fluxit Posted February 20, 2020 Share Posted February 20, 2020 There's a small control inconsistency in the launcher UI. I don't know if it can(or should as I'm not sure what's intended) be fixed by simply remapping or not. A 9 pin joystick plugged into the front ports allows one to select a game line by line by using the up and down directions, or page by page using left and right. The same is true of a USB keyboard's cursor keys. With a wireless USB controller on the other hand, the left thumb-stick works as expected in the UI, but the dpad will only do line by line. Left and right on the dpad in the UI does nothing. FWIW, the right thumbstick doesn't do anything at all in the UI. I see from "jstest" on my computer that the Mayflash adapter I'm using maps left thumbstick to axis 0 and 1, dpad to axis 4 and 5, and right thumbstick to axis 2 and 3 respectively. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted February 20, 2020 Share Posted February 20, 2020 You have to map UINavPrev and UINavNext to the axis you want to use for paging. Quote Link to comment Share on other sites More sharing options...
fluxit Posted February 20, 2020 Share Posted February 20, 2020 Hmmm. Is that in the options? I don't see it. I've gone over every single list and tab a few times at least. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted February 20, 2020 Share Posted February 20, 2020 Sorry, UINavPrev and UINavNext are code variables. You can find them in (Advanced)Options/Input/UI Events named PageUp and PageDown. Quote Link to comment Share on other sites More sharing options...
Hoessi666 Posted March 15, 2020 Share Posted March 15, 2020 I am having Problems with SCRAMBLE and SUPER COBRA ARCADE: In both Games the "Air-to-Ground"-Shot does not work! On my PC it all works flawlessly, but on the Retron (with Beta2- and actual RC1-Firmware) I can only shoot straight forward and not hitting the Ground-Targets... Is this a Bug or do i have to change some Preferences for the Games? All other Games (also ARM-based Games like DRACONIAN) don't seem to have Problems (at least from what I've seen until now). Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted March 15, 2020 Share Posted March 15, 2020 I suppose you are not using a Sega Genesis controller, correct? Then open the settings and change the controller into "Joystick" Quote Link to comment Share on other sites More sharing options...
Hoessi666 Posted March 15, 2020 Share Posted March 15, 2020 (edited) Yes, I'm using the Standard-Joystick that came with the Console. Strange that those Games are set to the "Sega Genesis"-Controller by Default on the Retron... With the "Joystick"-Option it works, Thanx! Edited March 15, 2020 by Hoessi666 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted March 15, 2020 Share Posted March 15, 2020 (edited) That's happening with the latest PC Stella too. Stella checks which controller the game supports and makes it available. And the game checks, if a Genesis controller is available and uses it then. So the two auto detections clash here. Edited March 15, 2020 by Thomas Jentzsch Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted March 15, 2020 Share Posted March 15, 2020 Same issue will occur with Stay Frosty 2, if you don't switch it to Joystick then you won't be able to throw snowballs and thus get stuck on level 4. Quote Link to comment Share on other sites More sharing options...
+stephena Posted March 15, 2020 Share Posted March 15, 2020 I think we should manually set "Joystick" for these games. While it's good that Genesis autodetection is working, I believe the vast majority of people won't be using such a controller. So it makes sense to cater to those people. EDIT: By 'we', I meant that the Stella team should change the settings in the released version of Stella, so that each user doesn't have to. 1 Quote Link to comment Share on other sites More sharing options...
+stephena Posted March 15, 2020 Share Posted March 15, 2020 1 hour ago, SpiceWare said: Same issue will occur with Stay Frosty 2, if you don't switch it to Joystick then you won't be able to throw snowballs and thus get stuck on level 4. @SpiceWare, I just realized that we don't have a ROM properties entry for Stay Frosty 2 in Stella. As such, we can't make an exception for this game to use Joystick by default. Did you ever release the ROMs for this game? If so, please provide them, as well as any info you want in the database. We're planning a new release by the end of the coming week, so it would be great to get this updated before then. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted March 15, 2020 Share Posted March 15, 2020 1 hour ago, stephena said: @SpiceWare, I just realized that we don't have a ROM properties entry for Stay Frosty 2 in Stella. As such, we can't make an exception for this game to use Joystick by default. Did you ever release the ROMs for this game? If so, please provide them, as well as any info you want in the database. We're planning a new release by the end of the coming week, so it would be great to get this updated before then. Here's the ROMs, they were released here for the High Score Club. SF2_20131217_RC8_NTSC.bin SF2_20131217_RC8_PAL.bin Properties: "Cart.MD5" "541cac55ebcf7891d9d51c415922303f" "Cart.Manufacturer" "SpiceWare - Darrell Spice Jr." "Cart.ModelNo" "SW-05" "Cart.Name" "Stay Frosty 2" "Cart.Note" "AtariAge Holiday Greetings 2014" "Cart.Rarity" "Homebrew" "Controller.Left" "JOYSTICK" "Display.Phosphor" "YES" "" "Cart.MD5" "791c88eca9836af8c34bf32b07cb58a7" "Cart.Manufacturer" "SpiceWare - Darrell Spice Jr." "Cart.ModelNo" "SW-05" "Cart.Name" "Stay Frosty 2 (PAL60)" "Cart.Note" "AtariAge Holiday Greetings 2014" "Cart.Rarity" "Homebrew" "Controller.Left" "JOYSTICK" "Display.Format" "PAL60" "Display.Phosphor" "YES" "" 1 Quote Link to comment Share on other sites More sharing options...
+stephena Posted March 15, 2020 Share Posted March 15, 2020 1 hour ago, SpiceWare said: Here's the ROMs, they were released here for the High Score Club. OK, thanks for the info; I'll get it added in a moment. In the future, it might be better to release the ROMs named with the actual format. So instead of 'PAL', please use 'PAL60'. That way Stella can detect the PAL60, and you don't need a properties entry for it at all. This is a new feature coming in 6.1. 1 1 Quote Link to comment Share on other sites More sharing options...
DonValor Posted April 2, 2020 Share Posted April 2, 2020 On 2/15/2020 at 3:38 PM, DirtyHairy said: Thanks for your report! Yes, this sounds like frame skipping --- I have ran into that several times during firmware development, but I thought we had been able to resolve this for good. I'll investigate... ? Just wanted to let everyone know that I've upgraded to the latest release and I'm no longer experiencing the frame skipping issue! Also, the new font is MUCH easier to read! Much thanks to everyone involved! 2 Quote Link to comment Share on other sites More sharing options...
unixdude Posted April 6, 2020 Share Posted April 6, 2020 Is there any chance a 64MB image exists, or is there maybe a way to reduce the size of the existing image from ~80MB to 64MB? I have a 64MB micro SD chip I'd like to use. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted April 6, 2020 Share Posted April 6, 2020 Nope. Quote Link to comment Share on other sites More sharing options...
BitMerge6502 Posted April 6, 2020 Share Posted April 6, 2020 I just installed v6.1, I love the new fonts & layout options. I am having one issue though: my input settings are not saving when I exit the options menu, and are reset to defaults when I power cycle the console. I noticed there is no .cfg file on the SD card in the config folder. If I make one (or edit one from mainline Stella 6 build), will the R77 use it instead as the default? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted April 6, 2020 Share Posted April 6, 2020 Try to delete the sqlite files. 1 Quote Link to comment Share on other sites More sharing options...
unixdude Posted April 6, 2020 Share Posted April 6, 2020 1 minute ago, Thomas Jentzsch said: Try to delete the sqlite files. Thanks, yeah, I can rsync my files onto a smaller drive, but it appears that there's some sort of special formatting or special file allocation that isn't getting copied when I make my own FAT16 image with the same files. I'm not sure what I'm doing wrong. This isn't a huge deal, but if I can reallocate the 32GB card that's in my RetroN77, I have a tiny 64MB card that would have space left over, and I'd love to be able to use that for the R77. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted April 6, 2020 Share Posted April 6, 2020 That was the answer for BitMerge6502, not for you. 64MB is not enough, sorry. 1 Quote Link to comment Share on other sites More sharing options...
BitMerge6502 Posted April 6, 2020 Share Posted April 6, 2020 52 minutes ago, Thomas Jentzsch said: Try to delete the sqlite files. As to be expected, deleting the database files reset all of my settings, however, If I try to change any of my inputs, it still resets to the defaults after power cycle. All I'm trying to do with the input settings is erase the mapping for "Color/BW toggle" (F4), and then map "screenshots" from the default F12 to F4 (physical color/bw button on back of R77). It works intil I turn the power off. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted April 6, 2020 Share Posted April 6, 2020 Sounds like a bug. We will look into this when time permits. Quote Link to comment Share on other sites More sharing options...
BitMerge6502 Posted April 6, 2020 Share Posted April 6, 2020 Just now, Thomas Jentzsch said: Sounds like a bug. Well, thanks for the help. Everything else looks good so far. I like that We're getting into the "fine tuning" phase with the firmware. Quote Link to comment Share on other sites More sharing options...
BitMerge6502 Posted April 6, 2020 Share Posted April 6, 2020 I guess one option for those who want to add more physical buttons to the console, but do not want to lug around a USB keyboard, could be to use an Arduino Leonardo (or compatible) connected to the internal USB of the R77 & drill more buttons into the back of the console. Quote Link to comment Share on other sites More sharing options...
ozyr Posted April 9, 2020 Share Posted April 9, 2020 Question for Stella running on the Retron 77. Could this make a game easier to play (slowed down or such via Stella)? I ask, as I need to know, but don't own a Retron 77. Quote Link to comment Share on other sites More sharing options...
