of any idea where it is related to page boundaries. Not saying it's wrong - it's just very foreign to me, this usage. Yes it's to get the bankswitching code in the right place, I was using nop's but since I have a compile time condition and probably will add more I thought I'd try it instead of adding compile time conditions with different amount of nop's, align seemed like the obvious choice, but maybe there's better ones? I would like to know. 6096 4c a4 b0 jmp .bs6 6099 60a4 00 00 00 00* align 133 60a4 .bs6 60a4 ad f7 1f lda $1FF7 I wouldn't say clearly, I can't read hex, I thought the low byte of the address was the number of bytes into the current page (high byte), I was displaying that in my score as decimal to see where I was, but I seem to have been wrong? How do I use these hex numbers to my advantage not knowing what they mean? Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted May 21, 2020 Share Posted May 21, 2020 3 hours ago, Lillapojkenpåön said: Yes it's to get the bankswitching code in the right place, I was using nop's but since I have a compile time condition and probably will add more I thought I'd try it instead of adding compile time conditions with different amount of nop's, align seemed like the obvious choice, but maybe there's better ones? I would like to know. 6096 4c a4 b0 jmp .bs6 6099 60a4 00 00 00 00* align 133 60a4 .bs6 60a4 ad f7 1f lda $1FF7 I wouldn't say clearly, I can't read hex, I thought the low byte of the address was the number of bytes into the current page (high byte), I was displaying that in my score as decimal to see where I was, but I seem to have been wrong? How do I use these hex numbers to my advantage not knowing what they mean? Well, that number on the left is the address, in hex. A4 is 164. That's the low byte of the address of the label .bs6 within a page. Since the code says "align 133" this is clearly not working as you expect. I would actually call this a bug in the "align" statement in dasm. I will follow that up with some tests and a bug report if needed. But basically, it does not look to me like your code is handling things as you expect. You could set a label to do what you want... something like this... HERE SET * ; some code for 1st block jmp .bs2 ; unused filler is here HERE SET HERE + 133 ORG HERE .bs2 ; some code that lives in the 2nd block jmp .bs3 ; unused filler is here HERE SET HERE + 266 ;? is it in 133 groups?? ORG HERE .bs3 ; some code that lives in the 3rd block jmp .bs4 Hope that makes sense, and that it works 1 Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted May 21, 2020 Author Share Posted May 21, 2020 Haha, what are the odds of me accidentally checking the wrong previous label, and using that number causes it to align to the right address, 164 is exactly where it should be ? to many here's, would this work _bank6data SET * ; some code for 1st block jmp .bs2 ; unused filler is here bs6 SET _bank6data + 164 ORG bs6 or this ; some code for 1st block jmp .bs6 ; unused filler is here ORG $60a4 .bs6 Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted May 21, 2020 Author Share Posted May 21, 2020 (edited) 1 hour ago, Lillapojkenpåön said: or this ; some code for 1st block jmp .bs6 ; unused filler is here ORG $60a4 .bs6 this looks good in the listing file but only black screen, why? other ORG's interfering? the other one, that should have been _bank6data + 31, also looks good, but origin reverse-indexed error ? Edited May 21, 2020 by Lillapojkenpåön Quote Link to comment Share on other sites More sharing options...
Lillapojkenpåön Posted May 23, 2020 Author Share Posted May 23, 2020 How do I use breakif { _scan==#263 } in Stella? I thought I remembered being able to paste it in there but I can't Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted May 23, 2020 Share Posted May 23, 2020 7 hours ago, Lillapojkenpåön said: How do I use breakif { _scan==#263 } in Stella? I thought I remembered being able to paste it in there but I can't "breakif _scan==40" works for me. The number is hexadecimal, so the above example will break on scanline 64. 1 Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted May 23, 2020 Share Posted May 23, 2020 You can type "help" in the debugger, and get additional help by adding the command name. So, "help breakif" will tell you the format to use. 1 Quote Link to comment Share on other sites More sharing options...
