ErkTheJerk Posted February 27, 2019 Share Posted February 27, 2019 Hello, I purchased a Vader system today. After playing with it for 10 minutes with pitfall the screen has slowly turned orange? And then 30 minutes has turned brown? When I turn off the system and turn it back on it is normal or green. Then itll repeat. Is there anyway I can fix this? Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted February 27, 2019 Share Posted February 27, 2019 I deleted the 2 extra threads you posted, would you please be so kind and remove the image from your signature? Cheers. Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted February 27, 2019 Share Posted February 27, 2019 Here's another link where someone had a similar problem. Could be the power supply failing under pressure. http://atariage.com/forums/topic/268918-changing-colors-and-other-issues/ 1 Quote Link to comment Share on other sites More sharing options...
ErkTheJerk Posted February 27, 2019 Author Share Posted February 27, 2019 I deleted the 2 extra threads you posted, would you please be so kind and remove the image from your signature? Cheers. Hello Im not sure what youre talking about? Quote Link to comment Share on other sites More sharing options...
ErkTheJerk Posted February 27, 2019 Author Share Posted February 27, 2019 Here's another link where someone had a similar problem. Could be the power supply failing under pressure. http://atariage.com/forums/topic/268918-changing-colors-and-other-issues/ Quote Link to comment Share on other sites More sharing options...
ErkTheJerk Posted February 27, 2019 Author Share Posted February 27, 2019 Thanks! Quote Link to comment Share on other sites More sharing options...
ErkTheJerk Posted February 27, 2019 Author Share Posted February 27, 2019 Oh I dont know why it is double posting? Quote Link to comment Share on other sites More sharing options...
ErkTheJerk Posted February 27, 2019 Author Share Posted February 27, 2019 I deleted the 2 extra threads you posted, would you please be so kind and remove the image from your signature? Cheers. Do you mean signature from my image? Im not sure what you mean and also I dont know how to delete the double post Im posting using an iPhone and theres no option to delete things. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted February 27, 2019 Share Posted February 27, 2019 Do you mean signature from my image? Im not sure what you mean and also I dont know how to delete the double post Im posting using an iPhone and theres no option to delete things. Are you using Tap a talk? I believe it is known to cause double posting here at AA all the time and it is advised to NOT use that when posting messages here. As for your issue, it could be the power supply, but I've also seen faulty TIA chips do this as well. Are you using an actual OEM power supply with your 2600 Vader unit? Console5 has a good replacement power supply for use with 2600s that matches all the OEM specs for pretty cheap: https://console5.com/store/power-supply-adapter-for-atari-2600-and-atari-dedicated-systems.html Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted February 27, 2019 Share Posted February 27, 2019 Hello Im not sure what youre talking about? A.) You posted this thread 3 times, I deleted 2 of them. B.) I have now removed the picture from your signature. Quote Link to comment Share on other sites More sharing options...
ErkTheJerk Posted February 27, 2019 Author Share Posted February 27, 2019 Are you using Tap a talk? I believe it is known to cause double posting here at AA all the time and it is advised to NOT use that when posting messages here. As for your issue, it could be the power supply, but I've also seen faulty TIA chips do this as well. Are you using an actual OEM power supply with your 2600 Vader unit? Console5 has a good replacement power supply for use with 2600s that matches all the OEM specs for pretty cheap: https://console5.com/store/power-supply-adapter-for-atari-2600-and-atari-dedicated-systems.html Im using a really old iPhone using safari. Well Im using an old beige adapter that was for a Atari pong system. I tested this on a 4 switcher and its normal. Its a 9v output and a 120v input. If thats not the problem... Could the Vader system be from over seas? Quote Link to comment Share on other sites More sharing options...
