Songbird #51 Posted March 17, 2019 Good work, CJ! I was always bugged by the status bar being off, but never spent time figuring out what made it do that. Also adding in the music is a nice touch -- I had done a quick hack to do it years ago, but noticed it distorted quite a bit, so I just left it off in future builds. I still haven't gotten back to test the networking code I released 2+ years ago in the other thread. It worked flawless for me at the time, but I know at least Saturn reported there were still hang-ups. It's just so time-consuming to test, since you need to prove it will play for 60+ min without messing up. 7 Quote Share this post Link to post Share on other sites
+CyranoJ #52 Posted March 17, 2019 It's just so time-consuming to test, since you need to prove it will play for 60+ min without messing up. Thanks! Hopefully we can get an "ULTIMATE Jaguar Doom" build at some point - I don't think finding testers will be an issue 9 Quote Share this post Link to post Share on other sites
omf #53 Posted March 17, 2019 Good work, CJ! I was always bugged by the status bar being off, but never spent time figuring out what made it do that. Also adding in the music is a nice touch -- I had done a quick hack to do it years ago, but noticed it distorted quite a bit, so I just left it off in future builds. I still haven't gotten back to test the networking code I released 2+ years ago in the other thread. It worked flawless for me at the time, but I know at least Saturn reported there were still hang-ups. It's just so time-consuming to test, since you need to prove it will play for 60+ min without messing up. im not saying it didnt work ok for you but it was tested at e-jagfest 2017 and selecting one of the mode (cant remember wich it was now, maybe co-op) it failed amost instanty this was with using a jaglink. after some fannying about with it it was abondoned as a lost cause and we went back to something more enjoyable that worked properly Quote Share this post Link to post Share on other sites
bmx #54 Posted June 5, 2019 Impressive what can be achived by modding Doom for the Jaguar. I'm curious if the new Romero Level Mod based on Doom 1 (WAD Files) would be playable on the Jaguar? https://www.romerogames.ie/si6il Quote Share this post Link to post Share on other sites
+Saturn #55 Posted June 6, 2019 Impressive what can be achived by modding Doom for the Jaguar. I'm curious if the new Romero Level Mod based on Doom 1 (WAD Files) would be playable on the Jaguar? https://www.romerogames.ie/si6il Briefly discussed it here. I don't think it'd be possible to do the original justice on the Jag. 1 Quote Share this post Link to post Share on other sites
SuperDork3000 #56 Posted June 6, 2019 Cool beans. Any chance you could use the soundtrack from the 3DO version? Quote Share this post Link to post Share on other sites
bmx #57 Posted June 6, 2019 Thanks @Saturn for the reply. Was not able to find it in a quick search. I enjoy every bit of Jag Doom modding 1 Quote Share this post Link to post Share on other sites
Kalani #58 Posted June 11, 2019 So, here's a bit of a write up: The status panel is pretty simple to fix - the game rebuilds the object list each frame on the GPU, simple add an X offset to the low word of the last phrase for both the status panel and the overlay. Job done. Now, the music.... oh boy here we go So, DOOM has a ring buffer for the sample playback (pretty common thing) The problem is that the audio system is designed to have either music OR sfx rendering into this buffer. What I did was have both routines read the previous content of the buffer, ADD the new sample, then normalise again before writing it back. This works... HOWEVER... the sample appear to stutter a bit (the music is rock solid) I've lowered the replay frequency and it still stutters, so this is not down to bandwidth at the playback phase. I have reduced the number of SFX channels to 2, and it still stutters, so its not down to sample rendering. I have had it render both SFX and music, and only send SFX to the DACs - this works I have had it render both SFX and music, and only send MUS to the DACs - this also works So, the issue is clearly in the way I'm mixing the samples here, but the audio code is, frankly, a mess. I've got a good handle on what its doing though so I'll keep playing with it between other things, but have to walk away from this for a while because it's frustratingly almost working, and also frustratingly preventing me working on thrusty and some other stuff. We've waited 20 years, I think we'll be ok for a bit longer. I'm also not convinced this is the final source, because sometimes a level will just end randomly and go to the next. Anyone else seen this with this source? I'm also investigating ripping this crap out and putting the U235SE in, which should give a significant frame rate boost. Are the ExMx midi files available as MODules? If not, maybe a CD audio track could be mixed in. I'm not dropping this, but I am putting it on the back burner for a while so I can get to some other stuff (reBOOTed, Strike) that has to be done. Good progress this week, though sounds like lfo modulation or stereo pan tremelo. Also the sound resolution goes down. Try mono music on one Chanel fx on other. You tried interrupting muting lowest volume the music on dac the sound plays on? Quote Share this post Link to post Share on other sites
+CyranoJ #59 Posted June 11, 2019 sounds like lfo modulation or stereo pan tremelo. Also the sound resolution goes down. Try mono music on one Chanel fx on other. You tried interrupting muting lowest volume the music on dac the sound plays on? The audio doesn't work like that. Appreciate the enthusiasm, but without looking at the source it's a bit worthless. Quote Share this post Link to post Share on other sites
BeefMan #60 Posted July 14, 2019 Still looking forward to this and hoping you can pull it off one day!-Chad 1 Quote Share this post Link to post Share on other sites
+CyranoJ #61 Posted July 22, 2019 It is no longer a b-b-b-b-b-b-b-o-o-o-o-o-m-m-m-m-g-g-g-g-u-u-u-u-n-n-n-n 8 Quote Share this post Link to post Share on other sites
BeefMan #62 Posted July 22, 2019 It is no longer a b-b-b-b-b-b-b-o-o-o-o-o-m-m-m-m-g-g-g-g-u-u-u-u-n-n-n-n Yes! How’d you do it! Anyway I could try it out? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
+CyranoJ #63 Posted July 22, 2019 2 minutes ago, BeefMan said: Yes! How’d you do it! Anyway I could try it out? Magic? No - found a memory hole that allowed me to create a second ring buffer, then broke down the SFX and Music code to render into their own buffers, and mixed them in the output render stage. I've got a bit of cleaning up to do and then we'll see about getting a nice public build of the source available, with fixed panel, network code and music Did you ever find out why some levels just randomly end? That is going to need to be fixed 8 Quote Share this post Link to post Share on other sites
+CyranoJ #65 Posted July 22, 2019 Just now, Saturn said: Awesome! This is your fault 2 1 Quote Share this post Link to post Share on other sites
+Saturn #66 Posted July 22, 2019 Ha, it sounded great. Didn't hear even the hint of a crackle in the music stream(?) while firin Quote Share this post Link to post Share on other sites
BeefMan #67 Posted July 22, 2019 (edited) 21 minutes ago, CyranoJ said: Magic? No - found a memory hole that allowed me to create a second ring buffer, then broke down the SFX and Music code to render into their own buffers, and mixed them in the output render stage. I've got a bit of cleaning up to do and then we'll see about getting a nice public build of the source available, with fixed panel, network code and music Did you ever find out why some levels just randomly end? That is going to need to be fixed I haven’t, it def doesn’t happen with just the Pro Controller support added. Let me review it again this week, I’m sure it can be resolved! What a hell of an achievement! Accomplishing what was seen as impossible for years. Sent from my iPhone using Tapatalk Edited July 22, 2019 by BeefMan 4 Quote Share this post Link to post Share on other sites
Tidus79001 #68 Posted July 22, 2019 Would like to try out this out. Is there a link to download the game? Any plans in physical release of this? I would gladly pay for a physical copy. Awesome job on this achievement. Quote Share this post Link to post Share on other sites
+CyranoJ #69 Posted July 22, 2019 13 minutes ago, Tidus79001 said: Would like to try out this out. Is there a link to download the game? Any plans in physical release of this? I would gladly pay for a physical copy. Awesome job on this achievement. Woah, hold up there partner! Put that six-shooter back in the hoster It's been 25 years, I'm sure a bit longer won't matter 2 Quote Share this post Link to post Share on other sites
Tidus79001 #70 Posted July 22, 2019 (edited) 22 minutes ago, Tidus79001 said: Would like to try out this out. Is there a link to download the game? Any plans in physical release of this? I would gladly pay for a physical copy. Awesome job on this achievement. 8 minutes ago, CyranoJ said: Woah, hold up there partner! Put that six-shooter back in the hoster It's been 25 years, I'm sure a bit longer won't matter Just asking. I wasn't making any demands. I'm just excited (as I am sure are all Atari Jaguar fans) about Jaguar Doom finally being made complete with music and hope that it will eventually be shared with the masses. I'm content to wait for it and pay for a copy. Edited July 22, 2019 by Tidus79001 1 Quote Share this post Link to post Share on other sites
BeefMan #71 Posted July 22, 2019 Just asking. I wasn't making any demands. I'm just excited (as I am sure are all Atari Jaguar fans) about Jaguar Doom finally being made complete with music and hope that it will eventually be shared with the masses. I'm content to wait for it and pay for a copy.We all excited!Sent from my iPhone using Tapatalk 2 Quote Share this post Link to post Share on other sites
BeefMan #73 Posted July 22, 2019 IDDQD Sounds perfect! Sent from my iPhone using Tapatalk 2 Quote Share this post Link to post Share on other sites
7800JAGFAN #74 Posted July 22, 2019 Well I was happy enough with "silent doom", but CyranoJ has apparently done the impossible! Now if this could just be used with some of those levels by Saturn, well it would be the "second coming" of Hell to the Jaguar. 4 1 Quote Share this post Link to post Share on other sites
+Saturn #75 Posted July 22, 2019 That video blew me away. Just amazing! 3 Quote Share this post Link to post Share on other sites
