mksmith
Atari Dev Studio for Homebrew Development [Release]
Which language do you develop with using Atari Dev Studio?
48 members have voted
  1. 1. Which language do you develop with using Atari Dev Studio?
    • batari Basic
      25
    • 7800basic
      14
    • dasm (assembly)
      17
Welcome to Atari Dev Studio for designing homebrew games for the Atari 8-bit systems (Atari 2600 and 7800). Atari Dev Studio is a one-stop-shop for any programmer and includes a number of built-in features to allow you to design, develop and test games for your favourite system. Get started with batari Basic (2600) or 7800basic (7800) using easy to learn BASIC-like languages or go hard-core with assembly using dasm. During development test your creation using the Stella (2600) or A7800 (7800) emulators right from within Atari Dev Studio.
Requirements
Atari Dev Studio is an extension for Microsoft's cross-platform IDE Visual Studio Code and will run on the Windows, Linux and macOS platforms. The latest releases of batari Basic, 7800basic, dasm, Stella and A7800 are included so you can begin coding straight after installing the extension.
Atari Dev Studio includes the following features:
  • Develop your game on Windows, Linux or macOS
  • Compile source code for your Atari 2600 or 7800 using batari Basic, 7800basic or dasm
  • Use scripting (makefile, batch or shell script files) to build your dasm projects [preview]
  • Optionally launch and test your game using the Stella (2600) or A7800 (7800) emulators
  • Document outline support (batari basic, 7800basic, dasm)
  • Peek/Go to Definition and Reference support (batari basic, 7800basic, dasm)
  • Built-in Sprite Editor (also suitable for tiles and other objects) [preview]
  • Manage your project using the File Explorer or version-control your source code directly with GitHub (and others) using the built-in features of the Visual Studio Code platform.
  • Provide references to your own specific releases of each language or emulator rather than use the includes ones via the Settings.
Additional features are planned for the future. At this time the focus is on the core functionality and ensuring full cross-platform support.
Installing Atari Dev Studio
What is Visual Studio Code?
Visual Studio Code (VS Code) is a streamlined code editor with support for development operations like debugging, task running, and version control. It aims to provide just the tools a developer needs for a quick code-build-debug cycle and leaves more complex workflows to fuller featured IDEs, such as Visual Studio.
Which OSs are supported?
VS Code is a cross-platform application which runs on Windows, Linux and macOS. See requirements for the supported versions.
Note: Linux users on 64-bit systems will be required to install the 32-bit compatibility libraries on your system to ensure everything will run as expected.
Note: macOS users will require a 64-bit operating system to fully utilise all features of Atari Dev Studio and will be required to install the SDL libraries on your system to ensure the A7800 emulator will run as expected.
Installing the extension
Once you have installed VS Code (available here), open the VS Code program and complete the following:
  • From the Activity Bar, click the Extensions button to display the Extensions window.
  • From the Extensions window, type Atari into the Search box and press Enter to display the list of available extensions.
  • From the list of available extensions, locate Atari Dev Studio and click the green Install button.
Updating the extension
Updates will be regularly provided and you will be notified via VS Code when one has been made available. Once an update has been installed you will generally be prompted to restart VS Code.
Using Atari Dev Studio
Compiling your program
To display the available extension features press CTRL+SHIFT+P to display the Command Palette. From the command palette prompt type adv to short-list the available options:
  • ads: Open the Welcome page
  • ads: Compile source code (Shift+F5)
  • ads: Compile source code and run in emulator (F5)
  • ads: Kill build process
  • ads: Open the Sprite Editor
Language Selection
When you load a file the initial language will be chosen based on the file extension. For example:
  • batari Basic (.bas, .bb) [Default for .bas files]
  • 7800basic (.bas, .78b)
  • dasm (.dasm, .asm, .a, .h)
To change a language you can click on the Status Bar Language selector and a list will be shown allowing you to choose another language. Optionally in the Settings you will be able to either let the extension choose based on the active language or set a specific language to always compile against.
Build scripts [preview]
Prefer using scripts to build your dasm games? If you have chosen to override the dasm compiler (select Make via the Settings) , Atari Dev Studio will scan and detect for makefile, batch (makefile.bat) or shell scripts (makefile.sh) files which are located in your root workspace folder to build your game.
Note: You are totally responsible to ensure your environment is properly configured to allow you to utilise the tools and applications you will be interacting with. No support will be provided for this feature.
Status Bar
Apart from using the Command Palette to select compilation, there are a number of short-cut buttons on the Status Bar allowing you to:
  • Display the extension version (might be useful at times)
  • Open the Welcome page
  • Open the Sprite Editor
  • Compile source code (Shift+F5)
  • Compile source code and run (F5)
Note: The short-cut buttons on the Status Bar can be turned off via the Settings.
Sprite Editor [preview]
Atari Dev Studio includes a simple and easy to use Sprite Editor allowing you to create sprites, tiles and other objects for use in your projects. It has the following features:
  • New Project wizard allowing you to select the console (2600 or 7800), size, region (NTSC or PAL palette) and total colors of your sprites
  • Load and Save projects allowing you to save and come back to on-going work
  • Editing features such and palette selector, zoom, pen, eraser, fill and move modes
  • Ability to manage your sprites in a sortable list with options to copy, paste, duplicate, resize and delete
  • Export sprites to batari Basic or assembly source code (2600)
  • Export sprites to .png files (7800) - either selected or all (compatible with 7800basic 3+1 and 12+1 image requirements)
  • Load and save palettes
The Sprite Editor is based on Spritemate by Ingo Hinterding (GitHub) and was suggested by RandomTerrain for inclusion in Atari Dev Studio. I have customised the source to provide the required features necessary for editing sprites, tiles and objects for the Atari platforms. This work is currently in preview and will be on-going until all required features have been added.
Settings
There are a number of compiler, emulator and editor configuration options available in Atari Dev Studio which can be changed via the Settings (Preferences -> Settings -> Extensions -> Atari Dev Studio).
Debugging the extension
During the development phase of the extension I've added some developer output to assist with any issues that may appear. To view this output, open the VS Code Developer Tools by selecting Help -> Toggle Developer Tools from the menu, and in the debugger window ensure the Console tab is activated. This information may help identify the area where the extension is failing to process as expected.
Known Issues
There are currently no known feature issues. If you find a problem please raise an issue on GitHub or contact mksmith at the AtariAge community.
Acknowledgements
This extension is only available due to the great people of the AtariAge community who have created these tools to help developers build their vision. Special thanks to the following for either allowing the inclusion of their tools or for their ongoing help and encouragement:
  • 7800basic - Mike Saarna (RevEng)
  • batari Basic - Fred 'batari' Quimby
  • dasm - the many contibutors
  • Stella emulator - Stephen Anthony (stephena)
  • A7800 emulator - Mike Saarna (RevEng) and Robert Tuccitto (Trebor).
  • The AtariAge community including Albert, CPUWiz, Random Terrain, Trebor, Synthpopalooza, sramirez2008, Defender_2600, Gemintronic, Karl G, ZeroPage Homebrew, Muddyfunster, TwentySixHundred, Lillapojkenpåön, Andrew Davie, splendidnut, andyjp, sexyUnderwriter, MikeBrownEmplas, Generation2Games, cwieland, slacker
  • Mats Engstrom (SmallRoomLabs)
Languages
Atari Dev Studio includes the following programming languages:
batari Basic (release 1.5 - 20200307)
batari Basic created by Fred 'batari' Quimby is a BASIC-like language used in the creation of Atari 2600 games. batari Basic is compiled to generate a binary file that can by used on actual Atari 2600 VCS hardware via cartridge (such as a Harmony or UNO cart) or by using an Atari 2600 VCS emulator such as Stella.
batari Basic is an external project and can be downloaded separately from here. Further information is about this release is available here at AtariAge.
7800basic (release 0.18 - 20210314)
7800basic is a BASIC-like language for creating Atari 7800 games. It is a compiled language that runs on a computer, and it creates a binary file that can be run with an Atari 7800 emulator, or the binary file may be used to make a cartridge that will operate on a real Atari 7800. 7800basic is derived from batari basic, a BASIC-like language for creating Atari 2600 games. Special thanks to the bB creator, Fred Quimby, and all of the the bB contributors!
7800basic is included as part of this extension with many thanks to Mike Saarna (RevEng). 7800basic is an external project and can be downloaded separately here. Further information about this release is available here at AtariAge.
dasm (release 2.20.14.1 - 20201109)
dasm is a versatile macro assembler with support for several 8-bit microprocessors including MOS 6502 & 6507, Motorola 6803, 68705 & 68HC11, Hitachi HD6303 (extended Motorola 6801), and Fairchild F8. Matthew Dillon started dasm in 1987-1988. Olaf 'Rhialto' Seibert extended dasm in 1995. dasm has also been maintained by Andrew Davie (2003-2008) and Peter Froehlich (2008-2015). The DASM team has taken over maintaining and updating dasm since 2019.
dasm is an external project and can be downloaded separately here.
Atari Dev Studio includes the following emulators for testing purposes:
Stella (release 6.5.3 - 20210421)
Stella is a multi-platform Atari 2600 VCS emulator released under the GNU General Public License (GPL). Stella was originally developed for Linux by Bradford W. Mott, and is currently maintained by Stephen Anthony. Since its original release several people have joined the development team to port Stella to other operating systems such as AcornOS, AmigaOS, DOS, FreeBSD, IRIX, Linux, OS/2, MacOS, Unix, and Windows. The development team is working hard to perfect the emulator and we hope you enjoy our effort.
Stella is included as part of this extension with many thanks to Stephen Anthony. Stella is an external project and can be downloaded separately here. If you enjoy using Stella place consider donating to ensure it's continued development.
A7800 (release 4.0 - 20200610)
A7800 is a fork of the MAME Atari 7800 driver, with several enhancements added:
Support for emulation of Proline Joysticks, VCS Joysticks, Lightguns, Paddles, Driving Controllers, Keypads, Trak-Balls, Amiga Mice, and ST Mice.
  • Maria DMA timing has been improved further, with the addition of accurate DMA hole penalties.
  • Improved saturated/normalized colors with palette selection.
  • Streamlined UI including menu options to have an Atari 7800 system focus.
  • A bug in the existing RIOT emulation has been fixed.
  • POKEY sound emulation improvements.
  • SALLY (CPU) and MARIA (Graphics chip) performance adjustments.
  • Framerate updated to 50Hz/60Hz.
  • Audio indication of no ROM loaded silenced.
  • BIOS files no longer required and made optional.
  • Implementation of XM control registers updated.
MAME compatibility and syntax has been maintained, to allow for the reuse of MAME configuration files and front-ends.
A7800 is included as part of this extension with many thanks to Mike Saarna (RevEng). A7800 is an external project and can be downloaded separately here. Further information about this release is available here at AtariAge.
Releases
20210422 - Build v0.7.1
20210315 - Build v0.7.0
20210305 - Build v0.6.9 / 20210216 - Build v0.6.8 / 20210210 - Build v0.6.7 / 20201124 - Build v0.6.5 / 20201008 - Build v0.6.4 / 20200917 - Build v0.6.3 / 20200915 - Build v0.6.2 / 20200912 - Build v0.6.1 / 20200901 - Build v0.6.0
20200829 - Build v0.5.9 / 20200624 - Build v0.5.8 / 20200622 - Build v0.5.7 / 20200616 - Build v0.5.5 / Build v0.5.6 / 20200608 - Build v0.5.4 / 20200518 - Build v0.5.3 / 20200508 - Build v0.5.2 / 20200429 - Build v0.5.1 / 20200427 - Build v0.5.0
20200415 - Build v0.4.9 / 20200415 - Build v0.4.8 / 20200414 - Build v0.4.7 / 20200409 - Build v0.4.6 / 20200407 - Build v0.4.5 / 20200323 - Build v0.4.4 / 20200321 - Build v0.4.3 / 20200317 - Build v0.4.2 / 20200316 - Build v0.4.1 / 20200314 - Build v0.4.0
20200314 - Build v0.3.9 / 20200312 - Build v0.3.8 / 20200307 - Build v0.3.6/v0.3.7 / 20200305 - Build v0.3.5 / 20200217 - Build v0.3.4 / 20200129 - Build v0.3.3 / 20200128 - Build v0.3.2 / 20200108 - Build v0.3.1 / 20191022 - Build v0.3.0
20190807 - Build v0.2.8 / 20190711 - Build v0.2.7 / 20190614 - Build v0.2.5 / 20190611 - Build v0.2.4 / 20190604 - Build v0.2.3 / 20190528 - Build v0.2.2 / 20190522 - Build v0.2.1 / 20190521 - Build v0.2.0
20190513 - Build v0.1.9 / 20190510 - Build v0.1.8 / 20190506 - Build v0.1.7 / 20190428 - Build v0.1.6 / 20190425 - Build v0.1.5 / 20190421 - Build v0.1.2 & v0.1.3 / 20190420 - Build v0.1.1
20190419 - Build v0.1.0 - Initial release
Manual download
  • Like 31
  • Thanks 2
A new release (v0.1.1) is now available with the following changes:
  • Added new Help references and Learn areas for batari Basic and 7800basic to Welcome page
  • Removed templates from Welcome page (for now)
  • Updated readme with more information about the product
  • Updated all internal references to accessing the settings to a const to better maintain future changes
Issues
  • #1 [underReview] - Added compiler notification to help with permission error when compiling dasm on macOS (thanks SmallRoomLabs)
  • #2 [Fixed] - Removed popup message (thanks SmallRoomLabs)
  • #3 [Fixed] - Updated breadcrumb to Settings to correct path and catered for cross-platform (thanks SmallRoomLabs)
  • #4 [Fixed] - Updated syntax highlighter (thanks SmallRoomLabs)
  • Like 4
Is this new? I just installed it this morning and was wondering why I never heard of it. Its awesome!
Thanks! I started an extension for batari Basic (and dasm) in January as editing in vBB got a little difficult for larger projects (plus It was able to be cross-platform). Since then I had a number of requests to add 7800basic so I decided to restart with a new extension and here we are!
Thanks for your hard work on this. I look forward to trying it out.
No probs - been great learning Typescript actually! Hope you enjoy it!
Absolutely amazing. Thank you so much for using VS Code and making this cross-platform. Huge props!
Pleasure! Just hoping it can help the community of homebrew developers! Cross-platform is always a major issue with most IDEs/tools so it's great something like VS Code is available!
A new release (v0.1.2) is now available with the following changes:
  • Added option in settings to show/hide commands on Status Bar (thanks SmallRoomLabs)
  • Updated readme with information about debugging
Issues
  • #1 [Fixed] - Added compiler notification to help with permission error when compiling dasm on macOS (thanks SmallRoomLabs)
  • #5 [Done] - Usage of status line (thanks SmallRoomLabs)
[update] We have final approval! I'll update the instructions with some images on how to install.
Edited by mksmith
[i'm SmallRoomLabs at Github] and I have to agree with the previous posters that the ADS is a lovely addition to both the VSC and the Atari ecosystems (hmm... I really dislike that word).
I picked up the Racing the Beam-book at a flea market some weeks ago and that got me interested in the 2600 so I tried out some coding in the 8bitworkshop IDE for a bit, but even if the live-compile-reload is a cool feature the editor is not fun at all to use. So now with the release of this VCS extension my journey of coding for the 2600 will be a lot more enjoyable. (Enough for me to spend some money at Ebay for a Sixer with two sets of controllers ^__^ )
Edited by matseng
A new release (v0.1.3) is now available with the following changes:
  • Updated 7800basic language definition with all (known) keywords, commands and variables. Note: there is every chance I have either missed some or labled incorrectly.
  • Update readme to include imore information about installing and a note about turning off the short-cut buttons on the Status Bar
I've picked up the Racing the Beam-book at a flea market some weeks ago and that got me interested in the 2600 so I tried out coding for it the 8bitworkshop IDE for a bit, but even if the live-compile-reload is a cool feature there the editor is not fun at all to use. So now with the release of this VCS extension my journey of coding for the 2600 will be a lot more enjoyable. (Enough for me to spend some money at Ebay for a Sixer with two sets of controllers ^__^ )
Thanks so much for you assistance and input into the changes over the past few days. Very much appreciated!
Yeah all this got me buying a Vader first up then picked up a non-working light sixer which I repaired (also got 3 jrs I repaired but have yet to list). Desperate to get a 7800 (have just missed out on a few - pretty expensive here in Australia). So much fun!
A new release (v0.1.5) is now available with the following changes:
  • Introduction of a new feature :grin: It cannot do anything other than the basics - just wanted to see if it runs OK on other PCs.
Edited by mksmith
So this release contains the introduction of a Sprite Editor (basic functionality only). The Sprite Editor is based on Spritemate by Ingo Hinterding (github) and was suggested by RandomTerrain. I've taken the original source and rebuilt and restructured it. It cannot do anything other than the basics - just wanted to see if it runs OK on other PCs.
You can open it either from the Status Bar or via the Welcome page.
Current features
Moveable windows
Palette color selector (currently 7800 NTSC colors)
Multiple sprites (New, Copy/Paste, Duplicate, Re-order (drag/drop), Delete)
Draw, Erase, Fill, Move, Undo, Redo, Zoom
Under development
Load/Save (ie workspace) - hoping to integrate into VS Code dialogs if I can
Export to png (strip of images), assembly and other formats
Features specific to the 2600 and 7800 ie. sprite sizes, palettes etc
Future
Animator
Additional editing features ie. lines, circles etc
Edited by mksmith
Is there a way to have the settings from the previous session become the default settings? i.e. The default programming language is currently bataribasic, currently I have to re-set the language to 7800basic every time I open Code Studio. This is also true of the settings for A7800, i.e. I have to reconfigure my joypad controls on A7800 every time I open Code Studio. Is there some way to set these as default I haven't seen, or is there some way it could be implemented?
Also, the A7800 launches as the NTSC 7800, is there a way to get the PAL version to be what launches instead?
Thanks for the work, I haven't installed the sprite editor version, but that looks really useful.
To set the default language as 7800basic there are 2 ways:
  • Make the file extension .78b (batari Basic can also use .bb)
  • Change the VS Code settings. Open your file, click on the Language Selector on the Status Bar (bottom right will say batari Basic) and choose Configure File Association for '.bas'... and then select 7800basic from the list. This will then open to 7800basic always
The main issue I have is historically both bB an 7800basic use the .bas file extension so one has to be the default in terms of which one VS Code chooses but in the end you can make it work by doing one of the above.
As for A7800 you can default the specific region via the settings (Preferences > Settings -> Extensions -> Atari Dev Studio). Locate the Emulator > A7800: Region option and you can set the various NTSC or PAL requirements.
For the actual A7800 emulator configuration I'm not entirely sure why that wouldn't save (it's just MAME). Which OS are you on as for Linux and macOS I do need to set the chmod properties for certain things... Regardless I'll have a play around and see if I can determine.
Edited by mksmith
A new release (v0.1.6) is now available with the following changes:
Sprite Editor
  • Added ability to load and save sprites
  • Added (auto) load and save of the workspace configuration (window layout)
  • Added ability to select and hold down mouse button to change palette colors on the fly for selected color
  • Fixed issue where holding down mouse button and leaving the sprite editing area left drawing mode on
Appears to be loading/saving OK on Windows and Linux but it's reasonably complex in that I need to communicate back and forwards using event listeners between VS Code and the Webview running the editor. We'll push on to saving .pngs out so I can test out 7800basic with them.
In case it helps: I have approached the same problem in 6502.ts (emulation is running on a web worker, and I need communicate between worker and main thread) with a thin layer that builds a promise-based RPC layer on postMessage. I have published the code as a library on NPM: https://www.npmjs.com/package/worker-rpc
Edited by DirtyHairy
@DirtyHarry - thanks will check that out!
Thanks for that help. I don't know what happened with configuring the controller inputs, the first time or two I loaded Studio Code it didn't remember the settings, but then after that, it did. So, problem solved I guess.
A new release (v0.1.7) is now available with the following changes:
Issues
  • #6 [Done] - Added new drop-down selector in settings to choose what you want to display on the Status Bar (Full, Minimum, None) [thanks SmallRoomLabs]
  • #7 [Done] - Autoclose any existing Stella windows before opening a new one (new option in settings to override) [thanks SmallRoomLabs]
  • #8 [Fixed] - When a dasm compilation fails clean up files generated by compiler (.sym/.bin/.lst) [thanks SmallRoomLabs]
  • #9 [Fixed] - Fixed issue autosaving files before compile (async) [thanks SmallRoomLabs]
  • #11 [Done] - Updated label determination in dasm assembly syntax [thanks SmallRoomLabs]
Sprite Editor
  • Added ability to export all sprites in project to .png (2 bit 7800basic)
  • Added ability zoom editor with mousewheel
  • Added ability to set transparent background color in editor (not exported to .png) to help when designing sprites
Edited by mksmith
  • Like 4
A new release (v0.1.8 ) is now available with the following changes:
  • #12 [Done] - SmallRoomLabs added a process to display hover tooltips to dasm language for 6502 and VCS opcodes [thanks SmallRoomLabs]
  • Extended hover tooltip process to work across all languages
  • Minor internal changes to Sprite Editor for future enhancements
Thanks to Mats (SmallRoomLabs) for investigating the hover tooltip process in VS Code. Thanks to his great work we now have tooltips (just hover the mouse over the opcode/keyword to view) for 6502 and VCS opcodes (all languages):
Now I need to build upon this for extra information in bB and 7800basic as well as some proper intellisense (will come after the Sprite Editor is done).
  • Like 5
A new release (v0.1.9) is now available with the following changes:
  • #13 [Done] - SmallRoomLabs updated hover text to markdown format [thanks SmallRoomLabs]
  • Updated 7800basic compilation routine to validate for additional errors
Sprite Editor
  • Updated Project area to store loaded file and auto save or prompt
  • Added menu bar back to display filename of active file
  • Updated Palette selector to display user colors across then down to allow for future expansion
  • Changes to file format to allow sprite size to be stored
  • Further internal changes
  • Like 7
