intvnut
jzintv Christmas update
I compiled the source with no issues.  Am I still using Makefile.termux_sdl2, or was everything consolidated into one Makefile?
I left the Termux Makefiles as-is for now.  If you're up for an experiment, I'd like you to try the following experiment:
  • In jzintv/src/buildcfg/:
    • ln -s 00-compiler-termux-clang.mak.txt 00-compiler.mak
    • ln -s 10-opt-for-native.mak.txt 10-opt.mak
  • Then try building with the Linux default Makefiles in jzintv/src:
    • SDL1: make -f Makefile.linux_sdl1 clean ; make -f Makefile.linux_sdl1
    • SDL2: make -f Makefile.linux_sdl2 clean ; make -f Makefile.linux_sdl2
If those work, then we can retire the Makefile.termux* files.
On 5/29/2020 at 2:29 AM, intvnut said:
Well, if you want to try to help me reheat Tim Lindner's port to MacOS Classic, I suppose I can dig those files back out.  They're in the revision history.
How many extensions are there out there now?  I search for  bin, int, itvrom, and cc3 currently.
Then there is no file extension at all on the Lives! and Rocks! CDs. 😛
I believe that's true on the Mac "side" of the disk.  On the PC "side," I see bin+cfg on Lives, and itv+cfg on Rocks.
Yep.
I created the two symlinks and then ran the builds.  In both cases, I immediately got two instances of this error message:
buildcfg/00-compiler.mak:164: *** missing 'endif'.  Stop.
Should be an easy one to solve.
In 00-compiler-termux-clang.mak.txt, I commented out a duplicate instance of
ifeq ($(USE_SANI),1)
and that did the trick.  I was able to build with SDL1 just now.  I'll try testing both the SDL1 and SDL2 builds.
Edited by Zendocon
Syntax correction
Both builds are behaving the same way as before.  With my proprietary window manager, the SDL1 build appears in the top left corner with a titlebar, and the SDL2 build appears in the center of the screen with no titlebar.  As for the mouse, with SDL1 the pointer disappears when it's hovered over the window, but not with SDL2.  That may explain the difference in reaction to mouse "input events".
The calls to SDL_ShowCursor in gfx/gfx_sdl2.c control whether jzIntv hides the mouse cursor when it's over the window.  I did change that behavior between SDL1 and SDL2 and was planning on possibly backporting the change to SDL1, actually.
You can try changing them to always hide the mouse (SDL_ShowCursor(SDL_DISABLE)) and see if that improves the stutters you see when the mouse moves.  Or, it's possible you're seeing the freezes these folks also saw: https://github.com/kivy/python-for-android/issues/2169
I still have no idea why it doesn't show you the window border.  I call SDL_SetWindowBordered and set it to SDL_TRUE.  I did see a comment about the Wayland display target lacking client-side window decorations here: https://bugzilla.libsdl.org/show_bug.cgi?id=3948#c3
If you add the command line flag --gfx-verbose, it'll print what video and render driver it's selected.
Yes, that worked.  I made the change in both places.  No more mouse pointer, and no more slowdown when moving the mouse (unless another window gets the focus; wm2 uses the SloppyFocus model).
The window border does appear when the jzintv window has focus.  I'm just not getting a titlebar.  Again, if I switch back to twm, I do get the titlebar, so it's however wm2 gets the title from the SDL2 build.
I forgot to mention, the SDL2 build is still returning 1 when exiting on user request.
I figured out what's going on with that. After printing the "normal exit" message, I call cfg_dtor(), which wipes the value of the exit flag, and leads to me returning 1.  It'll be fixed in the next release.
I do set the window title, initially to "jzintv" in SDL_CreateWindow, and updating later with the cartridge name and year via SDL_SetWindowTitle.
Can you report which video driver and render backend --gfx-verbose report for the SDL2 build?
Edited by intvnut
I dug into the SDL2 source code. On a call to SDL_SetWindowBordered(), if the window manager does not support _MOTIF_WM_HINTS, then the code blindly sets the WM_TRANSIENT_FOR hint regardless of the border enable flag, marking the window as transient (aka. a pop-up dialog).
Looking at the wm2 source code, it won't display the title tab on transient windows, if I understood the code correctly.  And, it doesn't seem to look for the _MOTIF_WM_HINTS, either.
I would say try commenting out the calls to SDL_SetWindowBordered().  However, it appears that won't work:  SDL unconditionally calls the internal SetWindowBordered function as part of X11_CreateWindow.
I don't know how comfortable you are with recompiling SDL2 yourself, and pointing jzIntv to your own SDL2 compile.  But, if you are comfortable with it, we can try a simple hack of commenting out this call to X11_XSetTransientForHint() (or conditionalize it on border == SDL_FALSE) and see if that fixes the issue.
I could also try a hack that just "goes around" SDL's X11 driver and manages the WM_TRANSIENT_FOR property directly on builds that support X11.  This wouldn't be the first place jzIntv went around SDL2 to work around an SDL2 bug.
That would be here.  On MacOS X devices, the Metal graphics backend leaves the target color space unset, resulting in "unmanaged color."  Now, anyone who has participated in the "What are the right colors?" threads might guess, that throws any attempt at getting it correct right out the window.  It might look right on my monitor and wrong on yours.  However, it seems that with a single monitor, it seemed to mostly do the right thing, giving me something like sRGB.  Mostly.
With multiple monitors with different color profiles, the unmanaged mode does seriously weird things.  In particular, the pool of render buffers that Metal uses can end up using a mix of color profiles if you drag the window between monitors.  In the best case scenario, it uses the starting monitor's color profile everywhere.  The colors look right on one monitor, and wrong on the others.  In the worst case scenario, it toggles between the different monitors' color profiles every frame.  The result is a window that shimmers weirdly:  It flickers between multiple different color profiles.  I lost a couple days figuring that one out.
One I figured it out, the fix was simple:  Ask SDL for a pointer to the Metal layer (which fortunately it has a hook for on OS/X), and manually set our color space to the device-independent sRGB color space.  Now when you drag a window between monitors, the colors match and you never get the weird shimmer I mentioned.  That fix is in the recent release.
Now just to add to the fun future possibilities:  I could also set the color space to DisplayP3 instead, and get something that can display the NTSC color gamut, and actually have a chance at correct colors!  But... it requires out-of-range colors passed directly to Metal, and SDL doesn't really support that.  There may be a way around it by abusing palettes and going around SDL2 to create a palette with the full-gamut colors.  But, that's way more science project than I care to bite off, and it only benefits Mac.
I just want to get all the immediate issues causing folks heartburn with jzIntv off my plate so I can stop thinking about jzIntv for a bit and get focused on LTO Flash again.
Edited by intvnut
clarifications, grammar, more links
SDL2 was a readily-available package in Termux, so tweaking that code is something I'd rather not do.  But I did have to tweak the code for wm2 in a few places, just to get it to compile.  I looked at Border::shapeTab and commented out the check for isTransient and recompiled.  No dice.  I'll try a few other places around here.
If the jzintv window is flagged as transient, then that explains why it's showing up in the center of the screen.  I liked it better off to one side, because my script currently draws the box image onto the root window, and pops up a window with the overlay image(s), all using feh.  For games that have multiple overlay images, the jzintv window clips the second overlay (I made a combined image in those cases).
I'm not using any other packages in X that display pop-ups, except maybe emacs-x, so I'm not concerned about inappropriate titlebars.
As for the video driver report you asked about:
gfx:  Searching for video modes near 1088x653x32, Windowed:
gfx:  Window pix format: SDL_PIXELFORMAT_ARGB8888
gfx: Could not create renderer with requested flags: Couldn't find matching render driver
     Trying again with software renderer, no VSync.
gfx:  Selected:  1088x653x32 with:
gfx:      VSync: No, Rend: Software, Windowed: Yes
gfx:      Video Driver: 'x11', Render Driver: 'software'
Ha!  All I had to do was modify this function, starting at line 157.
Boolean Border::isTransient(void)
    return m_client->isTransient();
"return false;" did the trick.  I've got my titlebar back.  Now if I could get it moved away from the center of the screen, I can arrange all the other windows accordingly.
On 7/13/2020 at 7:51 PM, intvnut said:
I've finally uploaded an updated version here.  Release notes:
Release notes for 2020-07-12.  (SVN r2110)
Updates since 2020-06-07.  See ReleaseNotes_20200607.txt for earlier updates.
 New features:
I ported new sources VERY EASILY on the nintendo switch, and it seems to work great.
This time I just had to add a couple of "#ifdef __SWITCH__" in just two files, elfi.c and config.h
Great job!
Trying to build SDL2 (on Ubuntu 16), ended with a 1 for exit status. Probably some pathing problem, can anyone help me get a clue? I grabbed SDL 2.0.12 source and put it into an "SDL2" directory. Thanks!
/tmp/jzintv/src$ sudo make
make: execvp: ./buildcfg/svn_rev.sh: Permission denied
make: execvp: ./buildcfg/svn_dty.sh: Permission denied
make: sdl2-config: Command not found
/bin/sh: 1: sdl2-config: not found
gcc -std=gnu99 -o plat/plat_lib.o -O3  -flto=auto -ffat-lto-objects    -I. -I..    -DUSE_SDL2   -DJZINTV_VERSION_MAJOR=0x01 -DJZINTV_VERSION_MINOR=0x00 -DJZINTV_SVN_REV= -DJZINTV_SVN_DTY= -DUSE_GNU_READLINE -c plat/plat_lib.c
gcc -std=gnu99 -o event/event.o -O3  -flto=auto -ffat-lto-objects    -I. -I..    -DUSE_SDL2   -DJZINTV_VERSION_MAJOR=0x01 -DJZINTV_VERSION_MINOR=0x00 -DJZINTV_SVN_REV= -DJZINTV_SVN_DTY= -c event/event.c
gcc -std=gnu99 -c -O3  -flto=auto -ffat-lto-objects    -I. -I..    -DUSE_SDL2   -DJZINTV_VERSION_MAJOR=0x01 -DJZINTV_VERSION_MINOR=0x00 -DJZINTV_SVN_REV= -DJZINTV_SVN_DTY= -o svn_revision.o svn_revision.c
gcc -std=gnu99 -o plat/plat_sdl.o -O3  -flto=auto -ffat-lto-objects    -I. -I..    -DUSE_SDL2   -DJZINTV_VERSION_MAJOR=0x01 -DJZINTV_VERSION_MINOR=0x00 -DJZINTV_SVN_REV= -DJZINTV_SVN_DTY= -c plat/plat_sdl.c
gcc -std=gnu99 -o plat/main_sdl.o -O3  -flto=auto -ffat-lto-objects    -I. -I..    -DUSE_SDL2   -DJZINTV_VERSION_MAJOR=0x01 -DJZINTV_VERSION_MINOR=0x00 -DJZINTV_SVN_REV= -DJZINTV_SVN_DTY= -c plat/main_sdl.c
gcc -std=gnu99 -o event/event_sdl.o -O3  -flto=auto -ffat-lto-objects    -I. -I..    -DUSE_SDL2   -DJZINTV_VERSION_MAJOR=0x01 -DJZINTV_VERSION_MINOR=0x00 -DJZINTV_SVN_REV= -DJZINTV_SVN_DTY= -c event/event_sdl.c
gcc -std=gnu99 -o event/event_sdl2.o -O3  -flto=auto -ffat-lto-objects    -I. -I..    -DUSE_SDL2   -DJZINTV_VERSION_MAJOR=0x01 -DJZINTV_VERSION_MINOR=0x00 -DJZINTV_SVN_REV= -DJZINTV_SVN_DTY= -c event/event_sdl2.c
gcc -std=gnu99 -o gfx/gfx_sdl2.o -O3  -flto=auto -ffat-lto-objects    -I. -I..    -DUSE_SDL2   -DJZINTV_VERSION_MAJOR=0x01 -DJZINTV_VERSION_MINOR=0x00 -DJZINTV_SVN_REV= -DJZINTV_SVN_DTY= -c gfx/gfx_sdl2.c
gcc -std=gnu99 -o gfx/gfx_scale.o -O3  -flto=auto -ffat-lto-objects    -I. -I..    -DUSE_SDL2   -DJZINTV_VERSION_MAJOR=0x01 -DJZINTV_VERSION_MINOR=0x00 -DJZINTV_SVN_REV= -DJZINTV_SVN_DTY= -c gfx/gfx_scale.c
gcc -std=gnu99 -o gfx/gfx_prescale.o -O3  -flto=auto -ffat-lto-objects    -I. -I..    -DUSE_SDL2   -DJZINTV_VERSION_MAJOR=0x01 -DJZINTV_VERSION_MINOR=0x00 -DJZINTV_SVN_REV= -DJZINTV_SVN_DTY= -c gfx/gfx_prescale.c
gcc -std=gnu99 -o snd/snd_sdl.o -O3  -flto=auto -ffat-lto-objects    -I. -I..    -DUSE_SDL2   -DJZINTV_VERSION_MAJOR=0x01 -DJZINTV_VERSION_MINOR=0x00 -DJZINTV_SVN_REV= -DJZINTV_SVN_DTY= -c snd/snd_sdl.c
gcc -std=gnu99 -o joy/joy_sdl.o -O3  -flto=auto -ffat-lto-objects    -I. -I..    -DUSE_SDL2   -DJZINTV_VERSION_MAJOR=0x01 -DJZINTV_VERSION_MINOR=0x00 -DJZINTV_SVN_REV= -DJZINTV_SVN_DTY= -c joy/joy_sdl.c
gcc -std=gnu99 -o mouse/mouse_sdl.o -O3  -flto=auto -ffat-lto-objects    -I. -I..    -DUSE_SDL2   -DJZINTV_VERSION_MAJOR=0x01 -DJZINTV_VERSION_MINOR=0x00 -DJZINTV_SVN_REV= -DJZINTV_SVN_DTY= -c mouse/mouse_sdl.c
g++ -std=c++14 -o ../bin/jzintv jzintv.o pads/pads_intv2pc.o cfg/cfg.o cfg/usage.o cfg/mapping.o misc/crc32.o misc/crc16.o misc/avl.o misc/ll.o misc/file_crc32.o misc/types.o misc/jzprint.o misc/printer.o plat/plat_lib.o plat/gnu_getopt.o plat/plat_gen.o event/event.o event/event_tbl.o gfx/palette.o gfx/gfx.o mvi/mvi.o debug/debug.o debug/debug_dasm1600.o util/symtab.o debug/source.o periph/periph.o cp1600/cp1600.o cp1600/op_decode.o cp1600/op_exec.o cp1600/emu_link.o cp1600/op_exec_ext.o cp1600/req_q.o cp1600/tbl/fn_cond_br.o cp1600/tbl/fn_dir_2op.o cp1600/tbl/fn_imm_2op.o cp1600/tbl/fn_impl_1op_a.o cp1600/tbl/fn_impl_1op_b.o cp1600/tbl/fn_ind_2op.o cp1600/tbl/fn_reg_1op.o cp1600/tbl/fn_reg_2op.o cp1600/tbl/fn_rot_1op.o cp1600/tbl/formats.o mem/mem.o icart/icart.o icart/icartrom.o icart/icartbin.o icart/icartfile.o icart/icarttag.o icart/icarttag_authors.o icart/icarttag_printer.o stic/stic.o  pads/pads.o pads/pads_cgc.o ay8910/ay8910.o ecs/ecs.o ivoice/ivoice.o speed/speed.o minilzo/minilzo.o file/file.o file/elfi.o lzoe/lzoe.o metadata/metadata.o metadata/cfgvar_metadata.o metadata/icarttag_metadata.o metadata/print_metadata.o bincfg/bincfg.o bincfg/bincfg_grmr.tab.o bincfg/bincfg_lex.o  bincfg/legacy.o gif/gif_enc.o gif/lzw_enc.o demo/demo.o  name/name.o name/name_list.o serializer/serializer.o jlp/jlp.o scale/scale2x.o scale/scale3x.o locutus/locutus.o locutus/luigi.o locutus/locutus_adapt.o locutus/locutus_types.o locutus/loc_to_bin.o locutus/bin_to_loc.o locutus/rom_to_loc.o zlib/deflate.o zlib/adler32.o zlib/trees.o zlib/zutil.o avi/avi.o cheat/cheat.o svn_revision.o plat/plat_sdl.o plat/main_sdl.o event/event_sdl.o event/event_sdl2.o gfx/gfx_sdl2.o gfx/gfx_scale.o gfx/gfx_prescale.o snd/snd_sdl.o joy/joy_sdl.o mouse/mouse_sdl.o -O3  -flto=auto -ffat-lto-objects    -I. -I..    -DUSE_SDL2   -DJZINTV_VERSION_MAJOR=0x01 -DJZINTV_VERSION_MINOR=0x00 -DJZINTV_SVN_REV= -DJZINTV_SVN_DTY=  -lrt -lreadline -ltermcap -Wl,--defsym=setpwent=0 -Wl,--defsym=getpwent=0 -Wl,--defsym=endpwent=0 -Wl,--defsym=getpwuid=0 -Wl,--defsym=getpwnam=0
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans0.ltrans.o: in function `gfx_init.constprop.0':
<artificial>:(.text+0x6661): undefined reference to `SDL_DestroyTexture'
/usr/bin/ld: <artificial>:(.text+0x6676): undefined reference to `SDL_FreeFormat'
/usr/bin/ld: <artificial>:(.text+0x668b): undefined reference to `SDL_DestroyRenderer'
/usr/bin/ld: <artificial>:(.text+0x669f): undefined reference to `SDL_DestroyWindow'
/usr/bin/ld: <artificial>:(.text+0x66d0): undefined reference to `SDL_CreateWindow'
/usr/bin/ld: <artificial>:(.text+0x66f4): undefined reference to `SDL_GetWindowSize'
/usr/bin/ld: <artificial>:(.text+0x66fc): undefined reference to `SDL_GetWindowPixelFormat'
/usr/bin/ld: <artificial>:(.text+0x6706): undefined reference to `SDL_GetPixelFormatName'
/usr/bin/ld: <artificial>:(.text+0x6726): undefined reference to `SDL_CreateRenderer'
/usr/bin/ld: <artificial>:(.text+0x6738): undefined reference to `SDL_GetError'
/usr/bin/ld: <artificial>:(.text+0x675b): undefined reference to `SDL_CreateRenderer'
/usr/bin/ld: <artificial>:(.text+0x676f): undefined reference to `SDL_AllocFormat'
/usr/bin/ld: <artificial>:(.text+0x678a): undefined reference to `SDL_CreateTexture'
/usr/bin/ld: <artificial>:(.text+0x67a4): undefined reference to `SDL_QueryTexture'
/usr/bin/ld: <artificial>:(.text+0x67eb): undefined reference to `SDL_GetRendererInfo'
/usr/bin/ld: <artificial>:(.text+0x67f3): undefined reference to `SDL_GetWindowFlags'
/usr/bin/ld: <artificial>:(.text+0x69d5): undefined reference to `SDL_MapRGB'
/usr/bin/ld: <artificial>:(.text+0x6a11): undefined reference to `SDL_GetNumVideoDisplays'
/usr/bin/ld: <artificial>:(.text+0x6a29): undefined reference to `SDL_ShowCursor'
/usr/bin/ld: <artificial>:(.text+0x6a2e): undefined reference to `SDL_PumpEvents'
/usr/bin/ld: <artificial>:(.text+0x6a3d): undefined reference to `SDL_ShowWindow'
/usr/bin/ld: <artificial>:(.text+0x6a4c): undefined reference to `SDL_RaiseWindow'
/usr/bin/ld: <artificial>:(.text+0x6b69): undefined reference to `SDL_GetCurrentVideoDriver'
/usr/bin/ld: <artificial>:(.text+0x6bf0): undefined reference to `SDL_SetWindowBordered'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans0.ltrans.o: in function `snd_init.constprop.0':
<artificial>:(.text+0x727c): undefined reference to `SDL_OpenAudio'
/usr/bin/ld: <artificial>:(.text+0x77ca): undefined reference to `SDL_BuildAudioCVT'
/usr/bin/ld: <artificial>:(.text+0x7876): undefined reference to `SDL_PauseAudio'
/usr/bin/ld: <artificial>:(.text+0x79ef): undefined reference to `SDL_GetError'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans0.ltrans.o: in function `joy_init.constprop.0':
<artificial>:(.text+0x7c8b): undefined reference to `SDL_NumJoysticks'
/usr/bin/ld: <artificial>:(.text+0x8c64): undefined reference to `SDL_JoystickOpen'
/usr/bin/ld: <artificial>:(.text+0x8c74): undefined reference to `SDL_JoystickName'
/usr/bin/ld: <artificial>:(.text+0x8c96): undefined reference to `SDL_JoystickNumAxes'
/usr/bin/ld: <artificial>:(.text+0x8cab): undefined reference to `SDL_JoystickNumBalls'
/usr/bin/ld: <artificial>:(.text+0x8cc0): undefined reference to `SDL_JoystickNumHats'
/usr/bin/ld: <artificial>:(.text+0x8cd5): undefined reference to `SDL_JoystickNumButtons'
/usr/bin/ld: <artificial>:(.text+0x8ced): undefined reference to `SDL_JoystickGetAxis'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans0.ltrans.o: in function `gfx_refresh.constprop.0':
<artificial>:(.text+0xb6dd): undefined reference to `SDL_MapRGB'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans0.ltrans.o: in function `snd_play_silence.constprop.0':
<artificial>:(.text+0xb8a7): undefined reference to `SDL_LockAudio'
/usr/bin/ld: <artificial>:(.text+0xb929): undefined reference to `SDL_PauseAudio'
/usr/bin/ld: <artificial>:(.text+0xb92e): undefined reference to `SDL_UnlockAudio'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans0.ltrans.o: in function `cfg_init.constprop.0':
<artificial>:(.text+0x11f3c): undefined reference to `SDL_EventState'
/usr/bin/ld: <artificial>:(.text+0x11f48): undefined reference to `SDL_EventState'
/usr/bin/ld: <artificial>:(.text+0x11f54): undefined reference to `SDL_EventState'
/usr/bin/ld: <artificial>:(.text+0x11f6b): undefined reference to `SDL_EventState'
/usr/bin/ld: <artificial>:(.text+0x11f7a): undefined reference to `SDL_EventState'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans0.ltrans.o:<artificial>:(.text+0x11f89): more undefined references to `SDL_EventState' follow
<artificial>:(.text+0x11ffc): undefined reference to `SDL_JoystickEventState'
/usr/bin/ld: <artificial>:(.text+0x12004): undefined reference to `SDL_PollEvent'
/usr/bin/ld: <artificial>:(.text+0x1371e): undefined reference to `SDL_EventState'
/usr/bin/ld: <artificial>:(.text+0x1372d): undefined reference to `SDL_EventState'
/usr/bin/ld: <artificial>:(.text+0x1373c): undefined reference to `SDL_EventState'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans1.ltrans.o: in function `joy_emu_link.lto_priv.0':
<artificial>:(.text+0x5f00): undefined reference to `SDL_JoystickGetButton'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans1.ltrans.o: in function `snd_dtor.lto_priv.0':
<artificial>:(.text+0x5fff): undefined reference to `SDL_CloseAudio'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans1.ltrans.o: in function `snd_fill.lto_priv.0':
<artificial>:(.text+0x6511): undefined reference to `SDL_ConvertAudio'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans1.ltrans.o: in function `snd_tick.lto_priv.0':
<artificial>:(.text+0x8aaf): undefined reference to `SDL_LockAudio'
/usr/bin/ld: <artificial>:(.text+0x8b5e): undefined reference to `SDL_UnlockAudio'
/usr/bin/ld: <artificial>:(.text+0x8c01): undefined reference to `SDL_LockAudio'
/usr/bin/ld: <artificial>:(.text+0x8c25): undefined reference to `SDL_UnlockAudio'
/usr/bin/ld: <artificial>:(.text+0x8c3e): undefined reference to `SDL_LockAudio'
/usr/bin/ld: <artificial>:(.text+0x8c69): undefined reference to `SDL_UnlockAudio'
/usr/bin/ld: <artificial>:(.text+0x8f5d): undefined reference to `SDL_LockAudio'
/usr/bin/ld: <artificial>:(.text+0x8f8b): undefined reference to `SDL_UnlockAudio'
/usr/bin/ld: <artificial>:(.text+0x915b): undefined reference to `SDL_UnlockAudio'
/usr/bin/ld: <artificial>:(.text+0x9348): undefined reference to `SDL_LockAudio'
/usr/bin/ld: <artificial>:(.text+0x935f): undefined reference to `SDL_UnlockAudio'
/usr/bin/ld: <artificial>:(.text+0x955a): undefined reference to `SDL_UnlockAudio'
/usr/bin/ld: <artificial>:(.text+0x956e): undefined reference to `SDL_PauseAudio'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans20.ltrans.o: in function `gfx_toggle_windowed':
<artificial>:(.text+0x5b49): undefined reference to `SDL_SetWindowFullscreen'
/usr/bin/ld: <artificial>:(.text+0x5bb6): undefined reference to `SDL_SetWindowFullscreen'
/usr/bin/ld: <artificial>:(.text+0x5bd0): undefined reference to `SDL_GetNumVideoDisplays'
/usr/bin/ld: <artificial>:(.text+0x5be3): undefined reference to `SDL_ShowCursor'
/usr/bin/ld: <artificial>:(.text+0x5be8): undefined reference to `SDL_PumpEvents'
/usr/bin/ld: <artificial>:(.text+0x5bf1): undefined reference to `SDL_ShowWindow'
/usr/bin/ld: <artificial>:(.text+0x5bfa): undefined reference to `SDL_RaiseWindow'
/usr/bin/ld: <artificial>:(.text+0x5c25): undefined reference to `SDL_GetWindowSize'
/usr/bin/ld: <artificial>:(.text+0x5c81): undefined reference to `SDL_ShowCursor'
/usr/bin/ld: <artificial>:(.text+0x5c86): undefined reference to `SDL_PumpEvents'
/usr/bin/ld: <artificial>:(.text+0x5c8f): undefined reference to `SDL_ShowWindow'
/usr/bin/ld: <artificial>:(.text+0x5c98): undefined reference to `SDL_RaiseWindow'
/usr/bin/ld: <artificial>:(.text+0x5cae): undefined reference to `SDL_ShowCursor'
/usr/bin/ld: <artificial>:(.text+0x5cb3): undefined reference to `SDL_PumpEvents'
/usr/bin/ld: <artificial>:(.text+0x5cbc): undefined reference to `SDL_ShowWindow'
/usr/bin/ld: <artificial>:(.text+0x5cc5): undefined reference to `SDL_RaiseWindow'
/usr/bin/ld: <artificial>:(.text+0x5cd3): undefined reference to `SDL_SetWindowBordered'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans20.ltrans.o: in function `gfx_flip.lto_priv.0':
<artificial>:(.text+0x5d54): undefined reference to `SDL_SetRenderDrawColor'
/usr/bin/ld: <artificial>:(.text+0x5d5c): undefined reference to `SDL_RenderClear'
/usr/bin/ld: <artificial>:(.text+0x5d77): undefined reference to `SDL_RenderPresent'
/usr/bin/ld: <artificial>:(.text+0x5dbc): undefined reference to `SDL_RenderCopy'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans20.ltrans.o: in function `gfx_sdl_abort.lto_priv.0':
<artificial>:(.text+0x5dd6): undefined reference to `SDL_GetError'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans20.ltrans.o: in function `gfx_tick.isra.0.lto_priv.0':
<artificial>:(.text+0x5e47): undefined reference to `SDL_LockTexture'
/usr/bin/ld: <artificial>:(.text+0x5ff1): undefined reference to `SDL_UnlockTexture'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans20.ltrans.o: in function `gfx_refresh':
<artificial>:(.text+0x61f6): undefined reference to `SDL_MapRGB'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans20.ltrans.o: in function `gfx_dtor.lto_priv.0':
<artificial>:(.text+0x6918): undefined reference to `SDL_DestroyTexture'
/usr/bin/ld: <artificial>:(.text+0x692d): undefined reference to `SDL_FreeFormat'
/usr/bin/ld: <artificial>:(.text+0x6942): undefined reference to `SDL_DestroyRenderer'
/usr/bin/ld: <artificial>:(.text+0x6957): undefined reference to `SDL_DestroyWindow'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans20.ltrans.o: in function `plat_quit':
<artificial>:(.text+0x5081): undefined reference to `SDL_Quit'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans20.ltrans.o: in function `main':
<artificial>:(.text.startup+0xda): undefined reference to `SDL_Init'
/usr/bin/ld: <artificial>:(.text.startup+0x4d9): undefined reference to `SDL_SetWindowTitle'
/usr/bin/ld: <artificial>:(.text.startup+0xf3b): undefined reference to `SDL_Delay'
/usr/bin/ld: <artificial>:(.text.startup+0x1276): undefined reference to `SDL_LockAudio'
/usr/bin/ld: <artificial>:(.text.startup+0x188c): undefined reference to `SDL_Delay'
/usr/bin/ld: <artificial>:(.text.startup+0x1ca4): undefined reference to `SDL_PauseAudio'
/usr/bin/ld: <artificial>:(.text.startup+0x1ca9): undefined reference to `SDL_UnlockAudio'
/usr/bin/ld: <artificial>:(.text.startup+0x1dd5): undefined reference to `SDL_GetError'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans22.ltrans.o: in function `speed_tk':
<artificial>:(.text+0x4c5b): undefined reference to `SDL_Delay'
/usr/bin/ld: /tmp/jzintv.VXUZ59.ltrans25.ltrans.o: in function `event_tick.lto_priv.0':
<artificial>:(.text+0x50b2): undefined reference to `SDL_PumpEvents'
/usr/bin/ld: <artificial>:(.text+0x515c): undefined reference to `SDL_PollEvent'
collect2: error: ld returned 1 exit status
make: *** [Makefile:116: ../bin/jzintv] Error 1
You don't need to build jzIntv as root.  Just plain ol' make (or better, make -f Makefile.linux_sdl2) should do
It looks like whatever you used to unzip jzIntv didn't apply the "execute" bit to the scripts in src/buildcfg/, based on this part:
To fix that, run chmod +x buildcfg/*.sh from within the src directory.
For the rest:  jzIntv does not build or install SDL2 for you.  You'll either need to install the SDL2 devel package for your Linux distro, or compile and install SDL2 yourself.  On Ubuntu 16, sudo apt-get install libsdl2-dev should do the trick.  I'm pretty sure installing the "dev" package pulls the main libraries.  If not, sudo apt-get install libsdl2 gets the run time libraries.
The advantage of compiling and installing SDL2 yourself is that you'll get a newer SDL2.  According to this page, Ubuntu 16.04LTS defaults to 2.0.4, while the latest is 2.0.12.
For SDL2, IIRC, you can install it with something along the lines of:
(From within the SDL2-2.0.12 source top-level directory)
$ ./configure --prefix=/usr/local
... lots of configuration goes by ...
$ make -jN
... lots of compilation goes by ...
$ sudo make install
In the sequence above, replace "N" in make -jN with the number of CPUs you have, or a smaller number.  For example, if you 4 CPUs, make -j4 works reasonably well.  You can use Make's -j flag when building jzIntv as well.
On my 4 CPU Linux box, make -j4 brings the compilation time down from about 3 minutes to about 1 min 20 seconds.
BTW, I did a partial release the other day, to incorporate some bug fixes from July.  You can grab that source here:  http://spatula-city.org/~im14u2c/intv/dl/jzintv-20200822-src.zip
Once I get a chance to build R-Pi and Linux builds, I'll make it the official release.  The bugfixes are fairly minor.
Edited by intvnut
To be clear, that's jzIntv's compilation time.  SDL2 actually compiles faster, but they don't enable link-time optimization, and that's somewhat expensive.
I compiled it on my tablet.  It seems wm2 is drawing the window decorations, but with a pixel offset to the right.  I can see just enough of the title bar, but none of the text.  The border across the top extends as many pixels past the right edge of the window.  It's still centered too, but I can deal with that.
Hi all, while playing with source code I just found a different behaviour between Windows SDL1 and SDL2 versions (thanks to event diagnostics)
in SDL2 version, if a key on the keyboard is pressed without release, a continous event KEY_DOWN is sent, while in SDL1 version not.
This does not seem to change the game experience 🙂
