Sign in to follow this
Falter
Atari 800 White Screen of Nothing
Hey guys,
So I'm trying to figure out this early 800 I have and so far nada. You power on, and with the composite out you get a solid white screen - the TV output just gives you a little less static.
Nothing really seems to change matters, cartridge in, cartridge out. I even have a spare OS cart but nothing there either. I've removed and reseated every chip in the thing. I've checked the RAM chips in another computer that uses them. I've even taken a DMM and, with the cards plugged in one at a time, confirmed continuity between the topmost part of the card 'teeth' and the bottom where the socket pin is soldered in. Kind of dizzying work and I *may* have missed one, but all that I tested came back ok.
I'm wondering if I should just buy a known good motherboard from Ebay or something just to test with, or a complete system... just to see if the cards are any good.
When I first got a power supply for it it was doing something similar and if you pressed on the OS ROM card with a bit of force it'd work. I figured maybe the socket needed cleaning to so I did more cleaning but after that it was white screen of death forever.
Would be grateful for any suggestions/advice.
I have a drop in replacement sitting on my benchpost-31298-0-48146600-1552450393_thumb.jpeg
Tested with SuperSalt and running great. It was a 800 I bought off Ebay.
Arrived in pieces, as did the 810.
Caps are good and I cleaned it Well with Qtips and rubbing alcohol. ( as usual )
Edited by Paul Westphal
Thank you.. I did a purchase on ebay and will see but if yours is still available I may come back to you. Appreciate the offer!
I have a drop in replacement sitting on my bench 5470F329-2F92-4AD5-A6DE-E68D9D8BBFA3.jpeg
