NickN Posted January 23, 2019 Share Posted January 23, 2019 I bought a composite video to HDMI converter ( https://www.amazon.com/gp/product/B077ZMX4PS/ref=ppx_yo_dt_b_asin_title_o04__o00_s00?ie=UTF8&psc=1 ). No luck connecting the Atari to an HDMI TV though. Does the Atari 800 not have composite out? I'm using the 5 pin DIN cable that has 4 RCA male connectors (Luma, Chroma, Audio, and I thought the black one was composite). I've tried 2 different cables that work fine when connected to the back of my Commodore 1702 monitor. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted January 23, 2019 Share Posted January 23, 2019 I bought a composite video to HDMI converter ( https://www.amazon.com/gp/product/B077ZMX4PS/ref=ppx_yo_dt_b_asin_title_o04__o00_s00?ie=UTF8&psc=1 ). No luck connecting the Atari to an HDMI TV though. Does the Atari 800 not have composite out? I'm using the 5 pin DIN cable that has 4 RCA male connectors (Luma, Chroma, Audio, and I thought the black one was composite). I've tried 2 different cables that work fine when connected to the back of my Commodore 1702 monitor. The Atari 800 has not only composite, but also separate chroma and luma signals. However, not all cables follow the “standard” color assignments for video - I have a couple different Atari DIN video cables and each of them uses a different set of color assignments for composite, chroma, luma and audio, lol. So if you’ve verified your 800 can connect to the 1702 via composite, then that is the signal to connect to your HDMI converter. The real problem here is that many computers and game consoles of the 70’s and 80’s produced not-quite-perfect video signals. Remember, this was analog circuitry creating analog output volages to be fed into analog displays. Lots of room for slop in the hardware at every step of the way, and most displays of the era had a plethora of analog knobs to adjust horizontal and vertical sync, color, brightness, sometimes even screen geometry. Not so with today’s digital display technology. Chances are the Atari video signal isn’t being captured by your HDMI device because it’s not quite “perfect” NTSC video. 1 Quote Link to comment Share on other sites More sharing options...
gozar Posted January 23, 2019 Share Posted January 23, 2019 I bought a composite video to HDMI converter ( https://www.amazon.com/gp/product/B077ZMX4PS/ref=ppx_yo_dt_b_asin_title_o04__o00_s00?ie=UTF8&psc=1 ). No luck connecting the Atari to an HDMI TV though. Does the Atari 800 not have composite out? I'm using the 5 pin DIN cable that has 4 RCA male connectors (Luma, Chroma, Audio, and I thought the black one was composite). I've tried 2 different cables that work fine when connected to the back of my Commodore 1702 monitor. I have an LCD TV/VGA monitor, which usually won't sync until I plug the composite or s-video in a couple of times. While everything is on, try unplugging and plugging in the composite a few times and see if you get a picture. Quote Link to comment Share on other sites More sharing options...
Magic Knight Posted January 23, 2019 Share Posted January 23, 2019 I bought a composite video to HDMI converter ( https://www.amazon.com/gp/product/B077ZMX4PS/ref=ppx_yo_dt_b_asin_title_o04__o00_s00?ie=UTF8&psc=1 ). No luck connecting the Atari to an HDMI TV though. Does the Atari 800 not have composite out? I'm using the 5 pin DIN cable that has 4 RCA male connectors (Luma, Chroma, Audio, and I thought the black one was composite). I've tried 2 different cables that work fine when connected to the back of my Commodore 1702 monitor. Heres what i use as a reference: 3 Quote Link to comment Share on other sites More sharing options...
SoundGammon Posted January 23, 2019 Share Posted January 23, 2019 I use a s-video to hdmi for my 800, also for the 2600, 7800, & the 5200! Quote Link to comment Share on other sites More sharing options...
