senior_falcon Posted January 29, 2019 Share Posted January 29, 2019 It has been a number of years since I have used my real TI99. In getting it going again, I have been having problems communicating with the expansion box. I suspect that one of the wires in the "firehose" has broken because when I manipulate the cable just right then disk access is restored. I have tried re-seating the connector, which doesn't seem to do anything. But moving the wires around right where they come out of that giant connector and make a sharp bend back towards the PE box (right where a broken wire is most likely) can sometimes get things working again, but not for long. I remember coming to this same conclusion years ago when the computer was being difficult. Has anyone else experienced this? Quote Link to comment Share on other sites More sharing options...
FDOS Posted January 29, 2019 Share Posted January 29, 2019 It has been a number of years since I have used my real TI99. In getting it going again, I have been having problems communicating with the expansion box. I suspect that one of the wires in the "firehose" has broken because when I manipulate the cable just right then disk access is restored. I have tried re-seating the connector, which doesn't seem to do anything. But moving the wires around right where they come out of that giant connector and make a sharp bend back towards the PE box (right where a broken wire is most likely) can sometimes get things working again, but not for long. I remember coming to this same conclusion years ago when the computer was being difficult. Has anyone else experienced this? No, I haven't experience that, but I have had to replace parts on the circuit board of the TI connector end. I have three, so I could spare one, but I haven't tested the other two in about 15 years, and right now I'm using my only working PEB for a problem with my SNUG TI-99/4P (no "fire hose" in use). I could send that one because it was in use a few months back. However, it may be the one I up-graded (for speed) years ago. I won't be testing them all for some time, but if you want to take the chance, I could send you one of the two spares or both, if one works return the other or both, if neither works return both. Bill 1 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted January 30, 2019 Author Share Posted January 30, 2019 No, I haven't experience that, but I have had to replace parts on the circuit board of the TI connector end. I have three, so I could spare one, but I haven't tested the other two in about 15 years, and right now I'm using my only working PEB for a problem with my SNUG TI-99/4P (no "fire hose" in use). I could send that one because it was in use a few months back. However, it may be the one I up-graded (for speed) years ago. I won't be testing them all for some time, but if you want to take the chance, I could send you one of the two spares or both, if one works return the other or both, if neither works return both. Bill That's very kind of you. I will take a close look at my cable over the weekend. Maybe there is a solder joint that needs attention, or if a wire is broken I might be able to remove a couple of inches of cable to eliminate the break. Will keep you posted. Thanks! 3 Quote Link to comment Share on other sites More sharing options...
Fritz442 Posted January 30, 2019 Share Posted January 30, 2019 That's very kind of you. I will take a close look at my cable over the weekend. Maybe there is a solder joint that needs attention, or if a wire is broken I might be able to remove a couple of inches of cable to eliminate the break. Will keep you posted. Thanks! Yes you can, I have repaired a few cables by removing 1-2 inches then re-clamping it. 2 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted January 30, 2019 Author Share Posted January 30, 2019 Yes you can, I have repaired a few cables by removing 1-2 inches then re-clamping it. So you have seen this in the TI expansion box cable? Quote Link to comment Share on other sites More sharing options...
Fritz442 Posted January 30, 2019 Share Posted January 30, 2019 (edited) So you have seen this in the TI expansion box cable? Yes, I received a PEB in the mail(not package well) where the rear corner landed on the cable and cut into it about 6 in from the end. I simply removed the large connector, cut off about 7 in and reconnected the cable. Just trim the outer black rubber to match the end of the original cable. Here's what it looks like, the bottom one still with the cable attached. Just carefully release the blue top part and peel the cable out from all the little teeth, then center the cable into the top blue connector inside the small tabs and grooves. I use a small vice to push the blue part back down, but you can use 2 small strips of wood and pliers. Edited January 30, 2019 by Fritz442 2 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted January 31, 2019 Author Share Posted January 31, 2019 (edited) Thanks! That looks easy enough. I would do it tonight but it is too darn cold to go to the shop for the tools I need. Should be warmer this weekend. You Canadians are probably laughing about what wimps we are in the states when a little cold weather sets in. Edited January 31, 2019 by senior_falcon 5 Quote Link to comment Share on other sites More sharing options...
JB Posted January 31, 2019 Share Posted January 31, 2019 You Canadians are probably laughing about what wimps we are in the states when a little cold weather sets in.On the other hand, I'm way down near the bottom of the US, and your idea of warmer weather is my "too darn cold". Perhaps even "godforsaken niflheim." So no laughing here. 2 Quote Link to comment Share on other sites More sharing options...
Airshack Posted March 26, 2019 Share Posted March 26, 2019 Thanks! That looks easy enough. I would do it tonight but it is too darn cold to go to the shop for the tools I need. Should be warmer this weekend. You Canadians are probably laughing about what wimps we are in the states when a little cold weather sets in. I’m guessing plenty of Canadians live south of your neck of the woods. In Detroit they drive south to visit Canada. Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
