jedimatt42
Force Command : kinda like command.com from 1985 (no TIPI required!)
Hi @jedimatt42,
With version 1.11 my AUTOCMD script no longer works. I only get the system prompt.
AUTOCMD1
I then made a simpler script and it worked up to the readkey command.
Readkey is not executed - the system prompt appears.
AUTOCMD
Everything worked with V1.10.
37 minutes ago, wolhess said:
Hi @jedimatt42,
AUTOCMD 384 B · 1 download
I noticed that. Anything that came after setting up XB did not work. However, setting up XB at the end of the script solved the problem.
I have to agree with wolhess & Vorticon
My AUTOCMD stops processing at XBMOD=SXBG
After it fails: I have a  script/batch named "X" (One letter because I am a lazy typist. 😞
ECHO PLAY CHRISTMAS MUSIC
CD TIPI.MUSIC.TIXMAS
STARTXMAS
"STARTXMAS" start doesn't run. It is a READKEY menu script with 10 selections. (First line is "BEGIN:")
STARTXMAS
Try moving your XB setup commands to the end of the script.
Looks like I totally broke scripting... part compiler not behaving like I expect, and part me missing an increment command.  We'll see.  1.11 is a dud.
so, I'm more of a defaults kind of user... or the defaults are what I use.. LOL.. so when I switched the script file closing to be only approved commands, any variable assignment fell into the unapproved commands... ( they don't have well known names, since users can set their own for their own purposes. )
Anyway, setting variables still closes the script... I'll try to prevent that in a later update. But now it resumes properly.
Note: because it closes the script, and then to resume has to sequentially read from the beginning of the file to the next line, setting environment variables will be most efficient if they are up front (for now)
Edited by jedimatt42
Happy to see the SYSINFO Command!
Just for information: On my European computer, SYSINFO displays "TMS9918A PAL". In fact, it should display "TMS-9929A" because a TMS-9918A is only for NTSC.
Do you plan to allow the creation of a simple text file on a device? Like COPY CON as on MS-DOS. It would be very practical to quickly and autonomously create AUTOCMD files.
Edited by fabrice montupet
Thanks for the TIP... I knew 9918 was a little wrong if PAL, but wasn't confident I could assert the 9929A. Then there is the NTSC 9928A, ( I think, and I don't believe that is detectable.. or matters, custom one-off mods )
9938 and 9958 can be switched PAL or NTSC, but the chip is detectable directly.
I'd like to get to '>' output redirect, probably not ever going to get to '|' pipe or '<' stdin in redirection.  But I'd prefer to have a tiny embedded editor, and solve that problem in a better than minimal way.
I am surprised by how the COPY command works.
Configuration used for the test: a stock TI-99 / 4A, a TI floppy disk controller, one single floppy drive. The floppy disk inserted in DSK1 contains the BASIC program: TEST
I type:
>CD DSK1
>DIR
FC lists me the contents of the floppy disk:
NAME             TYPE        P     RECLEN     SECTORS
TEST             PROGRAM     P     81         16
Everything is normal so far.
Now, while I don't have a second drive, I type:
> CD DSK2
The command is accepted. This seems to mean that the management of a disk in DSK2 is accepted.
So, I type:
> DIR
The command is well accepted and just sends me a carriage return. But it shouldn't because this drive is missing. We should see displayed: "No disk in Drive" or  better : "No Drive".
Because otherwise, one could be tempted to launch a command of the type:
> COPY DSK1.TEST DSK2
Which of course doesn't work.
Yes, DIR not erroring is something I just haven't gotten around to fixing.
This error is not limited to floppy controllers.
I was just thinking that the other day. That would be a very handy feature indeed. I second the request, although I suspect it's not a trivial one by any stretch.
I don't think the 9928A is used in any TI model. It's either 9918A NTSC or 9929A PAL.
F18A NTSC is also misleading. To be consistent it should be F18A VGA.
How about 50hz or 60hz as the point is the interrupt rate.
Yes, that would be my preferred option.
Hi @jedimatt42,
with the version v1.12 of Force Command the prompt command does not work as described in the wiki.
Now I can make all character after the "prompt=" to the system prompt.
Is this right? What about the crubase or the drive/path information?
Sorry to bother people with very basic questions, but I'm starting all over from scratch with the new versions of Force Command and the TIPI versions, I've also decided to make Extended BASIC 2.8 GEM my BASIC of choice due to the built in T80XB routines.  With that in mind, I really need the following two questions answered...
XBMOD= (for the cartridge)
XBADDR=(for the entry point at T80XB)
Thanks!
17 hours ago, jedimatt42 said:
I may have to update that page if the cart menu for GEM has changed.
As of yet, I'm unaware of a published entry point for the T80XB XBADDR.
Yeah, I've noticed that too!  Whenever I change the prompt to something else that valuable information vanishes, so I had to type: "PROMPT=" to revert to normal.  I guess my OCD is showing over a ">".
