Rybags #26 Posted November 24, 2019 Old ISA graphics cards were good for a while but probably better left now for retro PC building. Arcade component suppliers should have plenty of them, I'd not pay more than a few bucks per chip at most (though I have a reasonable stash of my own here). Quote Share this post Link to post Share on other sites
Wrathchild #27 Posted November 25, 2019 (edited) sometimes on some old ISA graphic cards [Edit] Ha, hadn't seen Rybag's post Edited November 25, 2019 by Wrathchild Quote Share this post Link to post Share on other sites
manterola #28 Posted November 25, 2019 (edited) What about this guy? https://www.ebay.com/itm/10x-NEC-UPD41256C-10-D41256-256K-100ns-PAGE-MODE-DRAM-16-DIP/113130079041?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Edit: I am sorry, these are not good for the 600xl without major changes. These that I just posted are 1bit RAM (256k), good for changing those MT damaged ram chips, typically found on 800XL and first revision 65XE. Edited November 25, 2019 by manterola Quote Share this post Link to post Share on other sites
adam242 #29 Posted November 26, 2019 On 11/23/2019 at 10:21 PM, hueyjones70 said: Where is the best source of the xx64 memory chips? I used to buy them from Jameco, but they no longer list them on their website. Quote Share this post Link to post Share on other sites
BillC #30 Posted November 26, 2019 3 hours ago, adam242 said: I used to buy them from Jameco, but they no longer list them on their website. I just searched on Jameco: https://www.jameco.com/z/41464-10-Major-Brands-IC-41464-10-DRAM-256K-Bit-64Kx4-100ns-w-Page-Mode-HY53C464S-10-_41574.html 1 Quote Share this post Link to post Share on other sites
adam242 #31 Posted November 26, 2019 7 hours ago, BillC said: I just searched on Jameco: https://www.jameco.com/z/41464-10-Major-Brands-IC-41464-10-DRAM-256K-Bit-64Kx4-100ns-w-Page-Mode-HY53C464S-10-_41574.html I stand corrected. Was searching for 4464, not 41464. Quote Share this post Link to post Share on other sites
manterola #32 Posted November 26, 2019 When I needed those, I just searched ebay for TMS 4464 and then I just picked one... like this: https://www.ebay.com/itm/10pcs-TMS4464-10NL-TMS4464-DIP-18-TI/180920063287?hash=item2a1fad1537:g:7RoAAMXQ0pNRvcsR Quote Share this post Link to post Share on other sites
+DrVenkman #33 Posted June 25, 2020 Necro-ing this old topic to report that I used @Mathy's instructions linked in one of the posts above to upgrade one of my 600XL's tonight. I know it's an easy mod, but it's still always nice when something works the first time. For the replacement memory, I used some NEC 41464-10 chips I bought on eBay over a year ago. I just never got around to this upgrade until this afternoon. 4 Quote Share this post Link to post Share on other sites
Kyle22 #34 Posted June 26, 2020 (edited) Solder 3 wires, put in 4464's then install Ultimate 1 Meg. That will get you going. Look for the up and coming SIDE3. Edit:Also, do something about the video. Edited June 26, 2020 by Kyle22 Quote Share this post Link to post Share on other sites
cwilbar #35 Posted June 26, 2020 I did it the 'hard way' 🙂 I modified the system such that no chips are soldered to. Changes on the bottom, changes under a chip socket or two, and now it's as if it was 64K from Atari. Chip fails, pop in a replacement chip. In retrospect I think I should have just used the 64K SRAM that IIRC goes between the cpu and socket. Then you can pull several components from the PCB as they aren't needed anymore. But I still like the way it turned out.... but it was a real pain when I discovered I had to pull one or two chip sockets to separate a connection I didn't know were hiding under there 🙂 Quote Share this post Link to post Share on other sites
+DrVenkman #36 Posted June 26, 2020 6 hours ago, cwilbar said: In retrospect I think I should have just used the 64K SRAM that IIRC goes between the cpu and socket. I know Lotharek makes one now but even then you need to solder at least one wire to the MMU or a nearby via. His site also said that some upgrades might need you to solder a second wire. Seems to me that if you’re soldering wires anyway, might as well go with the one that’s cheaper - which in this case was these memory chips ($3.09 on eBay last year for a lot of five chips ). 4 Quote Share this post Link to post Share on other sites
+hueyjones70 #37 Posted November 1, 2020 I saw a mention of a 256K RAM upgrade on the Best Electronics web site. Has anyone have any experience/knowledge with it? Quote Share this post Link to post Share on other sites
hloberg #38 Posted November 2, 2020 here's my write up of adding 64k to my Atari 600XL I just did. Not all that bad to do. I tried to be very detailed. Quote Share this post Link to post Share on other sites
+slx #39 Posted November 2, 2020 Thanks for sharing and taking the time to document. 1 Quote Share this post Link to post Share on other sites
