hizzy
Easy 78 Input/Output Board
Hi, Folks!
I was curious to see if anyone has given Ed Laddin's Easy 78 Input/Output board a try. It looks like a nice way to wire up a custom 7800 controller. I've attached a link to the board in the AA store, along with a photo.
https://atariage.com/store/index.php?l=product_detail&p=1077
Do the wires go through the holes on the board? Would you solder and trim them up on the other side?
Thanks in advance for the feedback!
Hi, Folks!
Yes, Looks like it shouldn't matter if you go through the top or the bottom.
When you tin the wire, use flux on the wire to make it easier to get the solder to stick to the wire.
The manual is pretty easy to follow:
https://atariage.com/store/images/edladdin/easy-78-instructions.pdf
Thanks for the reply! Have you tried one of these yourself?
