Sign in to follow this
Paul Westphal
Midi Maze - STe - 800xl - Will it Work?
Hi Ya'all!
I have the Midi Mate and Midi Maze Prototype on cart for the 800xl.
4mb STe with Midi Maze on floppy ( on the Lotharek SD Drive as well )
Plenty of Midi cables.
Has anyone tried this? and if so, how many Computers will it handle?
I have two Midi Mates so I could link up at least three computers at once..
Thanks,
PAul
It works. The key for me is to have the 8-bit host though. If I host on an ST the connection seems to drop like mad.
When I fired up the STe with the midi floppy, it was set as a slave. Ill get to it this week and report back. Looking forward to it! Thanks for the replies guys😀
I wonder if the problem is SIO-to-MIDI on the Atari 8-bits is too slow. Maybe they should use a 6551 or 6850 mod to run MIDI to improve performance.... of course, they'd have to hack A8 MIDI Maze to support that...
Then again, MIDI transfer doesn't seem to be a problem with the newer project 1088XEL and 1088XLD homebrew motherboards:
But more importantly, why isn't MIDI Maze on the Lynx yet??? Or the Jag?
That's friggon' Awesome! Thanks for the reply!
Now I'm wondering if they could do an ST port to the Jaguar and code it for the Jaglink. :)
Posted (edited)
They could if they had permission from the author. That's been mentioned as an issue over in the Jaguar area of this site.
But then again, has anyone made a JagLink - or CatBox Link - to MIDI cable? So the Jag could be hooked up to a MIDI Maze ring of STs and A8s?
Apparently, there's a controller chip in the modern A8 MIDI adapters that does the transfer processing so there's no need for a Motorola 6850 or MOS/Synertek/Rockwell 6551 to assist/improve upon the MIDI/serial transfer duties...
Notice the 1088XLD is installed inside that 1050 Disk Drive case...
Edited by Lynxpro
