str0m Posted November 14, 2018 Share Posted November 14, 2018 Hi, I recently bought an FZ10 which came with a wired 6 button Super UFO pad. It seems to use the same case as their wireless IR one even down to having the battery area (but no terminals etc). It doesn't have a daisy chain port but I have tested it in SF2 and all buttons work correctly. I then picked up one of the odd shaped Capcom controllers and that also works correctly in SF2. If I connect the Super UFO controller to the daisy chain cable on the Capcom it doesn't work right, none of the buttons work by themselves however if you hold down two you will get a response ie two of the normal buttons and suddenly a punch, hold the dpad diagonally and character will go left. As mentioned above, that pad works correctly by itself. Is there anyway of telling where the problem is, wiring issue in one of the pads or in the console itself? I don't know anyone else with a 3DO so thought I would ask before I hunted down another pad to buy. thanks, Darren Quote Link to comment Share on other sites More sharing options...
homerj Posted November 14, 2018 Share Posted November 14, 2018 Have you tried connecting the Capcom to the UFO? Quote Link to comment Share on other sites More sharing options...
str0m Posted November 15, 2018 Author Share Posted November 15, 2018 The UFO doesn't have a daisy chain port unfortunately Quote Link to comment Share on other sites More sharing options...
homerj Posted November 15, 2018 Share Posted November 15, 2018 The UFO doesn't have a daisy chain port unfortunately Oops. Missed that part. Well, just kind of browsing this thread ithttp://atariage.com/forums/topic/199303-3do-super-ufo-controller/it seems like the UFO is just not compatible with all other 3DO controllers. That one guy also said his wouldn't work when plugged directly into the 3DO as a stand alone controller though. 1 Quote Link to comment Share on other sites More sharing options...
str0m Posted November 16, 2018 Author Share Posted November 16, 2018 It is a bit strange. I will see if I can find someone local with a different pad to test and keep a look out on ebay for a cheap one Quote Link to comment Share on other sites More sharing options...
str0m Posted December 18, 2018 Author Share Posted December 18, 2018 So...I managed to pick up another of the Capcom ones. They work daisy chained together with no issues. The Super UFO pad works by itself but does not when daisy chained off either of them, have the issue above where you need to push 2 buttons/directions for it to react. Very weird. I blame that pad, I mean why doesn't it even have a pass thru!! :0 Quote Link to comment Share on other sites More sharing options...
