ppelleti Posted March 30, 2019 Share Posted March 30, 2019 Just wanted to double-check that my understanding of pin numbers on the cartridge port (see attached photos) is correct, based on the pin numbering given here: http://wiki.intellivision.us/index.php?title=Cartridge_Port In particular, the pin numbers seem to have the opposite "chirality" of the pin numbering given on this data sheet for a modern card edge connector: http://www.edac.net/dat/files/109.pdf (middle of the second page on the PDF) So, to have a footprint I can use for plugging in an Intellivision cartridge, I need to swap the even and odd pins from what is shown in the datasheet, correct? I just wanted a second set of eyes to double-check my conclusions, because I've managed to confuse myself about this before, and I'd rather not fry a cartridge if I can help it. Thanks! Quote Link to comment Share on other sites More sharing options...
mr_me Posted March 30, 2019 Share Posted March 30, 2019 (edited) I think the labels in the photos are correct. The numbering has to match the old Mattel schematics. Keep in mind that the original intellivision main board is installed upside down. The cartridge loopback/rainbow lines should be facing up. Anyone knows what happens if you insert a cartridge upsidedown. Edited March 30, 2019 by mr_me Quote Link to comment Share on other sites More sharing options...
+BBWW Posted March 30, 2019 Share Posted March 30, 2019 Anyone knows what happens if you insert a cartridge upsidedown. I think the game plays backwards. Quote Link to comment Share on other sites More sharing options...
intvnut Posted March 31, 2019 Share Posted March 31, 2019 I think the labels in the photos are correct. The numbering has to match the old Mattel schematics. Keep in mind that the original intellivision main board is installed upside down. The cartridge loopback/rainbow lines should be facing up. Anyone knows what happens if you insert a cartridge upsidedown. Having done this accidentally several times now, "not much." I thankfully have not damaged the unit or any board I've plugged in backward. I wouldn't recommend it, though. Just wanted to double-check that my understanding of pin numbers on the cartridge port (see attached photos) is correct, based on the pin numbering given here: http://wiki.intellivision.us/index.php?title=Cartridge_Port In particular, the pin numbers seem to have the opposite "chirality" of the pin numbering given on this data sheet for a modern card edge connector: http://www.edac.net/dat/files/109.pdf (middle of the second page on the PDF) So, to have a footprint I can use for plugging in an Intellivision cartridge, I need to swap the even and odd pins from what is shown in the datasheet, correct? I just wanted a second set of eyes to double-check my conclusions, because I've managed to confuse myself about this before, and I'd rather not fry a cartridge if I can help it. Thanks! Yes, your images look correct. Note that cartridges go "component side up." I don't know why the Wiki has such small versions of these images. They're from my old Intellivision tech page. It appears they took the thumbnails rather than the full size pics: I always mark pin 2 on my board designs. You can see it down in the lower right corner of my JLP03, JLP04 and LTO Flash boards. 1 Quote Link to comment Share on other sites More sharing options...
carlsson Posted April 1, 2019 Share Posted April 1, 2019 (edited) Yes, some of us have inserted our LTO! Flash cartridges upside down without causing any apparent damage to either the cartridge or console. Once you've made the mistake though, you are likely to put a label on the cartridge shell, in particular if you don't use it daily. Edited April 1, 2019 by carlsson Quote Link to comment Share on other sites More sharing options...
