FlashROM99 MG Explorer image
FALCOR4
  • 4 months later...
Attached is a version of the Explorer that I've wanted to release for many years now. I did some updates and fixed three known bugs; this is the Paisley version.
This version was intended to be under 16k (original was over 18k) to fit into two ROM/GROM banks with room for a simple loader. The file attached is a cartridge version with JG's loader for two ROM banks.
It no longer has two of the Exp screens; the options screen and the register screen nor does it have the user-configuration-save function. It added help screens, a memory mapped device function, a GRAM simulator switch (which was a utility that came with the Gram Kracker) and changed the GROM base address field to a GROM page field. There were a few more minor changes, all in the interest of single screen utility and stability.
I want to thank retroclouds and FarmerPotato for helping to beta test it. It was very helpful and they found some goof ups of mine that I introduced in the rewrite. If you find something not working quite right please let me know as well.
Also, if anyone wanted to come up with a key strip that would be very cool!
LEXP.bin
Thanks,
Doug
  • Like 8
The only manual available is the original MG Explorer manual mentioned earlier in this thread. Much of it still applies to this version sans the deleted screens and a few other minor changes. It's a good place to start. I embedded help screens in this version to try and bridge the gap a bit.
I'm not sure I will ever get around to updating a manual for this version. I do still have the original text, just need to sit down and figure out how to get the formatting to come across to the PC then I could consider it. Just takes time :-)
Comparing it to the original strip-Please feel free to abbreviate as it makes sense and thank you for doing this:
CTRL
1 - same - SINGLE Step
2 - same - CONT Step
3 - same - SELECT AP/EXP Screen
4 - same - INTRUPS On/Off
5 - same - SOUND Off
6 - AP SCREEN On
7 - blank
8 - blank
9 - SELECT GRAM Sim Mode
0 - blank
= - same - QUIT
FCTN
1 - same - Memory Select
2 - same - Memory Window Size
3 - same - Disassem Size
4 - same - Page Up
5 - same - Search
6 - same - Page Down
7 - blank
8 - Write to MMD
9 - same - Edit Field/Mem
0 - same - Basic Bias On/Off
= - same - ASCII/HEX
  • 4 months later...
Thanks,
Doug
This one fixes an annoying memory block address nit that is in Paisley v2.0a
LEXP_V21a.bin
Doug
  • Like 4
