spinnaker15136 #1 Posted April 21, 2019 (edited) My 810 does not seem to be working. It is the only serial device I have. I want to write a program to send data to the serial out to see if it is ny 810 or the serail port on the 800 that is the issue. I wrote a RS232 driver for a custom RS232 interface I designed but that was 30 years ago. And of course the code is on the disk so I can't get to it. Can anyone point me to some sample code for talking to the SIO? I just want to send raw data out. Or can someone remind me, do I want to look at the pokey interface or the CIO interface? Edited April 21, 2019 by spinnaker15136 Quote Share this post Link to post Share on other sites
spinnaker15136 #2 Posted April 21, 2019 In the back of my OS manual, I have some cryptic notes scribbled: With 3&4 Clock 399 baud = 11-high 163-164-165 LOW 53766 53764 2980 2976 circled I am sure I knew what that meant at the time. I sure wish I took better notes. 53766 is the Audio channel 4 frequency and 53764 is channel 3 frequency. So I am guessing maybe I wrote directly to the registers for my driver to at least set up the baud rate. I wrote some basic code to do noting but write to 53773 (serial out but I saw no transitions on the serial port. Quote Share this post Link to post Share on other sites
sanny #3 Posted April 23, 2019 I found this on my hard disk to send something to the serial port: 99 REM 01-JAN-2000 100 OPEN #1,13,0,"R1:" 110 XIO 36,#1,14,0,"R1:" 120 PRINT #1,"NEUES HALLO!";CHR$(13);CHR$(10) 130 CLOSE #1 It opens the port with 9600 baud (XIO "14" parameter), 8n1. Although the open specifies input+output (parameter "13" in OPEN), it doesn't start concurrent I/O. But I guess it worked, otherwise I wouldn't have kept it or fixed it to work. For input you have to start "concurrent mode" with XIO 40. See the 850 user's manual for more information. regards, chris Quote Share this post Link to post Share on other sites
_The Doctor__ #4 Posted April 23, 2019 810 or 850? which is it... Quote Share this post Link to post Share on other sites
sanny #5 Posted April 23, 2019 Hmm, just re-read the post, and OP was talking about 810. Sorry, I was somehow thinking about 850... Quote Share this post Link to post Share on other sites
1050 #6 Posted April 24, 2019 My opinion only and by experience you might want to replace your 6520 on the 800 with a 68B21 since I've had two out of three 800s that needed that done to it before any device answered to a SIO call. Reseating the chip may help too, but in my case the 6520 was nonfunctional with repeated attempts AFTER I got a good 68B21 in there. For some reason the early 6520s weren't made to last? Others should be in here going on about a new Pokey, can't fathom where they are, but both 40 pin chips have been found to be lacking after a 30 year nap. I'm not kidding 2 out of three, needed a new 68B21 which is identical to original 2 MHz 6520 PIA. eBay or Jameco. Produces SIO /PROCEED /COMMAND /INTERRUPT signals directly while Pokey creates Data and Clock I/O. It's also important to spray some contact cleaner of the de-oxit type on the drive select switches and while still wet, work them quite well. And again after drying. I need to do this every ten years, the state they relate to the drive's OS comes and goes such that the drive really doesn't know which one it is at any random moment and will only boot from Drive 1 anyway. Quote Share this post Link to post Share on other sites
spinnaker15136 #7 Posted April 26, 2019 Got the 810 working. So I know the SIO is working. Thanks. 1 Quote Share this post Link to post Share on other sites
